Support
why3
Project overview
Project overview
Boards
Packages
Packages
Container Registry
Why3
why3
54d6b937
54d6b937
Guillaume Melquiond
Simplify extract_ocaml_code.
f091aad9
2
2 changed files
23 additions
64 deletions
+23
-64
Makefile.in
Makefile.in
+5
-5
doc/extract_ocaml_code.ml
+18
-59
Makefile.in
54d6b937
@@ -1873,19 +1873,19 @@ doc/extract_ocaml_code: doc/extract_ocaml_code.ml
$(OCAMLC)
str.cma
-o
$(OCAMLC)
str.cma
-o
doc/logic__%.ml
examples/use_api/logic.ml doc/extract_ocaml_code
doc/logic__%.ml
doc
doc/whyconf__%.ml
src/driver/whyconf.ml doc/extract_ocaml_code
doc/whyconf__%.ml
doc
doc/call_provers__%.ml
src/driver/call_provers.ml doc/extract_ocaml_code
doc
doc/mlw_tree__%.ml
examples/use_api/mlw_tree.ml doc/extract_ocaml_code
doc/mlw_tree__%.ml
doc
doc/transform__%.ml
examples/use_api/transform.ml doc/extract_ocaml_code
doc/transform__%.ml
doc
OCAMLCODE_LOGIC
opening printformula declarepropvars declarepropatoms
OCAMLCODE_LOGIC
buildtask printtask buildtask2
54d6b937
Simple utility to extract a portion of
a file
the standard input
extract_ocaml_code <
path/file.ext> <id> <dir
id
extracts the part of path/file.ext between lines containing anchors BEGIN{id} and END{id}
outputs the part of the standard input between anchors BEGIN{id} and END{id}
and puts the result in the file dir/file_id.ext
open
Format
let
section
match
Sys
argv
let
filename
section
output_dir
_
section
section
if
Array
length
Sys
argv
4
then
_
Sys
argv
Sys
argv
2
Sys
argv
3
Format
eprintf
"Usage: %s <id>@
\n
else
Output the part of the standard input between anchors BEGIN{id} and END{id}@."
begin
Sys
argv
eprintf
"Usage: %s <path/file.ext> <id> <dir>@
\n
exit
2
Extract the part of path/file.ext between lines containing anchors BEGIN{id} and END{id}@
\n
and puts the result in the file dir/file_id.ext@."
Sys
argv
exit
2
let
ch_in
try
open_in
filename
exn
eprintf
"Cannot open %s for reading: %s@."
filename
Printexc
to_string
exn
exit
let
basename
Filename
basename
filename
let
ext
Filename
extension
basename
let
basename
Filename
remove_extension
basename
let
begin_re
Str
regexp_string
"BEGIN{"
section
let
begin_re
Str
regexp_string
"BEGIN{"
section
let
search_begin
let
search_begin
try
try
while
true
do
while
true
do
let
l
input_line
ch_in
in
let
l
read_line
in
try
try
let
_
Str
search_forward
begin_re
l
in
raise
Exit
let
_
Str
search_forward
begin_re
l
in
raise
Exit
Not_found
Not_found
done
done
End_of_file
End_of_file
eprintf
"Error: opening anchor BEGIN{%s} not found in file %s@."
section
filename
Format
eprintf
"Error: opening anchor BEGIN{%s} not found@."
section
close_in
ch_in
exit
exit
Exit
Exit
let
end_re
Str
regexp_string
"END{"
section
let
end_re
Str
regexp_string
"END{"
section
let
file_out
Filename
concat
output_dir
basename
"__"
section
ext
let
ch_out
try
open_out
file_out
exn
eprintf
"Cannot open %s for writing: %s@."
file_out
Printexc
to_string
exn
close_in
ch_in
exit
let
search_end
let
search_end
try
try
while
true
do
while
true
do
let
l
input_line
ch_in
in
let
l
read_line
in
try
try
let
_
Str
search_forward
end_re
l
in
raise
Exit
let
_
Str
search_forward
end_re
l
in
raise
Exit
Not_found
Not_found
output_string
ch_out
l
print_string
l
output_char
ch_out
'\n'
print_char
'\n'
done
done
Exit
End_of_file
eprintf
"Error: ending anchor END{%s} not found in file %s@."
section
filename
close_in
ch_in
close_out
ch_out
exit
Exit
close_in
ch_in
close_out
ch_out
let
let
search_begin
search_end
search_begin
search_end
