Commit a1d2969e authored by Sylvain Dailler's avatar Sylvain Dailler
Launch get-ce when clicking on a proofattempt status (unproved)
parent 5266b967
...@@ -1405,6 +1405,23 @@ let (_ : GtkSignal.id) = ...@@ -1405,6 +1405,23 @@ let (_ : GtkSignal.id) =
end; end;
context_tools_menu#popup ~button:3 ~time:(GdkEvent.Button.time ev); context_tools_menu#popup ~button:3 ~time:(GdkEvent.Button.time ev);
true true
| 1 -> (* Left click *)
(* Call get-ce only when clicked on the Status of a proofattempt
(which is unproved) *)
let x = int_of_float (GdkEvent.Button.x ev) in
let y = int_of_float (GdkEvent.Button.y ev) in
begin match goals_view#get_path_at_pos ~x ~y with
| Some (path,col,_,_) ->
if col#title = column_status_title then
let node_id =
get_node_id (goals_model#get_row_reference path)#iter in
let type_id = get_node_type node_id in
let proved_id = get_node_proved node_id in
if type_id = NProofAttempt && not proved_id then
send_request (Command_req (node_id, "get-ce"))
| _ -> ()
end;
false
| _ -> (* Other buttons *) false | _ -> (* Other buttons *) false
end end
in in
