... | @@ -210,21 +210,21 @@ A `CostFunction` element has the following **main attributes**: |
The following cost functions are currently supported:
| Name in XML | Description | Used in example policy | Notes |
| Name in XML | Description | Used in example policy | Additional attributes | Notes |
| `FOEAvoidance` | An avoidance function based on the focus of expansion. | - | 1,2 |
| `FOEAvoidance` | An avoidance function based on the focus of expansion. | - | - | 1,2 |
| `GoalReachingForce` | The goal-reaching force described by Helbing and Molnár (1995). | SocialForces | 1 |
| `GoalReachingForce` | The goal-reaching force described by Helbing and Molnár (1995). | SocialForces | - | 1 |
| `Karamouzas` | The cost function used in the velocity-based algorithm by Karamouzas and Overmars (2010). | Karamouzas | - |
| `Karamouzas` | The cost function used in the velocity-based algorithm by Karamouzas and Overmars (2010). | Karamouzas | `alpha`, `beta`, `gamma`, `delta`, `t_max` | - |
| `Moussaid` | The cost function used in the velocity-based algorithm by Moussaid et al. (2011). | Moussaid | - |
| `Moussaid` | The cost function used in the velocity-based algorithm by Moussaid et al. (2011). | Moussaid | `d_max` | - |
| `ORCA` | The cost function used in the ORCA method by van den Berg et al. (2011). | ORCA | 2,4 |
| `ORCA` | The cost function used in the ORCA method by van den Berg et al. (2011). | ORCA | `timeHorizon` | 2,4 |
| `Paris` | A cost function inspired by the collision-avoidance algorithm of Paris et al. (2007). | - | 2,3 |
| `Paris` | A cost function inspired by the collision-avoidance algorithm of Paris et al. (2007). | - | `w_a`, `w_b`, `t_max` | 2,3 |
| `PLEdestrians` | The cost function used in the PLEdestrians model by Guy et al. (2010). | PLEdestrians | 5 |
| `PLEdestrians` | The cost function used in the PLEdestrians model by Guy et al. (2010). | PLEdestrians | `w_a`, `w_b`, `t_min`, `t_max` | 5 |
| `PowerLaw` | The force used in the 'Universal Power Law' model by Karamouzas et al. (2014) | PowerLaw | 1,2 |
| `PowerLaw` | The force used in the 'Universal Power Law' model by Karamouzas et al. (2014) | PowerLaw | `k`, `tau0` | 1,2 |
| `RandomFunction` | A function that returns random costs and gradients. Useful for adding noise to the system. | - | - |
| `RandomFunction` | A function that returns random costs and gradients. Useful for adding noise to the system. | - | - | - |
| `RVO` | The cost function used in the original RVO implementation by van den Berg et al. (2008). | RVO | - |
| `RVO` | The cost function used in the original RVO implementation by van den Berg et al. (2008). | RVO | `w` | - |
| `SocialForcesAvoidance` | The avoidance component of the social-force model by Helbing and Molnár (1995). | SocialForces | 1 |
| `SocialForcesAvoidance` | The avoidance component of the social-force model by Helbing and Molnár (1995). | SocialForces | `dt`, `V0`, `sigma`, `U0`, `R` | 1 |
| `TtcaDca` | The cost function used in the vision-based steering algorithm by Dutra et al. (2016), simplified to our domain. | Dutra | 1,2 |
| `TtcaDca` | The cost function used in the vision-based steering algorithm by Dutra et al. (2016), simplified to our domain. | Dutra | `sigmaTtca`, `sigmaDca`, `sigmaAngle_goal`, `sigmaSpeed_goal` | 1,2 |
| `VanToll` | A custom collision-avoidance cost function that is sometimes used by our own team. | VanToll | - |
| `VanToll` | A custom collision-avoidance cost function that is sometimes used by our own team. | VanToll | `max_distance` | - |
*Notes:*
*Notes:*
1. This cost function is meant to be used in a gradient-based policy. You are free to use it in a sampling-based policy as well, but it may not behave exactly as intended.
... | @@ -233,4 +233,4 @@ The following cost functions are currently supported: |
4. This cost function also supports global optimization, using a direct port of the ORCA source code.
5. This cost function does not yet support global optimization, even though it is theoretically possible.
Each specific cost function can have its own **specific attributes**. We are currently not listing these attributes here. Instead, they are specified in the (Doxygen) comments of each cost function's C++ header file. For example, the documentation in `core/CostFunctions/RVO.h` describes the parameters of the RVO cost function. Therefore, the best option is to look in the Doxygen comments of the cost function that you want to use. |
As seen in the table above, many cost functions have their own **additional attributes**. These are usually one-on-one translations of the algorithm's parameters described in the corresponding paper. If you want to know more about them, we recommend you to take a look at the (Doxygen) documentation of the UMANS codebase. For example, the documentation in `core/CostFunctions/SocialForcesAvoidance.h` describes the parameters of the `SocialForcesAvoidance` cost function in more detail. |
\ No newline at end of file |
