Mentions légales du service
Aseba does not accept 'for' iteration on an array
Created by: severin-lemaignan
The following code:
var ledsrow[4]
onevent setLedsRow
ledsrow = [[0, 5], [6, 11]]
for i in ledsrow[event.args[0] * 2]:ledsrow[event.args[0] * 2 + 1] do
    call led.set(i, event.args[1], event.args[2], event.args[3])
end
does not compile with the message: Error at line ...: constant ledrows not defined
It seems like a bug to me because:
  • ledrows is not declared as a constant
  • I can not see any obvious error in my code (note that I'm a total beginner with the Aseba language, so I may miss something stupid), which let me think that for can not take its bounds from an array (??), which is not mention in the documentation
Note that the exact same issue occur if I define ledsrow as ledsrow = [0, 5, 6, 11].
