Commit 6b662f87 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Add syntactic coloring for OCaml code too.
parent 2bf65706
This diff is collapsed.
...@@ -39,7 +39,16 @@ ...@@ -39,7 +39,16 @@
\RequirePackage{listings} \RequirePackage{listings}
\RequirePackage{amssymb} \RequirePackage{amssymb}
\lstset{basicstyle={\ttfamily},framesep=2pt,frame=single} \lstset{
framesep=2pt,
frame=single,
keywordstyle={\color{blue}},
stringstyle=\itshape,
commentstyle=\itshape,
columns=[l]fullflexible,
showstringspaces=false,
\lstdefinelanguage{why3} \lstdefinelanguage{why3}
...@@ -48,13 +57,7 @@ import,export,theory,module,end,in,with,% ...@@ -48,13 +57,7 @@ import,export,theory,module,end,in,with,%
let,rec,for,to,do,done,match,if,then,else,while,try,invariant,variant,% let,rec,for,to,do,done,match,if,then,else,while,try,invariant,variant,%
absurd,raise,assert,exception,% absurd,raise,assert,exception,%
goal,axiom,lemma,forall},% goal,axiom,lemma,forall},%
keywordstyle={\color{blue}},%
otherkeywords={},%
string=[b]",% string=[b]",%
showstringspaces=false,%
stringstyle=\itshape,%
commentstyle=\itshape,%
columns=[l]fullflexible,%
sensitive=true,% sensitive=true,%
morecomment=[s]{(*}{*)},% morecomment=[s]{(*}{*)},%
keepspaces=true, keepspaces=true,
...@@ -82,6 +85,7 @@ literate=% ...@@ -82,6 +85,7 @@ literate=%
\lstnewenvironment{whycode}{\lstset{language=why3}}{} \lstnewenvironment{whycode}{\lstset{language=why3}}{}
\lstnewenvironment{ocamlcode}{\lstset{language={[Objective]Caml}}}{}
%%% Local Variables: %%% Local Variables:
%%% mode: latex %%% mode: latex
