Peano and one-time integers, with suitable drivers for OCaml extraction
parent dbf8fc7d
(* OCaml driver for 64-bit architecture *) (** OCaml driver for 64-bit architecture *)
import "ocaml-gen.drv" import "ocaml-gen.drv"
(* TODO bv.BV31 ? *) (** Machine arithmetic *)
(* TODO bv.BV32 -> int or int32 ? *)
module mach.int.Int32 module mach.int.Int32
syntax val of_int "Why3__BigInt.to_int" syntax val of_int "Why3__BigInt.to_int"
...@@ -64,15 +62,6 @@ module mach.int.UInt32 ...@@ -64,15 +62,6 @@ module mach.int.UInt32
end end
theory bv.BV63
syntax type t "int"
syntax constant zero "0"
syntax constant ones "-1"
syntax function bw_and "(%1 land %2)"
syntax predicate eq "(%1 = %2)"
(* TODO ... *)
module mach.int.Int63 module mach.int.Int63
syntax converter of_int "%1" syntax converter of_int "%1"
...@@ -97,8 +86,6 @@ module mach.int.Int63 ...@@ -97,8 +86,6 @@ module mach.int.Int63
syntax val of_bv "(fun x -> x)" syntax val of_bv "(fun x -> x)"
end end
(* TODO bv.BV64 -> int64 *)
module mach.int.Int64 module mach.int.Int64
syntax val of_int "Why3__BigInt.to_int64" syntax val of_int "Why3__BigInt.to_int64"
syntax converter of_int "%1L" syntax converter of_int "%1L"
...@@ -120,7 +107,68 @@ module mach.int.Int64 ...@@ -120,7 +107,68 @@ module mach.int.Int64
syntax val (>) "(>)" syntax val (>) "(>)"
end end
(* arrays *) module mach.peano.Peano
syntax type t "int"
syntax val to_int "Why3__BigInt.of_int"
syntax val zero "(fun _ -> 0)"
syntax val succ "succ"
syntax val pred "pred"
syntax val lt "(<)"
syntax val le "(<=)"
syntax val gt "(>)"
syntax val ge "(>=)"
syntax val eq "(=)"
syntax val ne "(<>)"
syntax val neg "(~-)"
syntax val abs "abs"
syntax val add "(+)"
syntax val sub "(-)"
syntax val mul "( * )"
syntax val of_int "(fun n _ _ -> Why3__BigInt.to_int n)"
syntax val div "(/)"
syntax val mod "(mod)"
syntax val max "max"
syntax val min "min"
module mach.onetime.OneTime
syntax type t "int"
syntax val lt "(<)"
syntax val gt "(>)"
syntax val eq "(=)"
syntax val to_peano "(fun x -> x)"
syntax val transfer "(fun x -> x)"
syntax val split "(fun x y -> x - y, y)"
(** Bit vectors *)
theory bv.BV63
syntax type t "int"
(* TODO ... *)
(* TODO
bv.BV31 ?
bv.BV64 -> int64 *)
(** Arrays *)
module mach.array.Array32 module mach.array.Array32
syntax type array "(%1 array)" syntax type array "(%1 array)"
...@@ -151,3 +199,4 @@ module mach.array.Array63 ...@@ -151,3 +199,4 @@ module mach.array.Array63
syntax val blit "Array.blit" syntax val blit "Array.blit"
syntax val self_blit "Array.blit" syntax val self_blit "Array.blit"
end end
(** {2 One-time integers} *)
module OneTime
use import int.Int
type t model { v: int; mutable ghost valid: bool }
val to_int (x: t) : int
ensures { result = x.v }
val zero (): t
ensures { result.valid }
ensures { result.v = 0 }
(* FIXME: should be a constant?
val function zero : t
val succ (x: t) : t
requires { x.valid }
writes { x.valid }
ensures { result.valid /\ not x.valid }
ensures { result.v = x.v + 1 }
val pred (x: t) : t
writes { x.valid }
ensures { result.v = x.v - 1 }
val lt (x y: t) : bool
ensures { result <-> x.v < y.v }
val le (x y: t) : bool
ensures { result <-> x.v <= y.v }
val gt (x y: t) : bool
ensures { result <-> x.v > y.v }
val ge (x y: t) : bool
ensures { result <-> x.v >= y.v }
val eq (x y: t) : bool
ensures { result <-> x.v = y.v }
val ne (x y: t) : bool
ensures { result <-> x.v <> y.v }
use mach.peano.Peano as P
val to_peano (x: t) : P.t
ensures { result.P.v = x.v }
val transfer (x: t) : t
writes { x.valid }
ensures { result.v = x.v }
val neg (x: t) : t
writes { x.valid }
ensures { result.v = - x.v }
val abs (x: t) : t
writes { x.valid }
ensures { result.v = if x.v >= 0 then x.v else - x.v }
val add (x y: t) : t
requires { x.valid /\ y.valid }
writes { x.valid, y.valid }
ensures { result.valid /\ not x.valid /\ not y.valid }
ensures { result.v = x.v + y.v }
val sub (x y: t) : t
ensures { result.v = x.v - y.v }
val split (x: t) (p: P.t) : (t, t)
requires { 0 <= p.P.v <= x.v \/ x.v <= p.P.v <= 0 }
writes { x.valid }
ensures { not x.valid }
returns { a, b -> a.valid /\ b.valid /\ a.v = x.v - b.v /\ b.v = p.P.v }
(** {2 Peano arithmetic} *)
module Peano
use import int.Int
type t model { v: int }
val zero (): t
val succ (x: t) : t
val pred (x: t) : t
val neg (x: t) : t
val abs (x: t) : t
val add (x y: t) (low high: t) : t
requires { low.v <= x.v + y.v <= high.v }
val sub (x y: t) (low high: t) : t
requires { low.v <= x.v - y.v <= high.v }
val mul (x y: t) (low high: t) : t
requires { low.v <= x.v * y.v <= high.v }
ensures { result.v = x.v * y.v }
val of_int (x: int) (low high: t) : t
requires { low.v <= x <= high.v }
ensures { result.v = x }
(* FIXME could replace low.v by - max (abs low) (abs high)
high.v by max (abs low) (abs high)
avoid the computation of the bounds
e.g. addition of two values of different signs
use import int.ComputerDivision
val div (x y: t) : t
requires { y.v <> 0 }
ensures { result.v = div x.v y.v }
val mod (x y: t) : t
ensures { result.v = mod x.v y.v }
use import int.MinMax
val max (x y: t) : t
ensures { result.v = max x.v y.v }
val min (x y: t) : t
ensures { result.v = min x.v y.v }
