Commit 340d4ef2 authored by DAUXAIS Yann's avatar DAUXAIS Yann
Add tid list output for extracted chronicles with --tid (experimental)
parent 1e718022
...@@ -19,6 +19,7 @@ CDA::testSub( ...@@ -19,6 +19,7 @@ CDA::testSub(
std::vector<std::pair<int*, int*>> values = r.getValues(); std::vector<std::pair<int*, int*>> values = r.getValues();
unsigned int vf = 0; unsigned int vf = 0;
std::vector<unsigned int> tid_list_pos;
for (unsigned int i = 0; i < data.size(); i++) { for (unsigned int i = 0; i < data.size(); i++) {
bool match = false; bool match = false;
...@@ -45,12 +46,16 @@ CDA::testSub( ...@@ -45,12 +46,16 @@ CDA::testSub(
if (match) vf++; if (match) {
vf++;
if (this->extract_with_tid) tid_list_pos.push_back(i);
if (vf >= (unsigned) f) { if (vf >= (unsigned) f) {
unsigned int vfn = 0; unsigned int vfn = 0;
for (unsigned int i = 0; i < data_b.size(); i++) { std::vector<unsigned int> tid_list_neg;
for (unsigned int j = 0; j < data_b[i].size() && !match; j++) { for (unsigned int j = 0; j < data_b[i].size() && !match; j++) {
...@@ -66,7 +71,10 @@ CDA::testSub( ...@@ -66,7 +71,10 @@ CDA::testSub(
match = true; match = true;
if (match) vfn++; if (match) {
vfn++;
if (this->extract_with_tid) tid_list_neg.push_back(i);
if (vfn == 0 || double(vf)/(double(vfn)*ratio) >= g) { if (vfn == 0 || double(vf)/(double(vfn)*ratio) >= g) {
...@@ -83,10 +91,19 @@ CDA::testSub( ...@@ -83,10 +91,19 @@ CDA::testSub(
tcis.push_back(TCIterator(std::shared_ptr<TC>(tc), true)); tcis.push_back(TCIterator(std::shared_ptr<TC>(tc), true));
if (txt) if (txt) {
std::cout << Chronicle(elements, tcis, vf, vfn).txt(inv_events, &disc) << std::endl; if (!this->extract_with_tid)
else
std::cout << Chronicle(elements, tcis, vf, vfn, tid_list_pos, tid_list_neg).txt(inv_events, &disc) << std::endl;
else else
std::cout << Chronicle(elements, tcis, vf, vfn).json(inv_events, &disc) << std::endl; {
else
std::cout << Chronicle(elements, tcis, vf, vfn, tid_list_pos, tid_list_neg).json(inv_events, &disc) << std::endl;
...@@ -35,7 +35,8 @@ class CDA { ...@@ -35,7 +35,8 @@ class CDA {
bool stop; //!< Initialized to false, switch stop to true will break the main run(...) loop. bool stop; //!< Initialized to false, switch stop to true will break the main run(...) loop.
bool next; bool next;
int nb_tc; int nb_tc;
bool extract_with_tid;
std::vector<int> stats; std::vector<int> stats;
...@@ -209,7 +210,7 @@ class CDA { ...@@ -209,7 +210,7 @@ class CDA {
) const; ) const;
public : public :
CDA():stop(false),next(false),nb_tc(0){} CDA():stop(false),next(false),nb_tc(0),extract_with_tid(false){}
* Run the CDA algorithm (frequent chronicles). * Run the CDA algorithm (frequent chronicles).
...@@ -84,6 +84,17 @@ Chronicle::txt ( ...@@ -84,6 +84,17 @@ Chronicle::txt (
else else
os << "f: " << frequency << "/" << ofrequency << std::endl; os << "f: " << frequency << "/" << ofrequency << std::endl;
if (tid_list_pos.size() > 0) {
os << "positives: [" << tid_list_pos[0];
for (unsigned i = 1; i < tid_list_pos.size(); i++) os << ", " << tid_list_pos[i];
os << "]" << std::endl;
if (tid_list_neg.size() > 0) {
os << "negatives: [" << tid_list_neg[0];
for (unsigned i = 1; i < tid_list_neg.size(); i++) os << ", " << tid_list_neg[i];
return os.str(); return os.str();
...@@ -119,6 +130,16 @@ Chronicle::json ( ...@@ -119,6 +130,16 @@ Chronicle::json (
os << "],"; os << "],";
os << "\"positives\": [\"" << tid_list_pos[0] << "\"";
for (unsigned i = 1; i < tid_list_pos.size(); i++) os << ", \"" << tid_list_pos[i] << "\"";
os << "]," << std::endl;
os << "\"negatives\": [\"" << tid_list_neg[0] << "\"";
for (unsigned i = 1; i < tid_list_neg.size(); i++) os << ", \"" << tid_list_neg[i] << "\"";
if (ofrequency == -1) if (ofrequency == -1)
os << "\"frequency\": \"" << frequency << "\"}" << std::endl; os << "\"frequency\": \"" << frequency << "\"}" << std::endl;
else else
...@@ -156,4 +177,5 @@ Chronicle::indice ( ...@@ -156,4 +177,5 @@ Chronicle::indice (
const int& j const int& j
return j*(j-1)/2 +i; return j*(j-1)/2 +i;
\ No newline at end of file
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
class Chronicle { class Chronicle {
private: private:
static int nextId; static int nextId;
protected : protected :
...@@ -25,10 +25,30 @@ class Chronicle { ...@@ -25,10 +25,30 @@ class Chronicle {
int id; int id;
int frequency; int frequency;
int ofrequency; int ofrequency;
Chronicle(){} Chronicle(){}
Chronicle(
const std::vector<int>& e,
const std::vector <TCIterator>& c,
const int f,
const int of,
const std::vector<unsigned int>& tid_list_pos,
const std::vector<unsigned int>& tid_list_neg
_elements(e),
_constraints(c),
_flag(0),
id(nextId++),
frequency(f),
ofrequency(of),
tid_list_pos(tid_list_pos),
tid_list_neg(tid_list_neg)
Chronicle( Chronicle(
const std::vector<int>& e, const std::vector<int>& e,
const std::vector<TCIterator>& c, const std::vector<TCIterator>& c,
...@@ -45,6 +45,7 @@ public: ...@@ -45,6 +45,7 @@ public:
("IBM,u", "Use IBM format for files instead of sequence per line") ("IBM,u", "Use IBM format for files instead of sequence per line")
("mincs", po::value<unsigned> (&mincs), "Minimum size of extracted chronicles") ("mincs", po::value<unsigned> (&mincs), "Minimum size of extracted chronicles")
("maxcs", po::value<unsigned> (&maxcs), "Maximum size of extracted chronicles") ("maxcs", po::value<unsigned> (&maxcs), "Maximum size of extracted chronicles")
("tid", "Output the tid list in addition of extracted chronicles (first line is 0) /!\\ has to be proven to really correspond to the right line numbers")
("close,c", "Extract frequent closed chronicles or discriminant chronicles from closed multisets if --disc is used") ("close,c", "Extract frequent closed chronicles or discriminant chronicles from closed multisets if --disc is used")
("json,j", "Output format is json instead of plain text") ("json,j", "Output format is json instead of plain text")
("verbose,v", "The program will speak") ("verbose,v", "The program will speak")
...@@ -233,6 +234,7 @@ private: ...@@ -233,6 +234,7 @@ private:
if (vm.count("not_calc_freq")) calc_freq = false; if (vm.count("not_calc_freq")) calc_freq = false;
if (vm.count("json")) txt = false; if (vm.count("json")) txt = false;
if (vm.count("verbose")) verbose = true; if (vm.count("verbose")) verbose = true;
if(vm.count("tid")) tid = true;
positives.open(fname); positives.open(fname);
if (!positives) { if (!positives) {
...@@ -367,6 +369,7 @@ public: ...@@ -367,6 +369,7 @@ public:
bool dif; bool dif;
bool txt; bool txt;
bool verbose; bool verbose;
bool tid;
std::map<std::string, int> events; std::map<std::string, int> events;
std::vector<std::string> inv_events; std::vector<std::string> inv_events;
...@@ -377,7 +380,7 @@ public: ...@@ -377,7 +380,7 @@ public:
Options() : gname(""), ibm(false), cwm(0), mincs(0), maxcs(0), gmin(2), Options() : gname(""), ibm(false), cwm(0), mincs(0), maxcs(0), gmin(2),
calc_freq(true), close(false), episode(false), disc(false), dif(false), txt(true), verbose(false), calc_freq(true), close(false), episode(false), disc(false), dif(false), txt(true), verbose(false),
b(NULL), b2(NULL) {} tid(false), b(NULL), b2(NULL) {}
int main(const int argc, char* argv[]) int main(const int argc, char* argv[])
...@@ -405,6 +408,7 @@ int main(const int argc, char* argv[]) ...@@ -405,6 +408,7 @@ int main(const int argc, char* argv[])
if (options.disc) if (options.disc)
algo.inv_events = options.inv_events; algo.inv_events = options.inv_events;
algo.txt = options.txt; algo.txt = options.txt;
algo.extract_with_tid = options.tid;
std::vector<Chronicle> res; std::vector<Chronicle> res;
bool disc_exec = true; bool disc_exec = true;
