foveoos11_challenge2: added proof of termination
parent 0d3d2818
...@@ -12,12 +12,19 @@ module MaximumTree ...@@ -12,12 +12,19 @@ module MaximumTree
type tree = Empty | Node tree int tree type tree = Empty | Node tree int tree
function size (t: tree) : int = match t with
| Empty -> 0
| Node l _ r -> 1 + size l + size r
lemma size_nonneg: forall t: tree. size t >= 0
predicate mem (x: int) (t: tree) = match t with predicate mem (x: int) (t: tree) = match t with
| Empty -> false | Empty -> false
| Node l v r -> mem x l \/ x = v \/ mem x r | Node l v r -> mem x l \/ x = v \/ mem x r
end end
let rec maximum (t: tree) : int = let rec maximum (t: tree) : int variant { size t } =
{ t <> Empty } { t <> Empty }
match t with match t with
| Empty -> absurd | Empty -> absurd
(* This file is generated by Why3's Coq driver *)
(* Beware! Only edit allowed sections below *)
Require Import ZArith.
Require Import Rbase.
Definition unit := unit.
Parameter qtmark : Type.
Parameter at1: forall (a:Type), a -> qtmark -> a.
Implicit Arguments at1.
Parameter old: forall (a:Type), a -> a.
Implicit Arguments old.
Axiom Max_is_ge : forall (x:Z) (y:Z), (x <= (Zmax x y))%Z /\
(y <= (Zmax x y))%Z.
Axiom Max_is_some : forall (x:Z) (y:Z), ((Zmax x y) = x) \/ ((Zmax x y) = y).
Axiom Min_is_le : forall (x:Z) (y:Z), ((Zmin x y) <= x)%Z /\
((Zmin x y) <= y)%Z.
Axiom Min_is_some : forall (x:Z) (y:Z), ((Zmin x y) = x) \/ ((Zmin x y) = y).
Axiom Max_x : forall (x:Z) (y:Z), (y <= x)%Z -> ((Zmax x y) = x).
Axiom Max_y : forall (x:Z) (y:Z), (x <= y)%Z -> ((Zmax x y) = y).
Axiom Min_x : forall (x:Z) (y:Z), (x <= y)%Z -> ((Zmin x y) = x).
Axiom Min_y : forall (x:Z) (y:Z), (y <= x)%Z -> ((Zmin x y) = y).
Axiom Max_sym : forall (x:Z) (y:Z), (y <= x)%Z -> ((Zmax x y) = (Zmax y x)).
Axiom Min_sym : forall (x:Z) (y:Z), (y <= x)%Z -> ((Zmin x y) = (Zmin y x)).
Inductive tree :=
| Empty : tree
| Node : tree -> Z -> tree -> tree .
Set Implicit Arguments.
Fixpoint size(t:tree) {struct t}: Z :=
match t with
| Empty => 0%Z
| (Node l _ r) => ((1%Z + (size l))%Z + (size r))%Z
end.
Unset Implicit Arguments.
(* YOU MAY EDIT THE CONTEXT BELOW *)
(* DO NOT EDIT BELOW *)
Theorem size_nonneg : forall (t:tree), (0%Z <= (size t))%Z.
(* YOU MAY EDIT THE PROOF BELOW *)
induction t; intuition.
unfold size; fold size; omega.
Qed.
...@@ -9,19 +9,11 @@ ...@@ -9,19 +9,11 @@
<prover <prover
id="coq" id="coq"
name="Coq" name="Coq"
version="8.2pl1"/> version="8.3pl2"/>
<prover <prover
id="cvc3" id="cvc3"
name="CVC3" name="CVC3"
version="2.2"/> version="2.2"/>
<prover
id="eprover"
name="Eprover"
version="0.7 Dhajea"/>
<prover
id="gappa"
name="Gappa"
version="0.14.0"/>
<prover <prover
id="simplify" id="simplify"
name="Simplify" name="Simplify"
...@@ -29,11 +21,11 @@ ...@@ -29,11 +21,11 @@
<prover <prover
id="yices" id="yices"
name="Yices" name="Yices"
version="1.0.13"/> version="1.0.27"/>
<prover <prover
id="z3" id="z3"
name="Z3" name="Z3"
version="2.13"/> version="2.19"/>
<file <file
name="../foveoos11_challenge2.mlw" name="../foveoos11_challenge2.mlw"
verified="true" verified="true"
...@@ -42,19 +34,33 @@ ...@@ -42,19 +34,33 @@
name="WP MaximumTree" name="WP MaximumTree"
expanded="true"> expanded="true">
<goal
name="size_nonneg"
sum="d9dbfdf8e431c42e593667388fe56267"
proved="true"
expanded="true"
shape="ainfix >=asizeV0c0F">
<proof
prover="coq"
timelimit="10"
edited="foveoos11_challenge2_WP_MaximumTree_size_nonneg_1.v"
obsolete="false">
<result status="valid" time="0.46"/>
</proof>
</goal>
<goal <goal
name="WP_parameter maximum" name="WP_parameter maximum"
expl="parameter maximum" expl="parameter maximum"
sum="f40fb156943f0b6bc126f4aa41b513f4" sum="633cd631bb850639d4b5effe2b5fcdf2"
proved="true" proved="true"
expanded="true" expanded="true"
shape="CV0aEmptyfaNodeaEmptyVaEmptyainfix <=V2V1IamemV2V0FAamemV1V0aNodeVVaEmptyOaNodeaEmptyVVainfix <=V6amaxV5V3IamemV6V0FAamemamaxV5V3V0Iainfix <=V7V5IamemV7V4FAamemV5V4FAainfix =V4aEmptyNaNodeVVVainfix <=V13amaxV11amaxV9V12IamemV13V0FAamemamaxV11amaxV9V12V0Iainfix <=V14V12IamemV14V10FAamemV12V10FAainfix =V10aEmptyNIainfix <=V15V11IamemV15V8FAamemV11V8FAainfix =V8aEmptyNIainfix =V0aEmptyNF"> shape="CV0aEmptyfaNodeaEmptyVaEmptyainfix <=V2V1IamemV2V0FAamemV1V0aNodeVVaEmptyOaNodeaEmptyVVainfix <=V6amaxV5V3IamemV6V0FAamemamaxV5V3V0Iainfix <=V7V5IamemV7V4FAamemV5V4FAainfix =V4aEmptyNAainfix <asizeV4asizeV0Aainfix <=c0asizeV0aNodeVVVainfix <=V13amaxV11amaxV9V12IamemV13V0FAamemamaxV11amaxV9V12V0Iainfix <=V14V12IamemV14V10FAamemV12V10FAainfix =V10aEmptyNAainfix <asizeV10asizeV0Aainfix <=c0asizeV0Iainfix <=V15V11IamemV15V8FAamemV11V8FAainfix =V8aEmptyNAainfix <asizeV8asizeV0Aainfix <=c0asizeV0Iainfix =V0aEmptyNF">
<proof <proof
prover="alt-ergo" prover="alt-ergo"
timelimit="10" timelimit="10"
edited="" edited=""
obsolete="false"> obsolete="false">
<result status="valid" time="0.40"/> <result status="valid" time="0.62"/>
</proof> </proof>
</goal> </goal>
</theory> </theory>
