Add the "switch" instruction
Created by: stephanemagnenat
This issue was moved from gna bug tracker, there it was bug 18102 (http://gna.org/bugs/?18102).
Florian Vaussard I agree, this is not a mandatory feature, but would be more confortable for big state machines.
Stéphane Magnenat Doing this is purely a syntactic extension, if implemented with chained if <-> else if.
The question whether it is worth the work and the complexification of the language, as chained elseif do implement the same idea:
if a == 1 then
elseif a == 2 then
elseif a == 3 then
else
end
Florian Vaussard It would be nice to have the "switch" instruction like in C.
