Mentions légales du service
drag an drop when line is selected
Created by: mbonani
there is a strange effect when you drag and drop a card under the last line. it replace the card of the select line even if it is hidden. It should add a line because user clearly want to add it under. Selected line should be only use when you click on card, and has no effect on drag and drop
