## Using ``Conda`` to install ``Axel``
## Using ``Conda`` to install ``Axl``
This installation requires first the installation of [conda](https://conda.io/miniconda.html):
... | @@ -13,37 +13,32 @@ For ``Linux`` or ``MacOS``, you can add the corresponding line: |
```shell
```shell
export PATH=/path/to/where/you/have/installed/miniconda*/bin:$PATH
at the end of your file ``$HOME/.bash_profile`` to have the variable ``PATH`` set up, each time you open a terminal. To set up the environment after editing the file, use:
at the end of your file ``$HOME/.bashrc`` (or ``$HOME/.bash_profile``) to have the variable ``PATH`` set up, each time you open a terminal. To set up the environment after editing the file, use:
```shell
```shell
source $HOME/.bash_profile
source $HOME/.bashrc
For ``Windows``, edit your environment variable ``PATH`` and add the path to the installation of miniconda ``C:\\....\\Miniconda*\\...\\Library\\bin\\``.
- Use conda to install ``Axel``:
## Installing Axl
Once ``conda`` is installed, you can use it to install ``Axl``:
```shell
```shell
conda install axel -c axel-distrib
conda install axl -c axel-distrib
- Check that ``axel`` is running:
Check that ``axl`` is now running:
```shell
```shell
axel
axl
This should start the application ``axel``, with its initial view of a frame.
This should start the application ``axl``, with its initial view of a frame.
## Installing Axl
Binary distributions can be installed with ``conda`` for Linux, MacOS and Windows from:
These binary distributions for ``linux64``, ``osx64`` and ``win64`` are from:
https://anaconda.org/axel-distrib
as follows:
where new releases will be made available. To installed a new version of ``axl``:
```shell
A new version of ``axl`` can be obtained with ``conda``:
```shell
```shell
conda update axl -c axel-distrib
## Dependencies
## Dependencies
... | @@ -62,7 +57,7 @@ conda install mesa |
[[Wiki]](https://gitlab.inria.fr/axel/axel/wikis/home)
[[Axl](http://axl.inria.fr/latest/)]
[[Axl](http://axl.inria.fr/)]
[[Gitlab]](https://gitlab.inria.fr/axel/axel)
