Commit b800fea5 authored by François Bobot's avatar François Bobot
Update tagset for FSet renaming
parent be95ca14
This diff is collapsed.
...@@ -35,7 +35,7 @@ module TagSetIntf ...@@ -35,7 +35,7 @@ module TagSetIntf
type iteration_state = mutable { } type iteration_state = mutable { }
type t = abstract { type t = abstract {
mutable elts: S.set key; mutable elts: S.fset key;
mutable iterated: iteration_state; mutable iterated: iteration_state;
invariant { not (S.mem S.dummy elts) } invariant { not (S.mem S.dummy elts) }
...@@ -66,9 +66,9 @@ module TagSetIntf ...@@ -66,9 +66,9 @@ module TagSetIntf
type iterator = abstract { type iterator = abstract {
iterating: iteration_state; iterating: iteration_state;
mutable seen: S.set key; mutable seen: S.fset key;
mutable todo: S.set key; mutable todo: S.fset key;
all: S.set key; all: S.fset key;
invariant { S.(union seen todo == all) } invariant { S.(union seen todo == all) }
invariant { S.(inter seen todo == S.empty) } invariant { S.(inter seen todo == S.empty) }
...@@ -118,7 +118,7 @@ module TagSet ...@@ -118,7 +118,7 @@ module TagSet
clone import S as S with axiom tag_correct clone import S as S with axiom tag_correct
type iteration_state = mutable { type iteration_state = mutable {
ghost mutable elts': S.set key; ghost mutable elts': S.fset key;
mutable value: array key; mutable value: array key;
invariant { not (S.mem S.dummy elts') } invariant { not (S.mem S.dummy elts') }
...@@ -132,7 +132,7 @@ module TagSet ...@@ -132,7 +132,7 @@ module TagSet
type t = { type t = {
ghost mutable elts: S.set key; ghost mutable elts: S.fset key;
invariant { elts = iterated.elts' } invariant { elts = iterated.elts' }
...@@ -204,9 +204,9 @@ module TagSet ...@@ -204,9 +204,9 @@ module TagSet
type iterator = { type iterator = {
ghost mutable seen: S.set key; ghost mutable seen: S.fset key;
ghost mutable todo: S.set key; ghost mutable todo: S.fset key;
ghost all: S.set key; ghost all: S.fset key;
mutable offset: int63; mutable offset: int63;
invariant { S.(==) all (S.union seen todo) } invariant { S.(==) all (S.union seen todo) }
