Commit 30fc66d6 authored by MARCHE Claude's avatar MARCHE Claude
Why3 meeting and new roadmap
parent 5998cb1b
...@@ -47,27 +47,58 @@ ...@@ -47,27 +47,58 @@
=== Roadmap for next release ======================== === Roadmap for next release ========================
* fix support for newer Z3, CVC3 and Alt-Ergo, allow several version
of them at the same time. Allow why3config --detect to find e.g z3
under names like z3-3.2 (how ? command-line option ? e.g. -p z3 /usr/local/bin/z3-3.2)
* move Session module and its dependencies into the Why3 library
* document new tools why3stats or others * stages
** M1. preuve d'un petit compilateur, pas de pb de lieur,
eventuellement outils pour les preuves par recurrence
a la Leino, + fct size automatique
** M2. Lieur en Why3, POPLmark challenge. vers
un theorie et/ou un module réutilisable de lieurs
** (M2?) Stage Airbus, "TIP" avec Frama-C/Jessie ou WP/Why/Coq
besoin du plugin Coq?
* PRIORITAIRE, JCF et ANDREI, clone de module
** demarche: ecrire une API avec smart constructors garantissant
le bon typage, et clone sera en premier lieu un de ces constructors
** cas d'utilisation: range d'entiers de Jessie, Flottants -> double ou single
containeurs pour Adacore et Claire
* extraction vers Caml
** PRIORITAIRE, JCF, ANDREI, besoin pour cours aux JFLA en janvier 2012
* FRANCOIS new tools
** merge why3html and why3stats into a new executable why3report
** move -latex from why3replayer to why3report
** document why3report
* CLAUDE provers
** fix support for newer Z3, CVC3 and Alt-Ergo, allow several version
** Ensure that we kill a prover after some time (ressurect %T ? with a
meaning like twice the value of %t ?), because we cannot be sure they always
honor their own -timeout option.
* Ensure that we kill a prover after some time (ressurect %T ? with a * FRANCOIS CLAUDE, move Session module and its dependencies into the Why3 library
meaning like twice the value of %t ?), because we cannot be sure they always ** but avoid duplication with session_ro
honor their own -timeout option. ** avoid also duplication of type like prover_data record
** do not include task and transf in the data type, so that
one can reload, and redetect provers
** session + session_ro -> session_data + session_dynamic
* update the BTS
* API for programs * efficiency issues
** understand problems when large number of goals (cf D Mentré examples)
* reject global "val"s in typing environment for logic decls. * ALL fix bug and update the BTS
** reject global "val"s in typing environment for logic decls.
* Coq plugin * DELAYED Coq plugin
* Coq realization of theories * Coq realization of theories
** corriger l'incoherence
* DOC: * DOC:
** complete api.tex: explain how to build theories, apply ** complete api.tex: explain how to build theories, apply
...@@ -81,7 +112,7 @@ ...@@ -81,7 +112,7 @@
(partially done, but no shortcut) (partially done, but no shortcut)
** restore provers detection in the middle of a session. ** restore provers detection in the middle of a session.
+ todo: run detection immediately at start up if conf file absent or + todo: run detection immediately at start up if conf file absent or
outdated outdated. should become doable with the new Session module
=== Roadmap for release 0.71 ======================== === Roadmap for release 0.71 ========================
