Mentions légales du service
Native sum
Created by: motib
I would like a native function to sum the elements of an array, instead of writing an explicit loop. Since the following code works, it should be possible to implement without changing the firmware.
var a[8] = [...]
var ones[8]
call math.fill(ones, 1)
call math.dot(sum, a, ones, 0)
