Commit db60323e authored by Mário Pereira's avatar Mário Pereira
Schorr-Waite typechecks
parent 515bea04
...@@ -46,6 +46,8 @@ module SchorrWaite ...@@ -46,6 +46,8 @@ module SchorrWaite
val c: ref (map loc bool) val c: ref (map loc bool)
val left: ref (map loc loc) val left: ref (map loc loc)
val right: ref (map loc loc) val right: ref (map loc loc)
val (=) (x y : loc) : bool ensures { result <-> x = y }
val (<<>>) (p1 p2: loc) : bool ensures { result <-> p1 <> p2 }
val get_left (p: loc) : loc val get_left (p: loc) : loc
requires { p <> null } requires { p <> null }
...@@ -104,7 +106,7 @@ module SchorrWaite ...@@ -104,7 +106,7 @@ module SchorrWaite
predicate not_in_stack (n: loc) (s: stacknodes) = predicate not_in_stack (n: loc) (s: stacknodes) =
forall i: int. 0 <= i < Seq.length s -> n <> Seq.get s i forall i: int. 0 <= i < Seq.length s -> n <> Seq.get s i
let tl_stackNodes (stack: stacknodes) : stacknodes let ghost tl_stackNodes (stack: stacknodes) : stacknodes
requires { Seq.length stack > 0 } requires { Seq.length stack > 0 }
ensures { result = stack[1 .. ] } ensures { result = stack[1 .. ] }
ensures { forall n. not_in_stack n stack -> not_in_stack n result } ensures { forall n. not_in_stack n stack -> not_in_stack n result }
...@@ -190,15 +192,14 @@ module SchorrWaite ...@@ -190,15 +192,14 @@ module SchorrWaite
ensures { !m[root] } ensures { !m[root] }
ensures { forall n : loc. S.mem n graph -> !m[n] -> ensures { forall n : loc. S.mem n graph -> !m[n] ->
(forall ch : loc. edge n ch !left !right -> ch <> null -> !m[ch]) } (forall ch : loc. edge n ch !left !right -> ch <> null -> !m[ch]) }
= 'Init: = let t = ref root in
let t = ref root in
let p = ref null in let p = ref null in
let ghost stackNodes = ref Seq.empty in let ghost stackNodes = ref Seq.empty in
let ghost pth = ref Nil in let ghost pth = ref Nil in
ghost set_path_from_root !t !pth; ghost set_path_from_root !t !pth;
let ghost unmarked_nodes = ref graph in let ghost unmarked_nodes = ref graph in
let ghost c_false_nodes = ref graph in let ghost c_false_nodes = ref graph in
while !p <> null || (!t <> null && not get_m !t) do while !p <<>> null || (!t <<>> null && not get_m !t) do
invariant { forall n. mem n graph -> not_in_stack n !stackNodes \/ invariant { forall n. mem n graph -> not_in_stack n !stackNodes \/
exists i : int. Seq.get !stackNodes i = n } exists i : int. Seq.get !stackNodes i = n }
invariant { not_in_stack null !stackNodes } invariant { not_in_stack null !stackNodes }
...@@ -215,15 +216,15 @@ module SchorrWaite ...@@ -215,15 +216,15 @@ module SchorrWaite
invariant { forall i. 0 <= i < Seq.length !stackNodes - 1 -> invariant { forall i. 0 <= i < Seq.length !stackNodes - 1 ->
let p1 = Seq.get !stackNodes i in let p1 = Seq.get !stackNodes i in
let p2 = Seq.get !stackNodes (i+1) in let p2 = Seq.get !stackNodes (i+1) in
(!c[p2] -> (at !left 'Init)[p2] = !left[p2] /\ (!c[p2] -> (old !left )[p2] = !left[p2] /\
(at !right 'Init)[p2] = p1) /\ (old !right )[p2] = p1) /\
(not !c[p2] -> (at !left 'Init)[p2] = p1 /\ (not !c[p2] -> (old !left )[p2] = p1 /\
(at !right 'Init)[p2] = !right[p2]) } (old !right )[p2] = !right[p2]) }
invariant { !path_from_root[root] = Nil } invariant { !path_from_root[root] = Nil }
invariant { forall n : loc. S.mem n graph -> invariant { forall n : loc. S.mem n graph ->
not_in_stack n !stackNodes -> not_in_stack n !stackNodes ->
!left[n] = (at !left 'Init)[n] /\ !left[n] = (old !left )[n] /\
!right[n] = (at !right 'Init)[n] } !right[n] = (old !right )[n] }
(* something like Leino's line 74; this is useful to prove that (* something like Leino's line 74; this is useful to prove that
* the stack is empty iff p = null *) * the stack is empty iff p = null *)
invariant { Seq.length !stackNodes <> 0 -> invariant { Seq.length !stackNodes <> 0 ->
...@@ -245,30 +246,30 @@ module SchorrWaite ...@@ -245,30 +246,30 @@ module SchorrWaite
(* something like Leino's line 68 *) (* something like Leino's line 68 *)
invariant { forall i. 0 <= i < Seq.length !stackNodes -> invariant { forall i. 0 <= i < Seq.length !stackNodes ->
let n = Seq.get !stackNodes i in let n = Seq.get !stackNodes i in
if !c[n] then !left[n] = (at !left 'Init)[n] if !c[n] then !left[n] = (old !left )[n]
else !right[n] = (at !right 'Init)[n] } else !right[n] = (old !right )[n] }
(* lines 80-81 from Leino's paper *) (* lines 80-81 from Leino's paper *)
if !c[!p] then (at !right 'Init)[!p] = !t if !c[!p] then (old !right )[!p] = !t
else (at !left 'Init)[!p] = !t } else (old !left )[!p] = !t }
(* lines 78-79 from Leino's paper *) (* lines 78-79 from Leino's paper *)
invariant { forall k : int. 0 < k < Seq.length !stackNodes -> invariant { forall k : int. 0 < k < Seq.length !stackNodes ->
let n = Seq.get !stackNodes k in let n = Seq.get !stackNodes k in
if !c[n] if !c[n]
then Seq.get !stackNodes (k - 1) = (at !right 'Init)[n] then Seq.get !stackNodes (k - 1) = (old !right )[n]
else Seq.get !stackNodes (k - 1) = (at !left 'Init)[n] } else Seq.get !stackNodes (k - 1) = (old !left )[n] }
(* line 70 from Leino's paper *) (* line 70 from Leino's paper *)
invariant { !p <> null -> invariant { !p <> null ->
path (at !left 'Init) (at !right 'Init) root !p !pth } path (old !left ) (old !right ) root !p !pth }
(* line 72 from Leino's paper *) (* line 72 from Leino's paper *)
invariant { forall n : loc. S.mem n graph -> !m[n] -> invariant { forall n : loc. S.mem n graph -> !m[n] ->
reachable (at !left 'Init) (at !right 'Init) root n } reachable (old !left ) (old !right ) root n }
invariant { !p = null -> !t = root } invariant { !p = null -> !t = root }
invariant { forall n : loc, pth : list loc. invariant { forall n : loc, pth : list loc.
S.mem n graph -> !m[n] -> S.mem n graph -> !m[n] ->
pth = !path_from_root[n] -> pth = !path_from_root[n] ->
path (at !left 'Init) (at !right 'Init) root n pth } path (old !left ) (old !right ) root n pth }
(* lines 61-62 from Leinos' paper *) (* lines 61-62 from Leinos' paper *)
invariant { forall n : loc. S.mem n graph -> n <> null -> !m[n] -> invariant { forall n : loc. S.mem n graph -> n <> null -> !m[n] ->
...@@ -310,7 +311,7 @@ module SchorrWaite ...@@ -310,7 +311,7 @@ module SchorrWaite
ghost if !p <> root then pth := !pth ++ (Cons q Nil) else pth := Nil; ghost if !p <> root then pth := !pth ++ (Cons q Nil) else pth := Nil;
ghost set_path_from_root !p !pth; ghost set_path_from_root !p !pth;
assert { !p = Seq.get !stackNodes 0 }; assert { !p = Seq.get !stackNodes 0 };
assert { path (at !left 'Init) (at !right 'Init) root !p !pth }; assert { path (old !left ) (old !right ) root !p !pth };
set_c !p false; set_c !p false;
ghost c_false_nodes := S.add !p !c_false_nodes; ghost c_false_nodes := S.add !p !c_false_nodes;
ghost unmarked_nodes := S.remove !p !unmarked_nodes ghost unmarked_nodes := S.remove !p !unmarked_nodes
