Commit 12edf166 authored by MARCHE Claude's avatar MARCHE Claude
tptp printers: produce an annotation for axioms declared as rewrite rules
parent af68079e
...@@ -57,6 +57,7 @@ type info = { ...@@ -57,6 +57,7 @@ type info = {
info_num : tptp_number; info_num : tptp_number;
info_srt : ty Mty.t ref; info_srt : ty Mty.t ref;
info_urg : string list ref; info_urg : string list ref;
info_rules : Decl.Spr.t;
let complex_type = Wty.memoize 3 (fun ty -> let complex_type = Wty.memoize 3 (fun ty ->
...@@ -247,22 +248,34 @@ let print_decl info fmt d = match d.d_node with ...@@ -247,22 +248,34 @@ let print_decl info fmt d = match d.d_node with
"TPTP does not support inductive predicates, use eliminate_inductive" "TPTP does not support inductive predicates, use eliminate_inductive"
| Dprop (Paxiom, pr, _) when Mid.mem pr.pr_name info.info_syn -> () | Dprop (Paxiom, pr, _) when Mid.mem pr.pr_name info.info_syn -> ()
| Dprop (Paxiom, pr, f) -> | Dprop (Paxiom, pr, f) ->
let head = if info.info_fmt = FOF then "fof" else "tff" in (*
fprintf fmt "@[<hov 2>%s(%a, axiom,@ %a).@]@\n@\n" Format.eprintf "Dprop for %s: rewrite rules:" pr.pr_name.id_string;
head print_pr pr (print_fmla info) f Spr.iter (fun pr -> Format.eprintf " %s" pr.pr_name.id_string) info.info_rules;
Format.eprintf "@.";
let annotation = if Spr.mem pr info.info_rules then ",rewrite" else "" in
fprintf fmt "@[<hov 2>%s(%a, axiom,@ %a%s).@]@\n@\n"
head print_pr pr (print_fmla info) f annotation
| Dprop (Pgoal, pr, f) -> | Dprop (Pgoal, pr, f) ->
let head = if info.info_fmt = FOF then "fof" else "tff" in let head = if info.info_fmt = FOF then "fof" else "tff" in
fprintf fmt "@[<hov 2>%s(%a, conjecture,@ %a).@]@\n" fprintf fmt "@[<hov 2>%s(%a, conjecture,@ %a).@]@\n"
head print_pr pr (print_fmla info) f head print_pr pr (print_fmla info) f
| Dprop ((Plemma|Pskip), _, _) -> assert false | Dprop ((Plemma|Pskip), _, _) -> assert false
let print_decls fm nm = let print_decls fm nm rew_rules =
Format.eprintf "rewrite rules:";
Spr.iter (fun pr -> Format.eprintf " %s" pr.pr_name.id_string) rew_rules;
let print_decl (sm,fm,ct) fmt d = let print_decl (sm,fm,ct) fmt d =
let info = { info_syn = sm; let info = { info_syn = sm;
info_fmt = fm; info_fmt = fm;
info_num = nm; info_num = nm;
info_srt = ref ct; info_srt = ref ct;
info_urg = ref [] } in info_urg = ref [];
info_rules = rew_rules } in
try print_decl info fmt d; try print_decl info fmt d;
(sm,fm,!(info.info_srt)), !(info.info_urg) (sm,fm,!(info.info_srt)), !(info.info_urg)
with Unsupported s -> raise (UnsupportedDecl (d,s)) in with Unsupported s -> raise (UnsupportedDecl (d,s)) in
...@@ -272,7 +285,6 @@ let print_decls fm nm = ...@@ -272,7 +285,6 @@ let print_decls fm nm =
Trans.fold print_decl ((sm,fm,Mty.empty),[])) Trans.fold print_decl ((sm,fm,Mty.empty),[]))
let print_task fm nm = let print_task fm nm =
let print_decls = print_decls fm nm in
fun args ?old:_ fmt task -> fun args ?old:_ fmt task ->
(* In trans-based p-printing [forget_all] is a no-no *) (* In trans-based p-printing [forget_all] is a no-no *)
(* forget_all ident_printer; *) (* forget_all ident_printer; *)
...@@ -281,7 +293,10 @@ let print_task fm nm = ...@@ -281,7 +293,10 @@ let print_task fm nm =
let rec print = function let rec print = function
| x :: r -> print r; Pp.string fmt x | x :: r -> print r; Pp.string fmt x
| [] -> () in | [] -> () in
print (snd (Trans.apply print_decls task)); let print_decls_with_meta =
Trans.on_tagged_pr Compute.meta_rewrite (print_decls fm nm)
in
print (snd (Trans.apply print_decls_with_meta task));
pp_print_flush fmt () pp_print_flush fmt ()
let () = let () =
...@@ -429,7 +444,9 @@ let print_dfg args ?old:_ fmt task = ...@@ -429,7 +444,9 @@ let print_dfg args ?old:_ fmt task =
info_fmt = FOF; info_fmt = FOF;
info_num = TPTP; info_num = TPTP;
info_urg = ref []; info_urg = ref [];
info_srt = ref Mty.empty } in info_srt = ref Mty.empty ;
info_rules = Spr.empty;
} in
let dl = Task.task_decls task in let dl = Task.task_decls task in
let tl = List.filter (is_type info) dl in let tl = List.filter (is_type info) dl in
let fl = List.filter (is_function info) dl in let fl = List.filter (is_function info) dl in
...@@ -444,6 +444,15 @@ version_ok = "0.7.1" ...@@ -444,6 +444,15 @@ version_ok = "0.7.1"
command = "%l/why3-cpulimit %T 0 -s %e -p0 -itptp -max-size %mM -max-time %ts %f" command = "%l/why3-cpulimit %T 0 -s %e -p0 -itptp -max-size %mM -max-time %ts %f"
driver = "drivers/zenon.drv" driver = "drivers/zenon.drv"
[ATP zenon_modulo]
name = "Zenon Modulo"
exec = "zenon_modulo"
version_switch = "-v"
version_regexp = "zenon_modulo version \\([0-9.]+\\)"
version_ok = "0.4.0"
driver = "drivers/zenon_modulo.drv"
[ATP iprover] [ATP iprover]
name = "iProver" name = "iProver"
exec = "iprover" exec = "iprover"
...@@ -9,3 +9,5 @@ ...@@ -9,3 +9,5 @@
val meta_rewrite : Theory.meta
theory T
use import set.Set
meta "rewrite" prop mem_empty
meta "rewrite" prop add_def1
goal g: mem 1 (add 2 (add 1 (add 0 empty)))
