Commit d57512a2 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Update opam packages.
parent 8f84e5d3
...@@ -270,52 +270,27 @@ DONE * sauvegarde de la configuration : à quel endroit dans l'IDE ? ...@@ -270,52 +270,27 @@ DONE * sauvegarde de la configuration : à quel endroit dans l'IDE ?
https://gforge.inria.fr/tracker/admin/?group_id=2990&atid=10293&add_extrafield=1 https://gforge.inria.fr/tracker/admin/?group_id=2990&atid=10293&add_extrafield=1
* prepare the OPAM package * prepare the OPAM package
- update opam/url: url and checksum of why-0.86.tar.gz - update opam/why3-base/url: url and checksum of why-0.86.tar.gz
(use "md5sum distrib/why3-0.86.tar.gz") (use "md5sum distrib/why3-0.86.tar.gz")
- update opam/descr if necessary - update opam/why3-base/descr and opam/why3/descr if necessary
- update opam/opam with correct dependencies and such - update opam/why3-base/opam with correct dependencies
- update opam/why3/opam with the dependency on why3-base
* test the OPAM package - test with "opam pin add why3 --kind=git .../why3/.git"
(it runs "opam install why3")
. with opam 1.2:
opam pin add why3 --kind=git <...>/why3/.git * upload the OPAM package
(it runs "opam install why3") - clone https://github.com/ocaml/opam-repository
. with opam < 1.2: git clone git@github.com:.../opam-repository.git
cd opam-repository/
- first step: have a local copy of opam-repository if not done yet, e.g.: git remote add opam https://github.com/ocaml/opam-repository.git
- reinitialize the repository if not fresh:
git clone git@github.com:claudemarche/opam-repository.git git fetch opam
cd opam-repository/ git reset --hard opam/master
git remote add opam https://github.com/ocaml/opam-repository.git git push
- cd packages/why3-base; cp -r .../opam/why3-base why3-base.0.86
or, if you already have one, make sure it is up-to-date: - cd packages/why3; cp -r .../opam/why3 why3.0.86
- commit and push
git fetch opam - make a pull request on github
git push
- second step: copy why3 opam files into it :
cd packages/why3
cp -r <source why3>/opam why3.0.86
- second step:
opam repository add local <...>/opam-repository
opam install why3
(* test it, e.g.
cp example/quicksort.mlw ~/tmp
why3 ide ~/tmp/quicksort.mlw *)
opam remove why3
opam repository remove local
* make a pull request on OPAM
git add why3.0.86
git commit -am "new package version why3 0.86"
git push
sur github: creer un pull request
* inform Jerry James <loganjerry@gmail.com> so that he can produce the * inform Jerry James <loganjerry@gmail.com> so that he can produce the
Fedora package Fedora package
archive: "https://gforge.inria.fr/frs/download.php/file/34797/why3-0.86.1.tar.gz" archive: "https://gforge.inria.fr/frs/download.php/file/35214/why3-0.86.2.tar.gz"
checksum: "43ab4c224b025c2e3dd5526fa6bef181" checksum: "ef0f4c133fc0da25a6b90adefddefa9a"
...@@ -19,7 +19,7 @@ tags: [ ...@@ -19,7 +19,7 @@ tags: [
available: [ ocaml-version >= "4.01.0" ] available: [ ocaml-version >= "4.01.0" ]
depends: [ depends: [
"why3-base" { = "0.86" } "why3-base" { = "0.86.2" }
"lablgtk" "lablgtk"
"conf-gtksourceview" "conf-gtksourceview"
"zarith" "zarith"
