Mentions légales du service
Clear VPL data when code is changed in text mode
Created by: mbonani
Currently, if one saves a file with VPL, closes VPL, changes the code in text mode, and then saved, the code and VPL data are out of sync and therefore the code will be overwritten by VPL on next reload.
