Commit 41d7a29c authored by Andrei Paskevich's avatar Andrei Paskevich
put OCAML-LICENSE
parent 8f6a08df
This diff is collapsed.
...@@ -15,8 +15,8 @@ DOCUMENTATION ...@@ -15,8 +15,8 @@ DOCUMENTATION
The documentation (a tutorial and a reference manual) is in The documentation (a tutorial and a reference manual) is in
the file doc/manual.pdf. the file doc/manual.pdf.
Various examples can be found in the subdirectories theories/ and Various examples can be found in the subdirectories theories/
examples/. and examples/.
Mailing list (Why3 Club): Mailing list (Why3 Club):
http://lists.gforge.inria.fr/mailman/listinfo/why3-club http://lists.gforge.inria.fr/mailman/listinfo/why3-club
...@@ -30,9 +30,9 @@ COPYRIGHT ...@@ -30,9 +30,9 @@ COPYRIGHT
This program is distributed under the GNU LGPL 2.1. See the enclosed This program is distributed under the GNU LGPL 2.1. See the enclosed
file LICENSE. file LICENSE.
The files src/util/stdlib.ml{i} are derived from the sources of OCaml The files src/util/stdlib.ml{i} are derived from the sources of
3.12 standard library, and are distributed under the GNU LGPL version OCaml 3.12 standard library, and are distributed under the GNU
xx (see file OCAML-LICENSE). LGPL version 2 (see file OCAML-LICENSE).
INSTALLATION INSTALLATION
