Hillel challenge: solution for the third problem
parent 5d1af82a
(** {1 Hillel challenge} (** {1 Hillel challenge}
See https://www.hillelwayne.com/post/theorem-prover-showdown/ See https://www.hillelwayne.com/post/theorem-prover-showdown/
The challenge proposed by Hillel Wayne was to provide purely functional
implementations and proofs for three imperative programs he proved using
Dafny (as an attempt to understand whether the proof of FP code is easier
than the proof of imperative programs).
Below are imperative implementations and proofs for the three Hillel
challenges. Thus it is not really a response to the challenge, but rather
an alternative to the Dafny proofs.
Author: Jean-Christophe Filliâtre (CNRS)
(** {2 Challenge 1: Lefpad}
Takes a padding character, a string, and a total length, returns the
string padded to that length with that character. If length is less
than the length of the string, does nothing.
module Leftpad module Leftpad
...@@ -26,6 +43,14 @@ module Leftpad ...@@ -26,6 +43,14 @@ module Leftpad
end end
(** {2 Challenge 2: Unique}
Takes a sequence of integers, returns the unique elements of that
list. There is no requirement on the ordering of the returned
values.
module Unique module Unique
use import int.Int use import int.Int
...@@ -60,3 +85,55 @@ module Unique ...@@ -60,3 +85,55 @@ module Unique
Array.sub res 0 !len Array.sub res 0 !len
end end
(** {2 Challenge 3: Fulcrum}
Given a sequence of integers, returns the index `i` that minimizes
`|sum(seq[..i]) - sum(seq[i..])|`. Does this in O(n) time and O(n)
memory.
We do it in O(n) time and O(1) space. A first loop computes the sum
of the array. A second scans the array from left to right, while
maintaining the left and right sums in two variables. Updating these
variables is simply of matter of adding `a[i]` to `left` and subtracting
`a[i]` to `right`.
module Fulcrum
use import int.Int
use import int.Abs
use import ref.Refint
use import array.Array
use import array.ArraySum
function diff (a: array int) (i: int) : int =
abs (sum a 0 i - sum a i (length a))
let fulcrum (a: array int) : int
ensures { 0 <= result <= length a }
ensures { forall i. 0 <= i <= length a -> diff a result <= diff a i }
= let n = length a in
let right = ref 0 in
for i = 0 to n - 1 do
invariant { !right = sum a 0 i }
right += a[i]
done;
let left = ref 0 in
let besti = ref 0 in
let bestd = ref (abs !right) in
invariant { !left = sum a 0 i }
invariant { !right = sum a i n }
invariant { 0 <= !besti <= i }
invariant { !bestd = diff a !besti }
invariant { forall j. 0 <= j <= i -> !bestd <= diff a j }
left += a[i];
right -= a[i];
let d = abs (!left - !right) in
if d < !bestd then begin bestd := d; besti := i+1 end
done;
!besti
...@@ -122,5 +122,83 @@ ...@@ -122,5 +122,83 @@
</transf> </transf>
</goal> </goal>
</theory> </theory>
<theory name="Fulcrum" proved="true">
<goal name="VC fulcrum" expl="VC for fulcrum" proved="true">
<transf name="split_vc" proved="true" >
<goal name="VC fulcrum.0" expl="loop invariant init" proved="true">
<proof prover="0"><result status="valid" time="0.03"/></proof>
</goal>
<goal name="VC fulcrum.1" expl="index in array bounds" proved="true">
<proof prover="0"><result status="valid" time="0.01"/></proof>
</goal>
<goal name="VC fulcrum.2" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.3" expl="loop invariant init" proved="true">
<proof prover="0"><result status="valid" time="0.02"/></proof>
</goal>
<goal name="VC fulcrum.4" expl="loop invariant init" proved="true">
</goal>
<goal name="VC fulcrum.5" expl="loop invariant init" proved="true">
</goal>
<goal name="VC fulcrum.6" expl="loop invariant init" proved="true">
</goal>
<goal name="VC fulcrum.7" expl="loop invariant init" proved="true">
</goal>
<goal name="VC fulcrum.8" expl="index in array bounds" proved="true">
</goal>
<goal name="VC fulcrum.9" expl="index in array bounds" proved="true">
</goal>
<goal name="VC fulcrum.10" expl="loop invariant preservation" proved="true">
<proof prover="0"><result status="valid" time="0.04"/></proof>
</goal>
<goal name="VC fulcrum.11" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.12" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.13" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.14" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.15" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.16" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.17" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.18" expl="loop invariant preservation" proved="true">
</goal>
<goal name="VC fulcrum.19" expl="loop invariant preservation" proved="true">
<proof prover="0"><result status="valid" time="0.37"/></proof>
</goal>
<goal name="VC fulcrum.20" expl="postcondition" proved="true">
</goal>
<goal name="VC fulcrum.21" expl="postcondition" proved="true">
</goal>
<goal name="VC fulcrum.22" expl="out of loop bounds" proved="true">
</goal>
<goal name="VC fulcrum.23" expl="out of loop bounds" proved="true">
</goal>
</transf>
</goal>
</theory>
</file> </file>
</why3session> </why3session>
