library: two versions of witness
the constructive version is now in witness.Nat
the non-constructive version is witness.Witness
parent 70868534
...@@ -6,7 +6,7 @@ ...@@ -6,7 +6,7 @@
<prover id="2" name="CVC4" version="1.5" timelimit="1" steplimit="0" memlimit="1000"/> <prover id="2" name="CVC4" version="1.5" timelimit="1" steplimit="0" memlimit="1000"/>
<prover id="4" name="Eprover" version="1.8-001" timelimit="16" steplimit="0" memlimit="1000"/> <prover id="4" name="Eprover" version="1.8-001" timelimit="16" steplimit="0" memlimit="1000"/>
<file name="../../../stdlib/witness.mlw" proved="true"> <file name="../../../stdlib/witness.mlw" proved="true">
<theory name="Witness" proved="true"> <theory name="Nat" proved="true">
<goal name="VC witness" expl="VC for witness" proved="true"> <goal name="VC witness" expl="VC for witness" proved="true">
<transf name="split_vc" proved="true" > <transf name="split_vc" proved="true" >
<goal name="VC witness.0" expl="postcondition" proved="true"> <goal name="VC witness.0" expl="postcondition" proved="true">
(** {1 Constructive existence of a witness} (** {1 Witnesses of existential proofs} *)
(** {2 Non-constructive existence of a witness} *)
module Witness
val ghost function witness (p: 'a -> bool) : 'a
requires { exists x. p x }
ensures { p result }
(** {2 Constructive existence of a witness}
Given a predicate `p` over integers and the existence of Given a predicate `p` over integers and the existence of
a nonnegative integer `n` such that `p n`, one can build a nonnegative integer `n` such that `p n`, one can build
a witness using a linear search starting from 0. a witness using a linear search starting from 0.
The difficulty here is to prove the termination of the The difficulty here is to prove termination. We use a custom
function implementing this linear search. We use a custom
variant predicate and we prove the accessibility of all variant predicate and we prove the accessibility of all
integers for which there exists a witnes above. integers for which there exists a witnes above.
...@@ -15,17 +26,19 @@ ...@@ -15,17 +26,19 @@
and Jean-François Monin). and Jean-François Monin).
module Witness module Nat
use int.Int use int.Int
use relations.WellFounded use relations.WellFounded
(** since a custom variant relation has to be a toplevel predicate symbol,
we store the predicate `p` inside the variant expression *)
predicate r (x y: ((int->bool),int)) = predicate r (x y: ((int->bool),int)) =
let p, x = x in let p, x = x in
let q, y = y in let q, y = y in
p = q && x = y+1 > 0 && not (p y) p = q && x = y+1 > 0 && not (p y)
let witness (p: int -> bool) : int let function witness (p: int -> bool) : int
requires { exists n. n >= 0 /\ p n } requires { exists n. n >= 0 /\ p n }
ensures { result >= 0 /\ p result } ensures { result >= 0 /\ p result }
= let lemma l1 (x: int) = let lemma l1 (x: int)
