Lexer et Parser
parent 05a9cd8a
...@@ -59,7 +59,7 @@ COQDEP = @COQDEP@ ...@@ -59,7 +59,7 @@ COQDEP = @COQDEP@
COQLIB = "@COQLIB@" COQLIB = "@COQLIB@"
COQVER = @COQVER@ COQVER = @COQVER@
GENERATED = src/version.ml GENERATED = src/version.ml src/parser.mli src/parser.ml src/lexer.ml
# main targets # main targets
...@@ -90,7 +90,8 @@ check: $(BINARY) $(PRELUDE) ...@@ -90,7 +90,8 @@ check: $(BINARY) $(PRELUDE)
LIBCMO = lib/pp.cmo lib/loc.cmo LIBCMO = lib/pp.cmo lib/loc.cmo
CMO = $(LIBCMO) src/name.cmo src/hashcons.cmo src/term.cmo src/pretty.cmo CMO = $(LIBCMO) src/name.cmo src/hashcons.cmo src/term.cmo src/pretty.cmo \
src/parser.cmo src/lexer.cmo
CMX = $(CMO:.cmo=.cmx) CMX = $(CMO:.cmo=.cmx)
bin/why.opt: $(CMX) bin/why.opt: $(CMX)
open Lexing
open Ptree
open Parser
let keywords = Hashtbl.create 97
let () =
List.iter
(fun (x,y) -> Hashtbl.add keywords x y)
[ "absurd", ABSURD;
"and", AND;
"array", ARRAY;
"as", AS;
"assert", ASSERT;
"axiom", AXIOM;
"begin", BEGIN;
"bool", BOOL;
"check", CHECK;
"do", DO;
"done", DONE;
"else", ELSE;
"end", END;
"exception", EXCEPTION;
"exists", EXISTS;
"external", EXTERNAL;
"false", FALSE;
"for", FOR;
"forall", FORALL;
"fun", FUN;
"function", FUNCTION;
"goal", GOAL;
"if", IF;
"in", IN;
"include", INCLUDE;
"inductive", INDUCTIVE;
"int", INT;
"invariant", INVARIANT;
"let", LET;
"logic", LOGIC;
"match", MATCH;
"not", NOT;
"of", OF;
"or", OR;
"parameter", PARAMETER;
"predicate", PREDICATE;
"prop", PROP;
"raise", RAISE;
"raises", RAISES;
"reads", READS;
"real", REAL;
"rec", REC;
"ref", REF;
"returns", RETURNS;
"then", THEN;
"true", TRUE;
"try", TRY;
"type", TYPE;
"unit", UNIT;
"variant", VARIANT;
"void", VOID;
"while", WHILE;
"with", WITH;
"writes", WRITES ]
let newline lexbuf =
let pos = lexbuf.lex_curr_p in
lexbuf.lex_curr_p <-
{ pos with pos_lnum = pos.pos_lnum + 1; pos_bol = pos.pos_cnum }
let string_buf = Buffer.create 1024
exception Lexical_error of string
let char_for_backslash = function
| 'n' -> '\n'
| 't' -> '\t'
| c -> c
let update_loc lexbuf file line chars =
let new_file = match file with None -> pos.pos_fname | Some s -> s in
{ pos with
pos_fname = new_file;
pos_lnum = int_of_string line;
pos_bol = pos.pos_cnum - int_of_string chars;
let remove_leading_plus s =
let n = String.length s in
if n > 0 && s.[0] = '+' then String.sub s 1 (n-1) else s
let option_app f = function None -> None | Some x -> Some (f x)
let newline = '\n'
let space = [' ' '\t' '\r']
let alpha = ['a'-'z' 'A'-'Z']
let letter = alpha | '_'
let digit = ['0'-'9']
let ident = letter (letter | digit | '\'')*
let hexadigit = ['0'-'9' 'a'-'f' 'A'-'F']
let hexafloat = '0' ['x' 'X'] (hexadigit* '.' hexadigit+ | hexadigit+ '.' hexadigit* ) ['p' 'P'] ['-' '+']? digit+
rule token = parse
| "#" space* ("\"" ([^ '\010' '\013' '"' ]* as file) "\"")?
space* (digit+ as line) space* (digit+ as char) space* "#"
{ update_loc lexbuf file line char; token lexbuf }
| newline
{ newline lexbuf; token lexbuf }
| space+
{ token lexbuf }
| ident as id
{ try Hashtbl.find keywords id with Not_found -> IDENT id }
| digit+ as s
{ INTEGER s }
| (digit+ as i) ("" as f) ['e' 'E'] (['-' '+']? digit+ as e)
| (digit+ as i) '.' (digit* as f) (['e' 'E'] (['-' '+']? digit+ as e))?
| (digit* as i) '.' (digit+ as f) (['e' 'E'] (['-' '+']? digit+ as e))?
{ FLOAT (RConstDecimal (i, f, option_app remove_leading_plus e)) }
| '0' ['x' 'X'] ((hexadigit* as i) '.' (hexadigit+ as f)
|(hexadigit+ as i) '.' (hexadigit* as f)
|(hexadigit+ as i) ("" as f))
['p' 'P'] (['-' '+']? digit+ as e)
{ FLOAT (RConstHexa (i, f, remove_leading_plus e)) }
{ comment lexbuf; token lexbuf }
{ QUOTE }
{ COMMA }
{ LEFTPAR }
{ RIGHTPAR }
{ BANG }
{ COLON }
{ SEMICOLON }
{ COLONEQUAL }
{ ARROW }
{ LRARROW }
{ EQUAL }
{ LT }
{ LE }
{ GT }
{ GE }
{ NOTEQ }
{ PLUS }
{ MINUS }
{ TIMES }
{ SLASH }
{ PERCENT }
{ AT }
{ DOT }
{ LEFTSQ }
{ RIGHTSQ }
{ LEFTB }
{ RIGHTB }
{ LEFTBLEFTB }
{ RIGHTBRIGHTB }
{ BAR }
{ BARBAR }
{ AMPAMP }
{ BIGARROW }
{ Buffer.clear string_buf; string lexbuf }
| eof
{ EOF }
| _ as c
{ raise (Lexical_error ("illegal character: " ^ String.make 1 c)) }
and comment = parse
{ comment lexbuf; comment lexbuf }
| newline
{ newline lexbuf; comment lexbuf }
| eof
{ raise (Lexical_error "unterminated comment") }
| _
{ comment lexbuf }
and string = parse
{ STRING (Buffer.contents string_buf) }
| "\\" (_ as c)
{ Buffer.add_char string_buf (char_for_backslash c); string lexbuf }
| newline
{ newline lexbuf; Buffer.add_char string_buf '\n'; string lexbuf }
| eof
{ raise (Lexical_error "unterminated string") }
| _ as c
{ Buffer.add_char string_buf c; string lexbuf }
let loc lb = (lexeme_start_p lb, lexeme_end_p lb)
let with_location f lb =
try f lb with e -> raise (Loc.Located (loc lb, e))
let parse_lexpr = with_location (lexpr token)
let parse_logic_file = with_location (logic_file token)
let lexpr_of_string s = parse_lexpr (from_string s)
Local Variables:
compile-command: "unset LANG; make -j -C .. bin/why.byte"
End:
This diff is collapsed.
...@@ -55,7 +55,7 @@ type plogic_type = ...@@ -55,7 +55,7 @@ type plogic_type =
| PPredicate of ppure_type list | PPredicate of ppure_type list
| PFunction of ppure_type list * ppure_type | PFunction of ppure_type list * ppure_type
type decl = type logic_decl =
| Logic of loc * external_ * string list * plogic_type | Logic of loc * external_ * string list * plogic_type
| Predicate_def of loc * string * (loc * string * ppure_type) list * lexpr | Predicate_def of loc * string * (loc * string * ppure_type) list * lexpr
| Inductive_def of loc * string * plogic_type * (loc * string * lexpr) list | Inductive_def of loc * string * plogic_type * (loc * string * lexpr) list
...@@ -67,4 +67,4 @@ type decl = ...@@ -67,4 +67,4 @@ type decl =
| AlgType of (loc * string list * string | AlgType of (loc * string list * string
* (loc * string * ppure_type list) list) list * (loc * string * ppure_type list) list) list
type file = decl list type logic_file = logic_decl list
