Commit e7b1ea28 authored by Raphael Rieu-Helft's avatar Raphael Rieu-Helft
Add GMP extraction and tests to the bench
parent 12633d91
...@@ -181,6 +181,45 @@ extract_and_run () { ...@@ -181,6 +181,45 @@ extract_and_run () {
fi fi
extract_and_test_wmp () {
dir="examples/in_progress/multiprecision"
shift
printf " $dir... "
printf "clean... "
if BENCH=yes make -C $dir clean > /dev/null; then
printf "extract... "
if BENCH=yes make -C $dir extract > /dev/null; then
printf "compile... "
if BENCH=yes make -C $dir bench-tests > /dev/null; then
printf "execute... "
if $dir/build/bench-tests > /dev/null; then
echo "ok"
else
echo "execution failed!"
echo $dir/main.opt
$dir/main.opt
exit 1
fi
else
echo "compilation failed!"
echo BENCH=yes make -C $dir
exit 1
fi
else
echo "extract failed!"
echo BENCH=yes make -C $dir extract
exit 1
fi
else
echo "clean failed!"
echo BENCH=yes make -C $dir clean
exit 1
fi
list_stuff () { list_stuff () {
pgm="bin/why3$suffix" pgm="bin/why3$suffix"
printf ' %s ' "$1" printf ' %s ' "$1"
...@@ -305,6 +344,10 @@ extract_and_run examples/defunctionalization defunctionalization.ml ...@@ -305,6 +344,10 @@ extract_and_run examples/defunctionalization defunctionalization.ml
extract_and_run examples/sudoku sudoku.ml 2,0,9,0,0,0,0,1,0,0,0,0,0,6,0,0,0,0,0,5,3,8,0,2,7,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,7,5,0,0,3,0,4,1,2,0,8,9,0,0,0,0,4,0,9,0,0,2,0,8,0,0,0,0,1,0,0,5,0,0,0,0,0,0,0,7,6 extract_and_run examples/sudoku sudoku.ml 2,0,9,0,0,0,0,1,0,0,0,0,0,6,0,0,0,0,0,5,3,8,0,2,7,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,7,5,0,0,3,0,4,1,2,0,8,9,0,0,0,0,4,0,9,0,0,2,0,8,0,0,0,0,1,0,0,5,0,0,0,0,0,0,0,7,6
echo "" echo ""
echo "=== Checking extraction to C ==="
echo ""
echo "=== Checking --list-* ===" echo "=== Checking --list-* ==="
list_stuff --list-transforms list_stuff --list-transforms
list_stuff --list-printers list_stuff --list-printers
all: why3 extract all: why3 extract
clean:
rm -rf build
why3: why3:
make -C ../../.. make -C ../../..
...@@ -13,6 +16,9 @@ tests: extract check-gmp ...@@ -13,6 +16,9 @@ tests: extract check-gmp
./build/tests ./build/tests
./build/minitests ./build/minitests
bench-tests: extract
gcc -O2 -Wall -g -std=gnu99 tests.c build/N.c -Iinclude -fomit-frame-pointer -fno-tree-vectorize -lgmp -o build/bench-tests
build/why3%bench: extract check-gmp build/why3%bench: extract check-gmp
gcc -O3 -Wall -g -std=gnu99 -DTEST_WHY3 -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c build/N.c -I$(GMP_DIR) -L$(GMP_LIB) -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -lgmp -o $@ gcc -O3 -Wall -g -std=gnu99 -DTEST_WHY3 -DTEST_`echo $* | tr [:lower:] [:upper:]` tests.c build/N.c -I$(GMP_DIR) -L$(GMP_LIB) -fomit-frame-pointer -mtune=haswell -march=haswell -fno-tree-vectorize -lgmp -o $@
# Ignore everything in this directory
# Except this file
!.gitignore
This diff is collapsed.
/* This file is automatically generated by gen-fac.c */
#if GMP_NUMB_BITS != 64
Error , error this data is for 64 GMP_NUMB_BITS only
#endif
/* This table is 0!,1!,2!,3!,...,n! where n! has <= GMP_NUMB_BITS bits */
#define ONE_LIMB_FACTORIAL_TABLE CNST_LIMB(0x1),CNST_LIMB(0x1),CNST_LIMB(0x2),CNST_LIMB(0x6),CNST_LIMB(0x18),CNST_LIMB(0x78),CNST_LIMB(0x2d0),CNST_LIMB(0x13b0),CNST_LIMB(0x9d80),CNST_LIMB(0x58980),CNST_LIMB(0x375f00),CNST_LIMB(0x2611500),CNST_LIMB(0x1c8cfc00),CNST_LIMB(0x17328cc00),CNST_LIMB(0x144c3b2800),CNST_LIMB(0x13077775800),CNST_LIMB(0x130777758000),CNST_LIMB(0x1437eeecd8000),CNST_LIMB(0x16beecca730000),CNST_LIMB(0x1b02b9306890000),CNST_LIMB(0x21c3677c82b40000)
/* This table is 0!,1!,2!/2,3!/2,...,n!/2^sn where n!/2^sn is an */
/* odd integer for each n, and n!/2^sn has <= GMP_NUMB_BITS bits */
#define ONE_LIMB_ODD_FACTORIAL_TABLE CNST_LIMB(0x1),CNST_LIMB(0x1),CNST_LIMB(0x1),CNST_LIMB(0x3),CNST_LIMB(0x3),CNST_LIMB(0xf),CNST_LIMB(0x2d),CNST_LIMB(0x13b),CNST_LIMB(0x13b),CNST_LIMB(0xb13),CNST_LIMB(0x375f),CNST_LIMB(0x26115),CNST_LIMB(0x7233f),CNST_LIMB(0x5cca33),CNST_LIMB(0x2898765),CNST_LIMB(0x260eeeeb),CNST_LIMB(0x260eeeeb),CNST_LIMB(0x286fddd9b),CNST_LIMB(0x16beecca73),CNST_LIMB(0x1b02b930689),CNST_LIMB(0x870d9df20ad),CNST_LIMB(0xb141df4dae31),CNST_LIMB(0x79dd498567c1b),CNST_LIMB(0xaf2e19afc5266d),CNST_LIMB(0x20d8a4d0f4f7347),CNST_LIMB(0x335281867ec241ef)
#define ODD_FACTORIAL_TABLE_MAX CNST_LIMB(0x335281867ec241ef)
#define ODD_FACTORIAL_TABLE_LIMIT (25)
/* Previous table, continued, values modulo 2^GMP_NUMB_BITS */
#define ONE_LIMB_ODD_FACTORIAL_EXTTABLE CNST_LIMB(0x9b3093d46fdd5923),CNST_LIMB(0x5e1f9767cc5866b1),CNST_LIMB(0x92dd23d6966aced7),CNST_LIMB(0xa30d0f4f0a196e5b),CNST_LIMB(0x8dc3e5a1977d7755),CNST_LIMB(0x2ab8ce915831734b),CNST_LIMB(0x2ab8ce915831734b),CNST_LIMB(0x81d2a0bc5e5fdcab),CNST_LIMB(0x9efcac82445da75b),CNST_LIMB(0xbc8b95cf58cde171),CNST_LIMB(0xa0e8444a1f3cecf9),CNST_LIMB(0x4191deb683ce3ffd),CNST_LIMB(0xddd3878bc84ebfc7),CNST_LIMB(0xcb39a64b83ff3751),CNST_LIMB(0xf8203f7993fc1495),CNST_LIMB(0xbd2a2a78b35f4bdd),CNST_LIMB(0x84757be6b6d13921),CNST_LIMB(0x3fbbcfc0b524988b),CNST_LIMB(0xbd11ed47c8928df9),CNST_LIMB(0x3c26b59e41c2f4c5),CNST_LIMB(0x677a5137e883fdb3),CNST_LIMB(0xff74e943b03b93dd),CNST_LIMB(0xfe5ebbcb10b2bb97),CNST_LIMB(0xb021f1de3235e7e7),CNST_LIMB(0x33509eb2e743a58f),CNST_LIMB(0x390f9da41279fb7d),CNST_LIMB(0xe5cb0154f031c559),CNST_LIMB(0x93074695ba4ddb6d),CNST_LIMB(0x81c471caa636247f),CNST_LIMB(0xe1347289b5a1d749),CNST_LIMB(0x286f21c3f76ce2ff),CNST_LIMB(0xbe84a2173e8ac7),CNST_LIMB(0x1595065ca215b88b),CNST_LIMB(0xf95877595b018809),CNST_LIMB(0x9c2efe3c5516f887),CNST_LIMB(0x373294604679382b),CNST_LIMB(0xaf1ff7a888adcd35),CNST_LIMB(0x18ddf279a2c5800b),CNST_LIMB(0x18ddf279a2c5800b),CNST_LIMB(0x505a90e2542582cb),CNST_LIMB(0x5bacad2cd8d5dc2b),CNST_LIMB(0xfe3152bcbff89f41)
#define ODD_FACTORIAL_EXTTABLE_LIMIT (67)
/* This table is 1!!,3!!,...,(2n+1)!! where (2n+1)!! has <= GMP_NUMB_BITS bits */
#define ONE_LIMB_ODD_DOUBLEFACTORIAL_TABLE CNST_LIMB(0x1),CNST_LIMB(0x3),CNST_LIMB(0xf),CNST_LIMB(0x69),CNST_LIMB(0x3b1),CNST_LIMB(0x289b),CNST_LIMB(0x20fdf),CNST_LIMB(0x1eee11),CNST_LIMB(0x20dcf21),CNST_LIMB(0x27065f73),CNST_LIMB(0x33385d46f),CNST_LIMB(0x49a10615f9),CNST_LIMB(0x730b9982551),CNST_LIMB(0xc223930bef8b),CNST_LIMB(0x15fe07a85a22bf),CNST_LIMB(0x2a9c2ed62ea3521),CNST_LIMB(0x57e22099c030d941)
#define ODD_DOUBLEFACTORIAL_TABLE_MAX CNST_LIMB(0x57e22099c030d941)
#define ODD_DOUBLEFACTORIAL_TABLE_LIMIT (33)
/* This table x_1, x_2,... contains values s.t. x_n^n has <= GMP_NUMB_BITS bits */
#define NTH_ROOT_NUMB_MASK_TABLE (GMP_NUMB_MASK),CNST_LIMB(0xffffffff),CNST_LIMB(0x285145),CNST_LIMB(0xffff),CNST_LIMB(0x1bdb),CNST_LIMB(0x659),CNST_LIMB(0x235),CNST_LIMB(0xff)
/* This table contains inverses of odd factorials, modulo 2^GMP_NUMB_BITS */
/* It begins with (2!/2)^-1=1 */
#define ONE_LIMB_ODD_FACTORIAL_INVERSES_TABLE CNST_LIMB(0x1),CNST_LIMB(0xaaaaaaaaaaaaaaab),CNST_LIMB(0xaaaaaaaaaaaaaaab),CNST_LIMB(0xeeeeeeeeeeeeeeef),CNST_LIMB(0x4fa4fa4fa4fa4fa5),CNST_LIMB(0x2ff2ff2ff2ff2ff3),CNST_LIMB(0x2ff2ff2ff2ff2ff3),CNST_LIMB(0x938cc70553e3771b),CNST_LIMB(0xb71c27cddd93e49f),CNST_LIMB(0xb38e3229fcdee63d),CNST_LIMB(0xe684bb63544a4cbf),CNST_LIMB(0xc2f684917ca340fb),CNST_LIMB(0xf747c9cba417526d),CNST_LIMB(0xbb26eb51d7bd49c3),CNST_LIMB(0xbb26eb51d7bd49c3),CNST_LIMB(0xb0a7efb985294093),CNST_LIMB(0xbe4b8c69f259eabb),CNST_LIMB(0x6854d17ed6dc4fb9),CNST_LIMB(0xe1aa904c915f4325),CNST_LIMB(0x3b8206df131cead1),CNST_LIMB(0x79c6009fea76fe13),CNST_LIMB(0xd8c5d381633cd365),CNST_LIMB(0x4841f12b21144677),CNST_LIMB(0x4a91ff68200b0d0f),CNST_LIMB(0x8f9513a58c4f9e8b),CNST_LIMB(0x2b3e690621a42251),CNST_LIMB(0x4f520f00e03c04e7),CNST_LIMB(0x2edf84ee600211d3),CNST_LIMB(0xadcaa2764aaacdfd),CNST_LIMB(0x161f4f9033f4fe63),CNST_LIMB(0x161f4f9033f4fe63),CNST_LIMB(0xbada2932ea4d3e03),CNST_LIMB(0xcec189f3efaa30d3),CNST_LIMB(0xf7475bb68330bf91),CNST_LIMB(0x37eb7bf7d5b01549),CNST_LIMB(0x46b35660a4e91555),CNST_LIMB(0xa567c12d81f151f7),CNST_LIMB(0x4c724007bb2071b1),CNST_LIMB(0xf4a0cce58a016bd),CNST_LIMB(0xfa21068e66106475),CNST_LIMB(0x244ab72b5a318ae1),CNST_LIMB(0x366ce67e080d0f23),CNST_LIMB(0xd666fdae5dd2a449),CNST_LIMB(0xd740ddd0acc06a0d),CNST_LIMB(0xb050bbbb28e6f97b),CNST_LIMB(0x70b003fe890a5c75),CNST_LIMB(0xd03aabff83037427),CNST_LIMB(0x13ec4ca72c783bd7),CNST_LIMB(0x90282c06afdbd96f),CNST_LIMB(0x4414ddb9db4a95d5),CNST_LIMB(0xa2c68735ae6832e9),CNST_LIMB(0xbf72d71455676665),CNST_LIMB(0xa8469fab6b759b7f),CNST_LIMB(0xc1e55b56e606caf9),CNST_LIMB(0x40455630fc4a1cff),CNST_LIMB(0x120a7b0046d16f7),CNST_LIMB(0xa7c3553b08faef23),CNST_LIMB(0x9f0bfd1b08d48639),CNST_LIMB(0xa433ffce9a304d37),CNST_LIMB(0xa22ad1d53915c683),CNST_LIMB(0xcb6cbc723ba5dd1d),CNST_LIMB(0x547fb1b8ab9d0ba3),CNST_LIMB(0x547fb1b8ab9d0ba3),CNST_LIMB(0x8f15a826498852e3)
/* This table contains 2n-popc(2n) for small n */
/* It begins with 2-1=1 (n=1) */
#define TABLE_2N_MINUS_POPC_2N 1,3,4,7,8,10,11,15,16,18,19,22,23,25,26,31,32,34,35,38,39,41,42,46,47,49,50,53,54,56,57,63,64,66,67,70,71,73,74,78
#define TABLE_LIMIT_2N_MINUS_POPC_2N 81
#define ODD_CENTRAL_BINOMIAL_OFFSET (13)
/* This table contains binomial(2k,k)/2^t */
/* It begins with ODD_CENTRAL_BINOMIAL_TABLE_MIN */
#define ONE_LIMB_ODD_CENTRAL_BINOMIAL_TABLE CNST_LIMB(0x13d66b),CNST_LIMB(0x4c842f),CNST_LIMB(0x93ee7d),CNST_LIMB(0x11e9e123),CNST_LIMB(0x22c60053),CNST_LIMB(0x873ae4d1),CNST_LIMB(0x10757bd97),CNST_LIMB(0x80612c6cd),CNST_LIMB(0xfaa556bc1),CNST_LIMB(0x3d3cc24821),CNST_LIMB(0x77cfeb6bbb),CNST_LIMB(0x7550ebd97c7),CNST_LIMB(0xe5f08695caf),CNST_LIMB(0x386120ffce11),CNST_LIMB(0x6eabb28dd6df),CNST_LIMB(0x3658e31c82a8f),CNST_LIMB(0x6ad2050312783),CNST_LIMB(0x1a42902a5af0bf),CNST_LIMB(0x33ac44f881661d),CNST_LIMB(0xcb764f927d82123),CNST_LIMB(0x190c23fa46b93983),CNST_LIMB(0x62b7609e25caf1b9),CNST_LIMB(0xc29cb72925ef2cff)
#define ODD_CENTRAL_BINOMIAL_TABLE_LIMIT (35)
/* This table contains the inverses of elements in the previous table. */
#define ONE_LIMB_ODD_CENTRAL_BINOMIAL_INVERSE_TABLE CNST_LIMB(0x61e5bd199bb12643),CNST_LIMB(0x78321494dc8342cf),CNST_LIMB(0x4fd348704ebf7ad5),CNST_LIMB(0x7e722ba086ab568b),CNST_LIMB(0xa5fcc124265843db),CNST_LIMB(0x89c4a6b18633f431),CNST_LIMB(0x4daa2c15f8ce9227),CNST_LIMB(0x801c618ca9be9605),CNST_LIMB(0x32dc192f948a441),CNST_LIMB(0xd02b90c2bf3be1),CNST_LIMB(0xd897e8c1749aa173),CNST_LIMB(0x54a234fc01fef9f7),CNST_LIMB(0x83ff2ab4d1ff7a4f),CNST_LIMB(0xa427f1c9b304e2f1),CNST_LIMB(0x9c14595d1793651f),CNST_LIMB(0x883a71c607a7b46f),CNST_LIMB(0xd089863c54bc9f2b),CNST_LIMB(0x9022f6bce5d07f3f),CNST_LIMB(0xbec207e218768c35),CNST_LIMB(0x9d70cb4cbb4f168b),CNST_LIMB(0x3c3d3403828a9d2b),CNST_LIMB(0x7672df58c56bc489),CNST_LIMB(0x1e66ca55d727d2ff)
/* This table contains the values t in the formula binomial(2k,k)/2^t */
#define CENTRAL_BINOMIAL_2FAC_TABLE 3,3,4,1,2,2,3,2,3,3,4,2,3,3,4,3,4,4,5,1,2,2,3
/* This file generated by gen-fib.c - DO NOT EDIT. */
Error, error, this data is for 64 bits
#endif
#define FIB_TABLE_LIMIT 93
#define FIB_TABLE_LUCNUM_LIMIT 92
/* Generic C gmp-mparam.h -- Compiler/machine parameter header file.
Copyright 1991, 1993, 1994, 2000 Free Software Foundation, Inc.
This file is part of the GNU MP Library.
The GNU MP Library is free software; you can redistribute it and/or modify
it under the terms of either:
* the GNU Lesser General Public License as published by the Free
Software Foundation; either version 3 of the License, or (at your
option) any later version.
* the GNU General Public License as published by the Free Software
Foundation; either version 2 of the License, or (at your option) any
later version.
or both in parallel, as here.
The GNU MP Library is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received copies of the GNU General Public License and the
GNU Lesser General Public License along with the GNU MP Library. If not,
see https://www.gnu.org/licenses/. */
/* Values for GMP_LIMB_BITS etc will be determined by ./configure and put
in config.h. */
/* This file generated by gen-bases.c - DO NOT EDIT. */
#endif
/* mp_bases[10] data, as literal values */
#define MP_BASES_CHARS_PER_LIMB_10 19
#define MP_BASES_BIG_BASE_10 CNST_LIMB(0x8ac7230489e80000)
#define MP_BASES_BIG_BASE_INVERTED_10 CNST_LIMB(0xd83c94fb6d2ac34a)
#define MP_BASES_NORMALIZATION_STEPS_10 0
