... | @@ -226,11 +226,11 @@ The following cost functions are currently supported: |
| `TtcaDca` | The cost function used in the vision-based steering algorithm by Dutra et al. (2016), simplified to our domain. | Dutra | 1,2 |
| `VanToll` | A custom collision-avoidance cost function that is sometimes used by our own team. | VanToll | - |
**Notes:**
*Notes:*
(1) This cost function is meant to be used in a gradient-based policy. You are free to use it in a sampling-based policy as well, but it may not behave exactly as intended.
1. This cost function is meant to be used in a gradient-based policy. You are free to use it in a sampling-based policy as well, but it may not behave exactly as intended.
(2) This cost function does not yet support obstacles. Agents that use this cost function will not avoid obstacles.
2. This cost function does not yet support obstacles. Agents that use this cost function will not avoid obstacles.
(3) This cost function is under construction, and it does not yet act as intended.
3. This cost function is under construction, and it does not yet act as intended.
(4) This cost function also supports global optimization, using a direct port of the ORCA source code.
4. This cost function also supports global optimization, using a direct port of the ORCA source code.
(5) This cost function does not yet support global optimization, even though it is theoretically possible.
5. This cost function does not yet support global optimization, even though it is theoretically possible.
Each specific cost function can have its own **specific attributes**. We are currently not listing these attributes here. Instead, they are specified in the (Doxygen) comments of each cost function's C++ header file. For example, the documentation in `core/CostFunctions/RVO.h` describes the parameters of the RVO cost function. Therefore, the best option is to look in the Doxygen comments of the cost function that you want to use. |
\ No newline at end of file |
