Commit 13c0b591 authored by Raphael Rieu-Helft's avatar Raphael Rieu-Helft
Extraction: inline more proxy variables
parent 22d11b93
...@@ -268,10 +268,10 @@ module Print = struct ...@@ -268,10 +268,10 @@ module Print = struct
(print_expr info) e (print_list_next newline (print_branch info)) bl (print_expr info) e (print_list_next newline (print_branch info)) bl
(print_list_next newline (print_xbranch true info)) xl (print_list_next newline (print_xbranch true info)) xl
| Eassign al -> | Eassign al ->
let assign fmt (rho, rs, pv) = let assign fmt (rho, rs, e) =
fprintf fmt "@[<hov 2>%a.%a <-@ %a@]" fprintf fmt "@[<hov 2>%a.%a <-@ %a@]"
(print_lident info) (pv_name rho) (print_lident info) rs.rs_name (print_lident info) (pv_name rho) (print_lident info) rs.rs_name
(print_lident info) (pv_name pv) in (print_expr info) e in
begin match al with begin match al with
| [] -> assert false | [a] -> assign fmt a | [] -> assert false | [a] -> assign fmt a
| al -> fprintf fmt "@[(%a)]" (print_list semi assign) al end | al -> fprintf fmt "@[(%a)]" (print_list semi assign) al end
...@@ -408,6 +408,8 @@ module Translate = struct ...@@ -408,6 +408,8 @@ module Translate = struct
let rm_ghost (_, rs, _) = not (rs_ghost rs) in let rm_ghost (_, rs, _) = not (rs_ghost rs) in
let al = List.filter rm_ghost al in let al = List.filter rm_ghost al in
let e_of_var pv = ML.e_var pv (ML.I pv.pv_ity) MaskVisible eff attrs in
let al = List.map (fun (pv1, rs, pv2) -> (pv1, rs, e_of_var pv2)) al in
ML.e_assign al (ML.I e.e_ity) mask eff attrs ML.e_assign al (ML.I e.e_ity) mask eff attrs
| Ematch (e1, bl, xl) when e_ghost e1 -> | Ematch (e1, bl, xl) when e_ghost e1 ->
assert (Mxs.is_empty xl); (* Expr ensures this for the time being *) assert (Mxs.is_empty xl); (* Expr ensures this for the time being *)
...@@ -616,6 +618,15 @@ module Transform = struct ...@@ -616,6 +618,15 @@ module Transform = struct
* Spv.for_all is_not_write spv *) * Spv.for_all is_not_write spv *)
Spv.is_empty (pvs_affected spv_mreg spv) Spv.is_empty (pvs_affected spv_mreg spv)
let rec can_inline ({e_effect = eff1} as e1) ({e_effect = eff2} as e2) =
match e2.e_node with
| Evar _ | Eapp _ | Eassign _ | Econst _ -> true
| Eblock el -> List.for_all (fun e -> can_inline e1 e) el
| Elet (Lvar (_, {e_effect = eff1'}), e2') ->
no_reads_writes_conflict eff1.eff_reads eff1'.eff_writes
&& can_inline e1 e2'
| _ -> no_reads_writes_conflict eff1.eff_reads eff2.eff_writes
let mk_list_eb ebl f = let mk_list_eb ebl f =
let mk_acc e (e_acc, s_acc) = let mk_acc e (e_acc, s_acc) =
let e, s = f e in e::e_acc, Spv.union s s_acc in let e, s = f e in e::e_acc, Spv.union s s_acc in
...@@ -627,10 +638,10 @@ module Transform = struct ...@@ -627,10 +638,10 @@ module Transform = struct
match e.e_node with match e.e_node with
| Evar pv -> begin try Mpv.find pv subst, Spv.singleton pv | Evar pv -> begin try Mpv.find pv subst, Spv.singleton pv
with Not_found -> e, Spv.empty end with Not_found -> e, Spv.empty end
| Elet (Lvar (pv, ({e_effect = eff1} as e1)), ({e_effect = eff2} as e2)) | Elet (Lvar (pv, ({e_effect = eff1} as e1)), e2)
when Sattr.mem Expr.proxy_attr pv.pv_vs.vs_name.id_attrs && when Sattr.mem Expr.proxy_attr pv.pv_vs.vs_name.id_attrs &&
eff_pure eff1 && eff_pure eff1 &&
no_reads_writes_conflict eff1.eff_reads eff2.eff_writes -> can_inline e1 e2 ->
let e1, s1 = expr info subst e1 in let e1, s1 = expr info subst e1 in
let e2, s2 = add_subst pv e1 e2 in let e2, s2 = add_subst pv e1 e2 in
let s_union = Spv.union s1 s2 in let s_union = Spv.union s1 s2 in
...@@ -690,8 +701,14 @@ module Transform = struct ...@@ -690,8 +701,14 @@ module Transform = struct
| Eraise (exn, Some e) -> | Eraise (exn, Some e) ->
let e, spv = expr info subst e in let e, spv = expr info subst e in
mk (Eraise (exn, Some e)), spv mk (Eraise (exn, Some e)), spv
| Eassign _al -> | Eassign al ->
e, Spv.empty let al, s =
List.fold_left
(fun (accl, spv) (pv,rs,e) ->
let e, s = expr info subst e in
((pv, rs, e)::accl, Spv.union spv s))
([], Spv.empty) al in
mk (Eassign (List.rev al)), s
| Econst _ | Eabsurd | Ehole | Eany _ -> e, Spv.empty | Econst _ | Eabsurd | Ehole | Eany _ -> e, Spv.empty
| Eignore e -> | Eignore e ->
...@@ -1028,7 +1028,7 @@ module MLToC = struct ...@@ -1028,7 +1028,7 @@ module MLToC = struct
d@defs, C.(Sseq(Sseq(s,assigns), Sblock b)) d@defs, C.(Sseq(Sseq(s,assigns), Sblock b))
| Ematch _ -> raise (Unsupported "pattern matching") | Ematch _ -> raise (Unsupported "pattern matching")
| Eabsurd -> assert false | Eabsurd -> assert false
| Eassign ([pv, ({rs_field = Some _} as rs), v]) -> | Eassign ([pv, ({rs_field = Some _} as rs), e2]) ->
let t = let t =
match query_syntax info.syntax rs.rs_name with match query_syntax info.syntax rs.rs_name with
| Some s -> | Some s ->
...@@ -1047,7 +1047,8 @@ module MLToC = struct ...@@ -1047,7 +1047,8 @@ module MLToC = struct
in in
C.Esyntax(s,ty_of_ty info rty, rtyargs, params) C.Esyntax(s,ty_of_ty info rty, rtyargs, params)
| None -> raise (Unsupported ("assign not in driver")) in | None -> raise (Unsupported ("assign not in driver")) in
[], C.(Sexpr(Ebinop(Bassign, t, C.Evar v.pv_vs.vs_name))) let v = expr info env e2 in
[], C.(Sexpr(Ebinop(Bassign, t, simplify_expr v)))
| Eassign _ -> raise (Unsupported "assign") | Eassign _ -> raise (Unsupported "assign")
| Ehole | Eany _ -> assert false | Ehole | Eany _ -> assert false
| Eexn (_,_,e) -> expr info env e | Eexn (_,_,e) -> expr info env e
...@@ -696,9 +696,9 @@ let rec interp_expr info (e:Mltree.expr) : value = ...@@ -696,9 +696,9 @@ let rec interp_expr info (e:Mltree.expr) : value =
end end
| Eassign l -> | Eassign l ->
List.iter List.iter
(fun (pvs, rs, v) -> (fun (pvs, rs, e) ->
let fld = fd_of_rs rs in let fld = fd_of_rs rs in
let value = get v info in let value = interp_expr info e in
match get pvs info with match get pvs info with
| Vconstr(c, args) -> | Vconstr(c, args) ->
let rec aux cargs args = let rec aux cargs args =
...@@ -54,7 +54,7 @@ and expr_node = ...@@ -54,7 +54,7 @@ and expr_node =
| Efun of var list * expr | Efun of var list * expr
| Elet of let_def * expr | Elet of let_def * expr
| Eif of expr * expr * expr | Eif of expr * expr * expr
| Eassign of (pvsymbol * rsymbol * pvsymbol) list | Eassign of (pvsymbol * rsymbol * expr) list
| Ematch of expr * reg_branch list * exn_branch list | Ematch of expr * reg_branch list * exn_branch list
| Eblock of expr list | Eblock of expr list
| Ewhile of expr * expr | Ewhile of expr * expr
...@@ -461,10 +461,10 @@ module Print = struct ...@@ -461,10 +461,10 @@ module Print = struct
(protect_on paren "begin match @[%a@] with@\n@[<hov>%a@]@\nend") (protect_on paren "begin match @[%a@] with@\n@[<hov>%a@]@\nend")
(print_expr info) e (print_list newline (print_branch info)) pl (print_expr info) e (print_list newline (print_branch info)) pl
| al -> fprintf fmt "@[begin %a end@]" (print_list semi assign) al end | al -> fprintf fmt "@[begin %a end@]" (print_list semi assign) al end
