Commit 92dd9a78 authored by Andrei Paskevich's avatar Andrei Paskevich
move the server code to a dedicated directory
also, do not use server_main.c, compile both .o instead
parent 6bb5875d
...@@ -121,8 +121,10 @@ why3.conf ...@@ -121,8 +121,10 @@ why3.conf
/doc/stdlibdoc/ /doc/stdlibdoc/
# /lib # /lib
/lib/why3-cpulimit /lib/why3cpulimit
/lib/why3-cpulimit.exe /lib/why3cpulimit.exe
/lib/why3server
/lib/why3server.exe
# /lib/why3/ # /lib/why3/
/lib/why3/META /lib/why3/META
...@@ -248,7 +248,7 @@ opt: lib/why3/why3.cmxa ...@@ -248,7 +248,7 @@ opt: lib/why3/why3.cmxa
lib/why3/why3.cma: lib/why3/why3.cmo lib/why3/why3.cma: lib/why3/why3.cmo
$(if $(QUIET),@echo 'Linking $@' &&) \ $(if $(QUIET),@echo 'Linking $@' &&) \
$(OCAMLC) -a $(BFLAGS) -o $@ $^ $(OCAMLC) -a $(BFLAGS) -o $@ $^
lib/why3/why3.cmxa: lib/why3/why3.cmx lib/why3/why3.cmxa: lib/why3/why3.cmx
...@@ -614,46 +614,38 @@ clean:: ...@@ -614,46 +614,38 @@ clean::
# Why3server # # Why3server #
SERVER_MODULES:= logging arraylist options queue readbuf request writebuf server_main SERVER_MODULES := logging arraylist options queue readbuf request \
SERVER_C:= $(addprefix src/tools/, $(addsuffix .c, $(SERVER_MODULES))) writebuf server-unix server-win
SERVER_H:= $(addprefix src/tools/, $(addsuffix .h, $(SERVER_MODULES)))
SERVER_O:= $(addprefix src/tools/, $(addsuffix .o, $(SERVER_MODULES))) CPULIM_MODULES := cpulimit-unix cpulimit-win
SERVER_O := $(addprefix src/server/, $(addsuffix .o, $(SERVER_MODULES)))
CPULIM_O := $(addprefix src/server/, $(addsuffix .o, $(CPULIM_MODULES)))
opt: lib/why3server$(EXE) TOOLS = lib/why3server$(EXE) lib/why3cpulimit$(EXE)
byte opt: $(TOOLS)
lib/why3server$(EXE): $(SERVER_O) lib/why3server$(EXE): $(SERVER_O)
gcc -o $@ $^ $(CC) -Wall -o $@ $^
lib/why3cpulimit$(EXE): $(CPULIM_O)
%.o: %.c %.h %.o: %.c %.h
gcc -c -Wall -g -o $@ $< $(CC) -c -Wall -g -o $@ $<
%.o: %.c
src/tools/main.o:: src/tools/server-unix.c src/tools/server-win.c %.o: %.c
install_no_local:: install_no_local::
cp -f lib/why3server$(EXE) $(LIBDIR)/why3/why3server$(EXE) cp -f lib/why3server$(EXE) $(LIBDIR)/why3/why3server$(EXE)
cp -f lib/why3cpulimit$(EXE) $(LIBDIR)/why3/why3cpulimit$(EXE)
cp -f lib/why3-call-pvs $(LIBDIR)/why3/why3-call-pvs
clean:: clean::
rm -f $(SERVER_O) rm -f $(SERVER_O) $(CPULIM_O) $(TOOLS)
install_spark2014:
mkdir -p $(BINDIR)
mkdir -p $(DATADIR)/why3
mkdir -p $(DATADIR)/why3/theories
mkdir -p $(DATADIR)/why3/drivers
mkdir -p $(DATADIR)/why3/modules
mkdir -p $(DATADIR)/why3/libs
cp -f theories/*.why $(DATADIR)/why3/theories
cp -f modules/*.mlw $(DATADIR)/why3/modules
cp -f drivers/*.drv drivers/*.gen drivers/*.aux $(DATADIR)/why3/drivers
cp -f share/why3session.dtd $(DATADIR)/why3
cp -f lib/why3server$(EXE) $(BINDIR)/why3server$(EXE)
cp -f bin/gnatwhy3.@OCAMLBEST@ $(BINDIR)/gnatwhy3$(EXE)
cp -f bin/why3realize.@OCAMLBEST@ $(BINDIR)/why3realize$(EXE)
cp -f bin/why3config.@OCAMLBEST@ $(BINDIR)/why3config$(EXE)
cp -f share/provers-detection-data.conf $(DATADIR)/why3/
cp -rf lib/coq $(DATADIR)/why3/libs
# gallery # gallery
...@@ -873,7 +865,7 @@ lib/coq-tactic/why3tac.cmxs: lib/why3/why3.cmxa $(COQPCMX) ...@@ -873,7 +865,7 @@ lib/coq-tactic/why3tac.cmxs: lib/why3/why3.cmxa $(COQPCMX)
$(OCAMLOPT) $(OFLAGS) -o $@ -shared $^ $(OCAMLOPT) $(OFLAGS) -o $@ -shared $^
lib/coq-tactic/why3tac.cma: src/driver/vc_client.o lib/why3/why3.cma $(COQPCMO) lib/coq-tactic/why3tac.cma: lib/why3/why3.cma $(COQPCMO)
...@@ -1442,24 +1434,6 @@ clean:: ...@@ -1442,24 +1434,6 @@ clean::
endif endif
# tools
TOOLS = lib/why3-cpulimit$(EXE)
byte opt: $(TOOLS)
lib/why3-cpulimit$(EXE): src/tools/@CPULIMIT@.c
clean::
rm -f lib/why3-cpulimit$(EXE)
install_no_local::
cp -f lib/why3-cpulimit$(EXE) $(LIBDIR)/why3/why3-cpulimit$(EXE)
# why3doc # why3doc
...@@ -140,18 +140,15 @@ AC_MSG_CHECKING(executable suffix) ...@@ -140,18 +140,15 @@ AC_MSG_CHECKING(executable suffix)
if uname -s | grep -q CYGWIN ; then if uname -s | grep -q CYGWIN ; then
EXE=.exe EXE=.exe
STRIP='echo "no strip "' STRIP='echo "no strip "'
CPULIMIT=cpulimit-win
AC_MSG_RESULT(.exe <Cygwin>) AC_MSG_RESULT(.exe <Cygwin>)
else else
if uname -s | grep -q MINGW ; then if uname -s | grep -q MINGW ; then
EXE=.exe EXE=.exe
STRIP=strip STRIP=strip
AC_MSG_RESULT(.exe <MinGW>) AC_MSG_RESULT(.exe <MinGW>)
else else
EXE= EXE=
CPULIMIT=cpulimit
AC_MSG_RESULT(<none>) AC_MSG_RESULT(<none>)
fi fi
fi fi
...@@ -719,7 +716,6 @@ AC_SUBST(enable_verbose_make) ...@@ -719,7 +716,6 @@ AC_SUBST(enable_verbose_make)
AC_SUBST(EXE) AC_SUBST(EXE)
AC_SUBST(STRIP) AC_SUBST(STRIP)
AC_SUBST(CPULIMIT)
AC_SUBST(OCAMLC) AC_SUBST(OCAMLC)
AC_SUBST(OCAMLOPT) AC_SUBST(OCAMLOPT)
...@@ -267,7 +267,7 @@ let actualcommand command ~use_why3cpulimit limit interactive file = ...@@ -267,7 +267,7 @@ let actualcommand command ~use_why3cpulimit limit interactive file =
in in
let args = let args =
if use_why3cpulimit && not interactive then if use_why3cpulimit && not interactive then
let cpulimit_bin = Filename.concat Config.libdir "why3-cpulimit" in let cpulimit_bin = Filename.concat Config.libdir "why3cpulimit" in
let cpulimit_time = let cpulimit_time =
(* for steps limit use 2 * t + 1 time *) (* for steps limit use 2 * t + 1 time *)
if limit.limit_steps <> None then string_of_int (2 * timelimit + 1) if limit.limit_steps <> None then string_of_int (2 * timelimit + 1)
...@@ -76,9 +76,9 @@ let run_server () = ...@@ -76,9 +76,9 @@ let run_server () =
let force_connect () = let force_connect () =
match !socket with match !socket with
| None when !standalone -> | None when !standalone ->
run_server (); let _pid = run_server () in
(* sleep is needed before connecting, or the server will not be ready (* sleep is needed before connecting,
yet *) or the server will not be ready yet *)
ignore (Unix.select [] [] [] 0.1); ignore (Unix.select [] [] [] 0.1);
connect() connect()
| _ -> () | _ -> ()
...@@ -48,9 +48,3 @@ ...@@ -48,9 +48,3 @@
// events are incoming clients, read/write operations on sockets, and // events are incoming clients, read/write operations on sockets, and
// terminating child processes. Lists of child processes and connected clients // terminating child processes. Lists of child processes and connected clients
// are maintained. // are maintained.
#ifdef _WIN32
# include "server-win.c"
#else
# include "server-unix.c"
#endif
...@@ -9,6 +9,8 @@ ...@@ -9,6 +9,8 @@
#ifndef _WIN32
#include <sys/types.h> #include <sys/types.h>
#include <sys/time.h> #include <sys/time.h>
#include <time.h> #include <time.h>
...@@ -145,3 +147,5 @@ int main(int argc, char *argv[]) { ...@@ -145,3 +147,5 @@ int main(int argc, char *argv[]) {
return EXIT_FAILURE; return EXIT_FAILURE;
#endif /* _WIN32 */
...@@ -17,6 +17,8 @@ ...@@ -17,6 +17,8 @@
/* $Id: cpulimit-win.c,v 1.3 2009-12-09 08:28:00 nrousset Exp $ */ /* $Id: cpulimit-win.c,v 1.3 2009-12-09 08:28:00 nrousset Exp $ */
#ifdef _WIN32
#include <windows.h> #include <windows.h>
#include <stdlib.h> #include <stdlib.h>
#include <stdio.h> #include <stdio.h>
...@@ -203,5 +205,7 @@ int main(int argc, char *argv[]) { ...@@ -203,5 +205,7 @@ int main(int argc, char *argv[]) {
return ex; return ex;
#endif /* _WIN32 */
// How to compile under Cygwin (needs make, gcc and win32api): // How to compile under Cygwin (needs make, gcc and win32api):
// gcc -Wall -o cpulimit cpulimit.c // gcc -Wall -o cpulimit cpulimit.c
...@@ -5,6 +5,8 @@ ...@@ -5,6 +5,8 @@
// Contrary to the situation on windows, e.g. a read event means that the next // Contrary to the situation on windows, e.g. a read event means that the next
// call to read() will not block. // call to read() will not block.
#ifndef _WIN32
#include <unistd.h> #include <unistd.h>
...@@ -544,3 +546,5 @@ int main(int argc, char **argv) { ...@@ -544,3 +546,5 @@ int main(int argc, char **argv) {
#endif /* _WIN32 */
// windows: you need to start them first, and get notified when they are // windows: you need to start them first, and get notified when they are
// terminated. // terminated.
#ifdef _WIN32
...@@ -648,3 +650,5 @@ int main(int argc, char **argv) { ...@@ -648,3 +650,5 @@ int main(int argc, char **argv) {
#endif /* _WIN32 */
