Thymio updater windows warning
Created by: mbonani
With Thyimo updater, window launch every time a warning saying "Are you sure you let this program modify the computer"... It was not the case for the flasher. Maybe the new system to block to opening of COM ports. I already check it is not a problem of packaging
