Commit 1572959f authored by Guillaume Melquiond's avatar Guillaume Melquiond
Use the proper base name for the deploy image.
parent cc1344c8
...@@ -3,7 +3,7 @@ ...@@ -3,7 +3,7 @@
set -e set -e
autoconf && (automake --add-missing 2> /dev/null || true) autoconf && (automake --add-missing 2> /dev/null || true)
docker build -t bench-image-system -f misc/Dockerfile.init . docker build -t bench-image-system-stable -f misc/Dockerfile.init .
IMAGE=$CI_REGISTRY_IMAGE:$(echo $CI_COMMIT_REF_NAME | tr -cs "[:alnum:].\n" "-") IMAGE=$CI_REGISTRY_IMAGE:$(echo $CI_COMMIT_REF_NAME | tr -cs "[:alnum:].\n" "-")
docker build -t $IMAGE -f misc/Dockerfile.deploy . docker build -t $IMAGE -f misc/Dockerfile.deploy .
docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
