Commit a4d77dd5 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Generate html documentation in its own subdirectory and run hacha on it.
parent 6b662f87
...@@ -97,7 +97,7 @@ why3.conf ...@@ -97,7 +97,7 @@ why3.conf
/doc/manual.out /doc/manual.out
/doc/*.haux /doc/*.haux
/doc/*.pdf /doc/*.pdf
/doc/manual.html /doc/html/
/doc/*.hind /doc/*.hind
/doc/*.htoc /doc/*.htoc
/doc/bnf /doc/bnf
...@@ -65,6 +65,7 @@ endif ...@@ -65,6 +65,7 @@ endif
RUBBER = @RUBBER@ RUBBER = @RUBBER@
HEVEA = @HEVEA@ HEVEA = @HEVEA@
HACHA = @HACHA@
#PSVIEWER = @PSVIEWER@ #PSVIEWER = @PSVIEWER@
#PDFVIEWER = @PDFVIEWER@ #PDFVIEWER = @PDFVIEWER@
...@@ -1235,11 +1236,15 @@ doc/manual.pdf: $(BNFTEX) $(DOCTEX) doc/manual.bib ...@@ -1235,11 +1236,15 @@ doc/manual.pdf: $(BNFTEX) $(DOCTEX) doc/manual.bib
cd doc; $(RUBBER) --warn all --pdf manual.tex cd doc; $(RUBBER) --warn all --pdf manual.tex
# the dependency on the pdf ensures the bbl was built # the dependency on the pdf ensures the bbl was built
doc/manual.html: doc/manual.pdf doc/html/manual.html: doc/manual.pdf
cd doc; $(HEVEA) -fix fix.hva makeidx.hva manual.tex cd doc; rm -rf html; mkdir -p html
cd doc; $(HEVEA) -o html/manual.html -fix fix.hva makeidx.hva manual.tex
doc/html/index.html: doc/html/manual.html
cd doc; $(HACHA) -tocbis -o html/index.html html/manual.html
clean:: clean::
cd doc; $(RUBBER) --pdf --clean manual.tex cd doc; rm -rf html; $(RUBBER) --pdf --clean manual.tex
else else
...@@ -302,6 +302,9 @@ fi ...@@ -302,6 +302,9 @@ fi
# checking for hevea # checking for hevea
AC_CHECK_PROG(HEVEA,hevea,hevea,no) AC_CHECK_PROG(HEVEA,hevea,hevea,no)
# checking for hacha
AC_CHECK_PROG(HACHA,hacha,hacha,no)
# checking for lablgtk2 # checking for lablgtk2
if test "$enable_ide" = yes ; then if test "$enable_ide" = yes ; then
if test "$USEOCAMLFIND" = yes; then if test "$USEOCAMLFIND" = yes; then
