Mentions légales du service
Compiler generates wrong bytecode for indirect array access in native function call
Created by: stephanemagnenat
The compiler for version 1.2 generates a wrong bytecode for the following program:
var a = 1
var b = 2
var c[2] = 1,2
var result
call math.add(result, a, c[a])
At the end, result has value 1 where it should have value 3.
