Mentions légales du service
Move code from absent tab when node connects
Created by: stephanemagnenat
If a node connects, and if there is an absent tab with the same name and id, Studio should copy the code from the absent tab to the newly created active tab, and delete the absent tab. This implies adding an id to the absent tab in addition to the name.
