Commit 0a69b161 authored by Sylvain Dailler's avatar Sylvain Dailler
Merge branch 'rebase_collecting_counterex'
Merge typing.ml and remove ref that is now apparently a keyword.
parents 10e54f43 37c89aad
...@@ -39,7 +39,12 @@ run () { ...@@ -39,7 +39,12 @@ run () {
sed 's/ ([0-9]\+\.[0-9]\+s)//' | \ sed 's/ ([0-9]\+\.[0-9]\+s)//' | \
# This ad hoc sed removes diff between Timeout and Unknown (unknown) # This ad hoc sed removes diff between Timeout and Unknown (unknown)
# when running from platform with different speed. # when running from platform with different speed.
sed -r 's/(Timeout|Unknown \(unknown\))/Timeout or Unknown/' >> "$f.out" sed -r 's/(Timeout|Unknown \(unknown\))/Timeout or Unknown/' | \
# ad hoc sed to remove the directory of the stdlib that can be found
# inside labels attribute [@at:'Old:loc:/home/.../stdlib/array.mlw
# TODO temporary as this comes from incorrect locations generated in
# a[i] <- x like terms.
sed -r 's/\:loc\:.*\]/\:loc\:location\]/' >> "$f.out"
printf "SP $2 ($1)... " printf "SP $2 ($1)... "
echo "Strongest Postcondition" >> "$f.out" echo "Strongest Postcondition" >> "$f.out"
$dir/../bin/why3prove.opt --debug print_model_attrs --debug vc_sp -P "$1,counterexamples" --timelimit 1 -a split_vc "$2.mlw" | \ $dir/../bin/why3prove.opt --debug print_model_attrs --debug vc_sp -P "$1,counterexamples" --timelimit 1 -a split_vc "$2.mlw" | \
...@@ -48,7 +53,12 @@ run () { ...@@ -48,7 +53,12 @@ run () {
if cmp "$f.oracle" "$f.out" > /dev/null 2>&1 ; then if cmp "$f.oracle" "$f.out" > /dev/null 2>&1 ; then
echo "ok" echo "ok"
else else
...@@ -26,11 +26,11 @@ module M ...@@ -26,11 +26,11 @@ module M
goal g7: forall l: mylist. l = Nil goal g7: forall l: mylist. l = Nil
(* use list.List use list.List
use list.Length use list.Length
goal g: forall l: list int. length l = 0 goal g: forall l: list int. length l = 0
...@@ -14,6 +14,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -14,6 +14,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
"val" : "0" }] } } "val" : "0" }] } }
bench/ce/algebraic_type.mlw M g4: Timeout or Unknown bench/ce/algebraic_type.mlw M g4: Timeout or Unknown
Counter-example model:File algebraic_type.mlw:
Line 12:
"val" : {"apply" : "A" ,
"list" : [] } }
bench/ce/algebraic_type.mlw M g5: Timeout or Unknown bench/ce/algebraic_type.mlw M g5: Timeout or Unknown
Counter-example model:File algebraic_type.mlw: Counter-example model:File algebraic_type.mlw:
Line 16: Line 16:
...@@ -23,7 +29,22 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -23,7 +29,22 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
"val" : "1" }] } } "val" : "1" }] } }
bench/ce/algebraic_type.mlw M g1: Timeout or Unknown bench/ce/algebraic_type.mlw M g1: Timeout or Unknown
Line 25:
l, [[@introduced], [@model_trace:l]] = {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "-1" },
{"type" : "Apply" , "val" : {"apply" : "Nil" ,
"list" : [] } }] } }
bench/ce/algebraic_type.mlw M g7: Timeout or Unknown bench/ce/algebraic_type.mlw M g7: Timeout or Unknown
Line 27:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "0" },
bench/ce/algebraic_type.mlw M g: Timeout or Unknown
Strongest Postcondition Strongest Postcondition
bench/ce/algebraic_type.mlw M G: Timeout or Unknown bench/ce/algebraic_type.mlw M G: Timeout or Unknown
...@@ -40,6 +61,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -40,6 +61,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
Line 12:
"list" : [] } }
Line 16: Line 16:
...@@ -49,4 +76,19 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -49,4 +76,19 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
Line 25:
Line 27:
bench/ce/algebraic_type.mlw M g4: Unknown (sat) bench/ce/algebraic_type.mlw M g4: Unknown (sat)
Line 12:
"list" : [] } }
bench/ce/algebraic_type.mlw M g5: Unknown (sat) bench/ce/algebraic_type.mlw M g5: Unknown (sat)
Line 16: Line 16:
...@@ -23,7 +29,34 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -23,7 +29,34 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
Line 25:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "17" },
{"type" : "Apply" , "val" : {"apply" : "Cons" ,
"list" : [{"type" : "Integer" , "val" : "160" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "158" },
"list" : [{"type" : "Integer" , "val" : "164" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "162" },
"list" : [] } }] } }] } }] } }] } }] } }
Line 27:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "21" },
"list" : [{"type" : "Integer" , "val" : "10" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "9" },
"list" : [{"type" : "Integer" , "val" : "7" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "8" },
bench/ce/algebraic_type.mlw M G: Unknown (sat) bench/ce/algebraic_type.mlw M G: Unknown (sat)
...@@ -40,6 +73,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -40,6 +73,12 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
Line 12:
"list" : [] } }
Line 16: Line 16:
...@@ -49,4 +88,31 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" , ...@@ -49,4 +88,31 @@ x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
Line 25:
Line 27:
module Array
use int.Int
use map.Map
type array = private {
mutable ghost elts : int -> int;
length : int
} invariant { 0 <= length }
function ([]) (a: array) (i: int) : int = a.elts i
val ([]) (a: array) (i: int) : int
requires { [@expl:index in array bounds] 0 <= i < length a }
ensures { result = a[i] }
val ghost function ([<-]) (a: array) (i: int) (v: int): array
ensures { result.length = a.length }
ensures { result.elts = Map.set a.elts i v }
val ([]<-) (a: array) (i: int) (v: int) : unit writes {a}
ensures { a.elts = Map.set (old a).elts i v }
ensures { a = (old a)[i <- v] }
module A
use int.Int
use Array
let f1 (a:array) : int
= a[0]
let f2 (a:array) : unit
requires { a.length >= 2 }
ensures { a[0] <> a[1] }
= a[0] <- 42
module B
use int.Int
use array.Array
clone array.Sorted with
type elt=int,
predicate le=(<=)
let f1 (a:array int) : unit
ensures { sorted a }
let f2 (a:array int) : array int
ensures { sorted result }
= a
\ No newline at end of file
Weakest Precondition
bench/ce/array_mono.mlw Array VC array: Valid
bench/ce/array_mono.mlw A VC f1: Timeout or Unknown
Counter-example model:File array_mono.mlw:
Line 35:
a, [[@introduced], [@model_trace:a]] = {"type" : "Record" ,
"val" : {"Field" : [{"field" : "elts" , "value" : {"type" : "Array" ,
"val" : [{"others" : {"type" : "Integer" , "val" : "0" } }] } },
{"field" : "length" , "value" : {"type" : "Integer" ,
Line 36:
bench/ce/array_mono.mlw A VC f2: Valid
bench/ce/array_mono.mlw A VC f2: Timeout or Unknown
Line 38:
a, [[@introduced], [@model_trace:a],
[@at:'Old:loc:location],
[@at:'Old:loc:location] = {"type" : "Record" ,
"val" : [{"indice" : "0" , "value" : {"type" : "Integer" , "val" : "42" } },
{"indice" : "1" , "value" : {"type" : "Integer" , "val" : "42" } },
{"others" : {"type" : "Integer" , "val" : "0" } }] } }, {"field" : "length" ,
"val" : "2" } }] } }
Line 40:
Line 41:
Line 35:
Line 36:
Line 38:
Line 40:
Line 35:
Line 36:
Line 38:
{"others" : {"type" : "Integer" , "val" : "4" } }] } }, {"field" : "length" ,
Line 40:
Line 41:
Line 35:
Line 36:
Line 38:
Line 40:
...@@ -2,55 +2,154 @@ Weakest Precondition ...@@ -2,55 +2,154 @@ Weakest Precondition
bench/ce/array_records.mlw Array_records VC var_overwrite: Timeout or Unknown bench/ce/array_records.mlw Array_records VC var_overwrite: Timeout or Unknown
Counter-example model:File array_records.mlw: Counter-example model:File array_records.mlw:
Line 23: Line 23:
i, [[@introduced], [@model_trace:i]] = {"type" : "Integer" , a, [[@introduced], [@model_trace:a]] = {"type" : "Record" ,
"val" : {"Field" : [{"field" : "first_value" ,
"value" : {"type" : "Integer" , "val" : "3" } }, {"field" : "flag" ,
"value" : {"type" : "Boolean" , "val" : true } }, {"field" : "second_value" ,
"value" : {"type" : "Integer" , "val" : "5" } }] } }
i, [[@introduced],
"val" : "-1" } "val" : "-1" }
Line 27: Line 27:
i, [[@introduced],
Line 23: Line 23:
i, [[@introduced],
Line 27: Line 27:
i, [[@introduced],
Line 23: Line 23:
i, [[@introduced],
Line 27: Line 27:
i, [[@introduced],
Line 23: Line 23:
i, [[@introduced], [@model_trace:i]] = {"type" : "Integer" , a, [[@introduced], [@model_trace:a],
i, [[@introduced],
Line 27:
Line 28: Line 28:
i, [[@introduced],
Line 23: Line 23:
i, [[@introduced],
Line 27:
