Commit da6251e7 authored by François Bobot's avatar François Bobot
[Session] fix: Fatal error: exception Session.NoTask (thx Martin)
          fix: recompute_all_shapes forgot to iter on metas
parent 725550da
...@@ -297,6 +297,9 @@ let iter_transf f t = ...@@ -297,6 +297,9 @@ let iter_transf f t =
let iter_metas f t = f t.metas_goal let iter_metas f t = f t.metas_goal
let iter_theory f t =
List.iter f t.theory_goals
let iter_file f fi = List.iter f fi.file_theories let iter_file f fi = List.iter f fi.file_theories
let iter_session f s = PHstr.iter (fun _ th -> f th) s.session_files let iter_session f s = PHstr.iter (fun _ th -> f th) s.session_files
...@@ -2039,7 +2042,7 @@ and merge_metas ~keygen ~theories env to_goal s from_metas = ...@@ -2039,7 +2042,7 @@ and merge_metas ~keygen ~theories env to_goal s from_metas =
exception OutdatedSession exception OutdatedSession
let merge_theory let merge_theory
?(release=false) ~keygen ~theories env ~allow_obsolete from_th to_th = ~release ~keygen ~theories env ~allow_obsolete from_th to_th =
set_theory_expanded to_th from_th.theory_expanded; set_theory_expanded to_th from_th.theory_expanded;
let from_goals = List.fold_left let from_goals = List.fold_left
(fun from_goals g -> (fun from_goals g ->
...@@ -2068,7 +2071,7 @@ let merge_theory ...@@ -2068,7 +2071,7 @@ let merge_theory
| Not_found -> raise OutdatedSession | Not_found -> raise OutdatedSession
) to_th.theory_goals ) to_th.theory_goals
let merge_file ?release ~keygen ~theories env ~allow_obsolete from_f to_f = let merge_file ~release ~keygen ~theories env ~allow_obsolete from_f to_f =
dprintf debug "[Info] merge_file, shape_version = %d@\n" dprintf debug "[Info] merge_file, shape_version = %d@\n"
env.session.session_shape_version; env.session.session_shape_version;
set_file_expanded to_f from_f.file_expanded; set_file_expanded to_f from_f.file_expanded;
...@@ -2085,7 +2088,7 @@ let merge_file ?release ~keygen ~theories env ~allow_obsolete from_f to_f = ...@@ -2085,7 +2088,7 @@ let merge_file ?release ~keygen ~theories env ~allow_obsolete from_f to_f =
(* TODO: remove this later when all sessions are updated *) (* TODO: remove this later when all sessions are updated *)
with Not_found -> Mstr.find ("WP "^name) from_theories with Not_found -> Mstr.find ("WP "^name) from_theories
in in
merge_theory ?release ~keygen ~theories env ~allow_obsolete from_th to_th merge_theory ~release ~keygen ~theories env ~allow_obsolete from_th to_th
with with
| Not_found when allow_obsolete -> () | Not_found when allow_obsolete -> ()
...@@ -2093,33 +2096,38 @@ let merge_file ?release ~keygen ~theories env ~allow_obsolete from_f to_f = ...@@ -2093,33 +2096,38 @@ let merge_file ?release ~keygen ~theories env ~allow_obsolete from_f to_f =
to_f.file_theories; to_f.file_theories;
dprintf debug "[Info] merge_file, done@\n" dprintf debug "[Info] merge_file, done@\n"
let rec recompute_all_shapes_goal g = let rec recompute_all_shapes_goal ~release g =
let t = goal_task g in let t = goal_task g in
(* g.goal_shape <- Termcode.t_shape_buf (Task.task_goal_fmla t); *) (* g.goal_shape <- Termcode.t_shape_buf (Task.task_goal_fmla t); *)
g.goal_shape <- Termcode.t_shape_task t; g.goal_shape <- Termcode.t_shape_task t;
g.goal_checksum <- Termcode.task_checksum t; g.goal_checksum <- Termcode.task_checksum t;
PHstr.iter recompute_all_shapes_transf g.goal_transformations if release then release_task g;
iter_goal
and recompute_all_shapes_transf _ tr = (fun pa -> ())
List.iter recompute_all_shapes_goal tr.transf_goals (iter_transf (recompute_all_shapes_goal ~release))
(iter_metas (recompute_all_shapes_goal ~release))
g
let recompute_all_shapes_theory t = let recompute_all_shapes_theory ~release t =
List. iter recompute_all_shapes_goal t.theory_goals iter_theory (recompute_all_shapes_goal ~release) t
let recompute_all_shapes_file _ f = let recompute_all_shapes_file ~release f =
List.iter recompute_all_shapes_theory f.file_theories iter_file (recompute_all_shapes_theory ~release) f
let recompute_all_shapes session = let recompute_all_shapes ~release session =
session.session_shape_version <- Termcode.current_shape_version; session.session_shape_version <- Termcode.current_shape_version;
PHstr.iter recompute_all_shapes_file session.session_files iter_session (recompute_all_shapes_file ~release) session
let update_session ?release ~keygen ~allow_obsolete old_session env whyconf = let update_session
?(release=false) ~keygen ~allow_obsolete old_session env whyconf =
dprintf debug "[Info] update_session: shape_version = %d@\n" dprintf debug "[Info] update_session: shape_version = %d@\n"
old_session.session_shape_version; old_session.session_shape_version;
let new_session = let new_session =
create_session ~shape_version:old_session.session_shape_version create_session ~shape_version:old_session.session_shape_version
old_session.session_dir old_session.session_dir
in in
let will_recompute_shape =
old_session.session_shape_version <> Termcode.current_shape_version in
let new_env_session = let new_env_session =
{ session = new_session; { session = new_session;
env = env; env = env;
...@@ -2139,7 +2147,8 @@ let update_session ?release ~keygen ~allow_obsolete old_session env whyconf = ...@@ -2139,7 +2147,8 @@ let update_session ?release ~keygen ~allow_obsolete old_session env whyconf =
let theories = Opt.get new_file.file_for_recovery in let theories = Opt.get new_file.file_for_recovery in
dprintf debug "[Merge] file '%s'@\n" old_file.file_name; dprintf debug "[Merge] file '%s'@\n" old_file.file_name;
merge_file ~keygen ~theories merge_file ~keygen ~theories
?release new_env_session ~allow_obsolete old_file new_file; ~release:(release && (not will_recompute_shape))
let fname = let fname =
Filename.basename (Filename.chop_extension old_file.file_name) Filename.basename (Filename.chop_extension old_file.file_name)
in in
...@@ -2150,11 +2159,11 @@ let update_session ?release ~keygen ~allow_obsolete old_session env whyconf = ...@@ -2150,11 +2159,11 @@ let update_session ?release ~keygen ~allow_obsolete old_session env whyconf =
new_env_session.files <- files; new_env_session.files <- files;
dprintf debug "[Info] update_session: done@\n"; dprintf debug "[Info] update_session: done@\n";
let obsolete = let obsolete =
if old_session.session_shape_version <> Termcode.current_shape_version if will_recompute_shape
then then
begin begin
dprintf debug "[Info] update_session: recompute shapes@\n"; dprintf debug "[Info] update_session: recompute shapes@\n";
recompute_all_shapes new_session; recompute_all_shapes ~release new_session;
true true
end end
else else
...@@ -496,6 +496,8 @@ val iter_transf : ...@@ -496,6 +496,8 @@ val iter_transf :
('key goal -> unit) -> 'key transf -> unit ('key goal -> unit) -> 'key transf -> unit
val iter_metas : val iter_metas :
('key goal -> unit) -> 'key metas -> unit ('key goal -> unit) -> 'key metas -> unit
val iter_theory :
('key goal -> unit) -> 'key theory -> unit
val iter_file : val iter_file :
('key theory -> unit) -> 'key file -> unit ('key theory -> unit) -> 'key file -> unit
val iter_session : val iter_session :
