Commit fb161ae8 authored by MARCHE Claude's avatar MARCHE Claude
Finally made the editor preference setting working
parent 5ffd6fc3
...@@ -98,8 +98,8 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -98,8 +98,8 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
* Improved IDE: * Improved IDE:
- left scrollbar + selection of shown or hidden provers - left scrollbar + selection of shown or hidden provers
- font enlargement - font enlargement
- integration of support for prover upgrade - integration of the support for prover upgrade
- !!TODO!! support for selection of alternate editors - support for selection of alternate editors
* what else ? * what else ?
* see also the file CHANGES * see also the file CHANGES
...@@ -136,14 +136,6 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990 ...@@ -136,14 +136,6 @@ https://gforge.inria.fr/tracker/index.php?func=detail&aid=13736&group_id=2990
== TODOs == == TODOs ==
* (TOUS) Faire marcher la selection de l'editeur associé a un prouveur
dans l'IDE
** probleme: le choix n'est pas pris en compte, pas enregistré
** question subsidaire: remise en cause du systeme de Whyconf inutilement
compliqué et tres difficile a maintenir.
La raison initiale "permettre a l'IDE de stocker sa config dans
le meme fichier .conf" ne me semble pas justifier une telle complication
* DONE Document the Coq plugin and tactic * DONE Document the Coq plugin and tactic
** DONE option timelimit <n> ** DONE option timelimit <n>
** DONE renommer "coq-plugin" en "coq-tactic" ** DONE renommer "coq-plugin" en "coq-tactic"
...@@ -41,10 +41,7 @@ type t = ...@@ -41,10 +41,7 @@ type t =
mutable window_height : int; mutable window_height : int;
mutable tree_width : int; mutable tree_width : int;
mutable task_height : int; mutable task_height : int;
mutable time_limit : int;
mutable mem_limit : int;
mutable verbose : int; mutable verbose : int;
mutable max_running_processes : int;
mutable default_editor : string; mutable default_editor : string;
mutable intro_premises : bool; mutable intro_premises : bool;
mutable show_labels : bool; mutable show_labels : bool;
...@@ -182,7 +179,7 @@ let load_altern alterns (_,section) = ...@@ -182,7 +179,7 @@ let load_altern alterns (_,section) =
Mprover.add unknown known alterns Mprover.add unknown known alterns
let load_config config original_config = let load_config config original_config =
let main = get_main config in (* let main = get_main config in *)
let ide = match get_section config "ide" with let ide = match get_section config "ide" with
| None -> default_ide | None -> default_ide
| Some s -> load_ide s | Some s -> load_ide s
...@@ -198,8 +195,6 @@ let load_config config original_config = ...@@ -198,8 +195,6 @@ let load_config config original_config =
window_width = ide.ide_window_width; window_width = ide.ide_window_width;
tree_width = ide.ide_tree_width; tree_width = ide.ide_tree_width;
task_height = ide.ide_task_height; task_height = ide.ide_task_height;
time_limit = Whyconf.timelimit main;
mem_limit = Whyconf.memlimit main;
verbose = ide.ide_verbose; verbose = ide.ide_verbose;
intro_premises= ide.ide_intro_premises ; intro_premises= ide.ide_intro_premises ;
show_labels = ide.ide_show_labels ; show_labels = ide.ide_show_labels ;
...@@ -209,7 +204,6 @@ let load_config config original_config = ...@@ -209,7 +204,6 @@ let load_config config original_config =
premise_color = ide.ide_premise_color; premise_color = ide.ide_premise_color;
goal_color = ide.ide_goal_color; goal_color = ide.ide_goal_color;
error_color = ide.ide_error_color; error_color = ide.ide_error_color;
max_running_processes = Whyconf.running_provers_max main;
default_editor = ide.ide_default_editor; default_editor = ide.ide_default_editor;
config = config; config = config;
original_config = original_config; original_config = original_config;
...@@ -238,14 +232,28 @@ let load_config config original_config = ...@@ -238,14 +232,28 @@ let load_config config original_config =
let debug_save_config n c =
let coq = { prover_name = "Coq" ; prover_version = "8.3pl3";
prover_altern = "" } in
let p = Mprover.find coq (get_provers c) in
let time = Whyconf.timelimit (Whyconf.get_main c) in
Format.eprintf "[debug] save_config %d: timelimit=%d ; editor for Coq=%s@."
n time p.editor
let save_config t = let save_config t =
eprintf "[Info] saving IDE config file@.";
(* taking original config, without the extra_config *)
let config = t.original_config in let config = t.original_config in
let config = set_main config (* copy possibly modified settings to original config *)
(set_limits (get_main config) let new_main = Whyconf.get_main t.config in
t.time_limit t.mem_limit t.max_running_processes) let time = Whyconf.timelimit new_main in
in let mem = Whyconf.memlimit new_main in
(* let _,alterns = Mprover.fold save_altern t.altern_provers (0,[]) in *) let nb = Whyconf.running_provers_max new_main in
(* let config = set_family config "alternative_prover" alterns in *) let config = set_main config (set_limits (get_main config) time mem nb) in
(* copy also provers section since it may have changed (the editor
can be set via the preferences dialog) *)
let config = set_provers config (get_provers t.config) in
(* copy also the possibly changed policies *)
let config = set_policies config (get_policies t.config) in let config = set_policies config (get_policies t.config) in
let ide = empty_section in let ide = empty_section in
let ide = set_int ide "window_height" t.window_height in let ide = set_int ide "window_height" t.window_height in
...@@ -262,17 +270,9 @@ let save_config t = ...@@ -262,17 +270,9 @@ let save_config t =
let ide = set_string ide "goal_color" t.goal_color in let ide = set_string ide "goal_color" t.goal_color in
let ide = set_string ide "error_color" t.error_color in let ide = set_string ide "error_color" t.error_color in
let ide = set_string ide "default_editor" t.default_editor in let ide = set_string ide "default_editor" t.default_editor in
(* let ide = set_string ~default:"ask" ide "replace_prover" *)
(* (match t.replace_prover with *)
(* | CRP_Ask -> "ask" *)
(* | CRP_Not_Obsolete -> "never not obsolete") in *)
let ide = set_stringl ide "hidden_prover" t.hidden_provers in let ide = set_stringl ide "hidden_prover" t.hidden_provers in
let config = set_section config "ide" ide in let config = set_section config "ide" ide in
(* TODO: store newly detected provers ! Whyconf.save_config config
(Mstr.fold save_prover t.provers Mstr.empty) in
save_config config
let read_config conf_file extra_files = let read_config conf_file extra_files =
try try
...@@ -494,17 +494,21 @@ let general_settings c (notebook:GPack.notebook) = ...@@ -494,17 +494,21 @@ let general_settings c (notebook:GPack.notebook) =
in in
(* timelimit ? *) (* timelimit ? *)
let main = Whyconf.get_main c.config in
let timelimit = ref (Whyconf.timelimit main) in
let memlimit = ref (Whyconf.memlimit main) in
let hb = GPack.hbox ~homogeneous:false ~packing:page#pack () in let hb = GPack.hbox ~homogeneous:false ~packing:page#pack () in
let _ = GMisc.label ~text:"Time limit: " let _ = GMisc.label ~text:"Time limit: "
~packing:(hb#pack ~expand:false) () in ~packing:(hb#pack ~expand:false) () in
let timelimit_spin = GEdit.spin_button ~digits:0 ~packing:hb#add () in let timelimit_spin = GEdit.spin_button ~digits:0 ~packing:hb#add () in
timelimit_spin#adjustment#set_bounds ~lower:2. ~upper:300. ~step_incr:1. (); timelimit_spin#adjustment#set_bounds ~lower:2. ~upper:300. ~step_incr:1. ();
timelimit_spin#adjustment#set_value (float_of_int c.time_limit); timelimit_spin#adjustment#set_value (float_of_int !timelimit);
let (_ : GtkSignal.id) = let (_ : GtkSignal.id) =
timelimit_spin#connect#value_changed ~callback: timelimit_spin#connect#value_changed ~callback:
(fun () -> c.time_limit <- timelimit_spin#value_as_int) (fun () -> timelimit := timelimit_spin#value_as_int)
in in
(* nb of processes ? *) (* nb of processes ? *)
let nb_processes = ref (Whyconf.running_provers_max main) in
let _ = GMisc.label ~text:"Nb of processes: " let _ = GMisc.label ~text:"Nb of processes: "
...@@ -512,10 +516,10 @@ let general_settings c (notebook:GPack.notebook) = ...@@ -512,10 +516,10 @@ let general_settings c (notebook:GPack.notebook) =
nb_processes_spin#adjustment#set_bounds nb_processes_spin#adjustment#set_bounds
~lower:1. ~upper:16. ~step_incr:1. (); ~lower:1. ~upper:16. ~step_incr:1. ();
nb_processes_spin#adjustment#set_value nb_processes_spin#adjustment#set_value
(float_of_int c.max_running_processes); (float_of_int !nb_processes);
nb_processes_spin#connect#value_changed ~callback: nb_processes_spin#connect#value_changed ~callback:
(fun () -> c.max_running_processes <- nb_processes_spin#value_as_int) (fun () -> nb_processes := nb_processes_spin#value_as_int)
in in
let display_options_frame = let display_options_frame =
GBin.frame ~label:"Display options" GBin.frame ~label:"Display options"
...@@ -611,8 +615,7 @@ let general_settings c (notebook:GPack.notebook) = ...@@ -611,8 +615,7 @@ let general_settings c (notebook:GPack.notebook) =
let _fillbox = let _fillbox =
GPack.vbox ~packing:(page#pack ~expand:true) () GPack.vbox ~packing:(page#pack ~expand:true) ()
in in
() timelimit, memlimit, nb_processes
(* Page "Provers" *) (* Page "Provers" *)
...@@ -742,8 +745,8 @@ let editors_page c (notebook:GPack.notebook) = ...@@ -742,8 +745,8 @@ let editors_page c (notebook:GPack.notebook) =
| "default" -> "" | "default" -> ""
| s -> s | s -> s
in in
Format.eprintf "prover %a : selected editor '%s'@." (* Format.eprintf "prover %a : selected editor '%s'@." *)
print_prover p data; (* print_prover p data; *)
let provers = Whyconf.get_provers c.config in let provers = Whyconf.get_provers c.config in
c.config <- c.config <-
Whyconf.set_provers c.config Whyconf.set_provers c.config
...@@ -764,7 +767,7 @@ let preferences (c : t) = ...@@ -764,7 +767,7 @@ let preferences (c : t) =
let vbox = dialog#vbox in let vbox = dialog#vbox in
let notebook = GPack.notebook ~packing:vbox#add () in let notebook = GPack.notebook ~packing:vbox#add () in
(** page "general settings" **) (** page "general settings" **)
general_settings c notebook; let t,m,n = general_settings c notebook in
(*** page "editors" **) (*** page "editors" **)
editors_page c notebook; editors_page c notebook;
(** page "Provers" **) (** page "Provers" **)
...@@ -788,7 +791,13 @@ let preferences (c : t) = ...@@ -788,7 +791,13 @@ let preferences (c : t) =
(** bottom button **) (** bottom button **)
dialog#add_button "Close" `CLOSE ; dialog#add_button "Close" `CLOSE ;
let ( _ : GWindow.Buttons.about) = dialog#run () in let ( _ : GWindow.Buttons.about) = dialog#run () in
eprintf "saving IDE config file@."; (* let config = set_main config *)
(* (set_limits (get_main config) *)
(* t.time_limit t.mem_limit t.max_running_processes) *)
(* in *)
c.config <- Whyconf.set_main c.config
(Whyconf.set_limits (Whyconf.get_main c.config) !t !m !n);
save_config (); save_config ();
dialog#destroy () dialog#destroy ()
...@@ -21,20 +21,12 @@ ...@@ -21,20 +21,12 @@
open Why3 open Why3
open Whyconf open Whyconf
(** Todo do something generic perhaps*)
(* type conf_replace_prover = *)
(* | CRP_Ask *)
(* | CRP_Not_Obsolete *)
type t = type t =
{ mutable window_width : int; { mutable window_width : int;
...@@ -414,7 +414,7 @@ let clear model = model#clear () ...@@ -414,7 +414,7 @@ let clear model = model#clear ()
let image_of_result ~obsolete result = let image_of_result ~obsolete result =
match result with match result with
| Session.Undone Session.Interrupted -> !image_undone | Session.Undone Session.Interrupted -> !image_undone
| Session.Undone Session.Unedited | Session.Undone Session.Unedited
| Session.Undone Session.JustEdited -> !image_unknown | Session.Undone Session.JustEdited -> !image_unknown
| Session.Undone Session.Scheduled -> !image_scheduled | Session.Undone Session.Scheduled -> !image_scheduled
| Session.Undone Session.Running -> !image_running | Session.Undone Session.Running -> !image_running
...@@ -536,7 +536,7 @@ let update_task_view a = ...@@ -536,7 +536,7 @@ let update_task_view a =
| S.Goal g -> | S.Goal g ->
if (Gconfig.config ()).intro_premises then if (Gconfig.config ()).intro_premises then
let trans = let trans =
Trans.lookup_transform intro_transformation (env_session()).S.env Trans.lookup_transform intro_transformation (env_session()).S.env
in in
display_task (Trans.apply trans (S.goal_task g)) display_task (Trans.apply trans (S.goal_task g))
else else
...@@ -587,7 +587,7 @@ module M = Session_scheduler.Make ...@@ -587,7 +587,7 @@ module M = Session_scheduler.Make
session_needs_saving := true; session_needs_saving := true;
let (_:bool) = goals_model#remove row#iter in () let (_:bool) = goals_model#remove row#iter in ()
let reset () = let reset () =
goals_model#clear () goals_model#clear ()
...@@ -765,7 +765,9 @@ let sched = ...@@ -765,7 +765,9 @@ let sched =
M.update_session ~allow_obsolete:true session gconfig.env M.update_session ~allow_obsolete:true session gconfig.env
gconfig.Gconfig.config gconfig.Gconfig.config
in in
let sched = M.init gconfig.max_running_processes in let sched = M.init (Whyconf.running_provers_max
(Whyconf.get_main gconfig.config))
in
dprintf debug "@]@\n[Info] Opening session: done@."; dprintf debug "@]@\n[Info] Opening session: done@.";
session_needs_saving := false; session_needs_saving := false;
current_env_session := Some env; current_env_session := Some env;
...@@ -804,6 +806,7 @@ let () = ...@@ -804,6 +806,7 @@ let () =
let prover_on_selected_goals pr = let prover_on_selected_goals pr =
let timelimit = Whyconf.timelimit (Whyconf.get_main gconfig.config) in
List.iter List.iter
(fun row -> (fun row ->
try try
...@@ -811,7 +814,7 @@ let prover_on_selected_goals pr = ...@@ -811,7 +814,7 @@ let prover_on_selected_goals pr =
M.run_prover M.run_prover
(env_session()) sched (env_session()) sched
~context_unproved_goals_only:!context_unproved_goals_only ~context_unproved_goals_only:!context_unproved_goals_only
~timelimit:gconfig.time_limit ~timelimit
pr a pr a
with e -> with e ->
eprintf "@[Exception raised while running a prover:@ %a@.@]" eprintf "@[Exception raised while running a prover:@ %a@.@]"
...@@ -938,18 +941,20 @@ let (_ : GMenu.image_menu_item) = ...@@ -938,18 +941,20 @@ let (_ : GMenu.image_menu_item) =
begin begin
match !current_env_session with match !current_env_session with
| None -> () | None -> ()
| Some _e -> | Some e ->
(* Can't do that since field .whyconf is not mutable *) Session.update_env_session_config e gconfig.config;
(* e.Session.whyconf <- gconfig.config *) Session.unload_provers e
end; end;
!refresh_provers (); !refresh_provers ();
Mprover.iter Mprover.iter
(fun p pi -> (fun p pi ->
Format.eprintf "editor for %a : %s@." Whyconf.print_prover p Format.eprintf "editor for %a : %s@." Whyconf.print_prover p
pi.editor) pi.editor)
(Whyconf.get_provers gconfig.config); (Whyconf.get_provers gconfig.config);
M.set_maximum_running_proofs gconfig.max_running_processes sched) *)
let nb = Whyconf.running_provers_max (Whyconf.get_main gconfig.config) in
M.set_maximum_running_proofs nb sched)
let add_refresh_provers f _msg = let add_refresh_provers f _msg =
...@@ -975,7 +980,6 @@ let save_session () = ...@@ -975,7 +980,6 @@ let save_session () =
let exit_function ?(destroy=false) () = let exit_function ?(destroy=false) () =
if not !session_needs_saving then GMain.quit () else if not !session_needs_saving then GMain.quit () else
match (Gconfig.config ()).saving_policy with match (Gconfig.config ()).saving_policy with
...@@ -1023,7 +1027,7 @@ let enlarge_font () = ...@@ -1023,7 +1027,7 @@ let enlarge_font () =
let reduce_font () = let reduce_font () =
decr font_size; decr font_size;
change_font (); change_font ();
GConfig.save () GConfig.save ()
...@@ -1511,8 +1515,18 @@ let edit_selected_row r = ...@@ -1511,8 +1515,18 @@ let edit_selected_row r =
| S.File _file -> | S.File _file ->
| S.Proof_attempt a -> | S.Proof_attempt a ->
M.edit_proof let e = env_session () in
(env_session()) sched ~default_editor:gconfig.default_editor a (*
let c = e.Session.whyconf in
Format.eprintf
0 time p.editor;
M.edit_proof e sched ~default_editor:gconfig.default_editor a
| S.Transf _ -> () | S.Transf _ -> ()
let edit_current_proof () = let edit_current_proof () =
...@@ -1695,7 +1709,7 @@ let () = ...@@ -1695,7 +1709,7 @@ let () =
(* to be run when a row in the tree view is selected *) (* to be run when a row in the tree view is selected *)
let select_row r = let select_row r =
let ind = goals_model#get ~row:r#iter ~column:index_column in let ind = goals_model#get ~row:r#iter ~column:index_column in
...@@ -119,10 +119,11 @@ type loaded_provers = loaded_prover option PHprover.t ...@@ -119,10 +119,11 @@ type loaded_provers = loaded_prover option PHprover.t
type 'a env_session = type 'a env_session =
{ env : Env.env; { env : Env.env;
whyconf : Whyconf.config; mutable whyconf : Whyconf.config;
loaded_provers : loaded_provers; loaded_provers : loaded_provers;
session : 'a session} session : 'a session}
let update_env_session_config e c = e.whyconf <- c
(** Iterators *) (** Iterators *)
...@@ -1138,6 +1139,8 @@ let load_prover eS prover = ...@@ -1138,6 +1139,8 @@ let load_prover eS prover =
PHprover.add eS.loaded_provers prover r; PHprover.add eS.loaded_provers prover r;
r r
let unload_provers eS = PHprover.clear eS.loaded_provers
let () = Exn_printer.register let () = Exn_printer.register
(fun fmt exn -> (fun fmt exn ->
match exn with match exn with
...@@ -173,13 +173,20 @@ type loaded_provers = loaded_prover option PHprover.t ...@@ -173,13 +173,20 @@ type loaded_provers = loaded_prover option PHprover.t
type 'a env_session = private type 'a env_session = private
val update_env_session_config : 'a env_session -> Whyconf.config -> unit
(** updates the configuration *)
val load_prover : 'a env_session -> Whyconf.prover -> loaded_prover option val load_prover : 'a env_session -> Whyconf.prover -> loaded_prover option
(** load a prover *) (** load a prover *)
val unload_provers : 'a env_session -> unit
(** forces unloading of all provers,
to force reading again the configuration *)
(** {2 Update session} *) (** {2 Update session} *)
type 'key keygen = ?parent:'key -> unit -> 'key type 'key keygen = ?parent:'key -> unit -> 'key
