Mentions légales du service
Aseba compilation fails on Ubuntu Wily
Created by: stephanemagnenat
Probably a missing include:
[100%] Building CXX object tests/CMakeFiles/test-asebahttp.dir/test-http.cpp.o
In file included from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_expression_lhs.hpp:12:0,
                 from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_result_builder.h:91,
                 from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_capture.hpp:11,
                 from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/catch.hpp:34,
                 from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/test-http.cpp:14:
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:43:17: error: ‘nullptr_t’ in namespace ‘std’ does not name a type
     inline std::nullptr_t opCast(std::nullptr_t) { return nullptr; }
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:58: error: ‘template<Catch::Internal::Operator Op, class T> bool Catch::Internal::compare’ conflicts with a previous declaration
     template<Operator Op, typename T> bool compare( std::nullptr_t, T* rhs ) {
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:159:44: note: previous declaration ‘namespace Catch::Internal { }::compare’
     template<Operator Op, typename T> bool compare( T* lhs, int rhs ) {
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:53: error: ‘nullptr_t’ is not a member of ‘std’
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:70: error: expected primary-expression before ‘*’ token
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:72: error: ‘rhs’ was not declared in this scope
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:76: error: expression list treated as compound expression in initializer [-fpermissive]
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:165:78: error: expected ‘;’ before ‘{’ token
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:168:66: error: ‘std::nullptr_t’ has not been declared
     template<Operator Op, typename T> bool compare( T* lhs, std::nullptr_t ) {
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:168:44: error: redefinition of ‘template<Catch::Internal::Operator Op, class T> bool Catch::Internal::compare(T*, int)’
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_evaluate.hpp:159:44: note: ‘template<Catch::Internal::Operator Op, class T> bool Catch::Internal::compare(T*, int)’ previously declared here
In file included from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_expression_lhs.hpp:13:0,
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.h:57:38: error: ‘std::__cxx11::string Catch::toString’ redeclared as different kind of symbol
 std::string toString( std::nullptr_t );
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.h:54:13: note: previous declaration ‘std::__cxx11::string Catch::toString(unsigned char)’
 std::string toString( unsigned char value );
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.h:57:23: error: ‘nullptr_t’ is not a member of ‘std’
In file included from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_impl.hpp:35:0,
                 from /home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/catch.hpp:53,
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.hpp:161:38: error: ‘std::__cxx11::string Catch::toString’ redeclared as different kind of symbol
 std::string toString( std::nullptr_t ) {
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.h:202:13: note: previous declaration ‘template<class T, class Allocator> std::__cxx11::string Catch::toString(const std::vector<_Tp, _Alloc>&)’
 std::string toString( std::vector<T,Allocator> const& v ) {
/home/steph/data/aseba-thymio/aseba-community/aseba/tests/externals/Catch/include/internal/catch_tostring.hpp:161:23: error: ‘nullptr_t’ is not a member of ‘std’
tests/CMakeFiles/test-asebahttp.dir/build.make:54: recipe for target 'tests/CMakeFiles/test-asebahttp.dir/test-http.cpp.o' failed
make[2]: *** [tests/CMakeFiles/test-asebahttp.dir/test-http.cpp.o] Error 1
