GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
f9f70e9f
f9f70e9f
Jean-Christophe Filliâtre
typage des declarations de types
b615b5df
9
9 changed files
100 additions
11 deletions
+100
-11
Makefile.in
Makefile.in
+1
-1
lib/util.ml
lib/util.ml
+10
lib/util.mli
lib/util.mli
+3
src/lexer.mli
src/lexer.mli
+1
-1
src/lexer.mll
src/lexer.mll
+4
-4
src/main.ml
src/main.ml
+6
-3
src/test.why
src/test.why
+3
-2
src/typing.ml
src/typing.ml
+51
src/typing.mli
src/typing.mli
+21
Makefile.in
f9f70e9f
@@ -88,7 +88,7 @@ check: $(BINARY) $(PRELUDE)
# why
# why
LIBCMO
lib/pp.cmo lib/loc.cmo
LIBCMO
lib/util.cmo
CMO
$(LIBCMO)
src/name.cmo src/hashcons.cmo src/term.cmo src/pretty.cmo
CMO
$(LIBCMO)
src/parser.cmo src/lexer.cmo src/typing.cmo src/main.cmo
lib/util.ml
f9f70e9f
let
map_fold_left
f
acc
l
let
acc
rev
fold_left
fun
acc
rev
e
let
acc
e
f
acc
e
in
acc
e
rev
acc
l
in
acc
rev
rev
lib/util.mli
f9f70e9f
val
map_fold_left
acc
a
acc
b
acc
a
list
acc
b
list
src/lexer.mli
f9f70e9f
type
error
type
error
exception
Lexical_e
rror
of
error
exception
E
rror
of
error
val
report
Format
formatter
error
unit
val
report
Format
formatter
error
unit
src/lexer.mll
f9f70e9f
@@ -12,7 +12,7 @@
@@ -12,7 +12,7 @@
UnterminatedComment
UnterminatedComment
UnterminatedString
UnterminatedString
exception
Lexical_e
rror
of
error
exception
E
rror
of
error
let
report
fmt
function
let
report
fmt
function
IllegalCharacter
c
fprintf
fmt
"illegal character %c"
c
IllegalCharacter
c
fprintf
fmt
c
@@ -213,7 +213,7 @@ rule token = parse
eof
eof
EOF
EOF
_
as
c
_
as
c
raise
Lexical_e
rror
IllegalCharacter
c
raise
E
rror
IllegalCharacter
c
comment
parse
comment
parse
@@ -223,7 +223,7 @@ and comment = parse
newline
newline
newline
lexbuf
comment
lexbuf
newline
lexbuf
comment
lexbuf
eof
eof
raise
Lexical_e
rror
UnterminatedComment
raise
E
rror
UnterminatedComment
_
_
comment
lexbuf
comment
lexbuf
@@ -235,7 +235,7 @@ and string = parse
newline
newline
newline
lexbuf
Buffer
add_char
string_buf
'\n'
string
lexbuf
newline
lexbuf
Buffer
add_char
string_buf
'\n'
string
lexbuf
eof
eof
raise
Lexical_e
rror
UnterminatedString
raise
E
rror
UnterminatedString
_
as
c
_
as
c
Buffer
add_char
string_buf
c
string
lexbuf
Buffer
add_char
string_buf
c
string
lexbuf
src/main.ml
f9f70e9f
@@ -19,12 +19,14 @@ open Format
let
file
Sys
argv
let
file
Sys
argv
let
rec
report
fmt
function
let
rec
report
fmt
function
Lexer
Lexical_e
rror
e
Lexer
E
rror
e
fprintf
fmt
"lexical error: %a"
Lexer
report
e
fprintf
fmt
"lexical error: %a"
Lexer
report
e
Loc
Located
loc
e
Loc
Located
loc
e
fprintf
fmt
"%a%a"
Loc
report_position
loc
report
e
fprintf
fmt
"%a%a"
Loc
report_position
loc
report
e
Parsing
Parse_error
Parsing
Parse_error
fprintf
fmt
"syntax error"
fprintf
fmt
"syntax error"
Typing
Error
e
Typing
report
fmt
e
e
e
fprintf
fmt
"anomaly: %s"
Printexc
to_string
e
fprintf
fmt
"anomaly: %s"
Printexc
to_string
e
@@ -33,8 +35,9 @@ let () =
let
c
open_in
file
in
let
c
open_in
file
in
let
lb
Lexing
from_channel
c
in
let
lb
Lexing
from_channel
c
in
Loc
set_file
file
lb
Loc
set_file
file
lb
let
_f
Lexer
parse_logic_file
lb
in
let
f
Lexer
parse_logic_file
lb
in
close_in
c
close_in
c
ignore
fold_left
Typing
add
Typing
empty
f
e
e
eprintf
"%a@."
report
e
eprintf
"%a@."
report
e
exit
exit
src/test.why
f9f70e9f
@@ -3,6 +3,7 @@
@@ -3,6 +3,7 @@
type 'a list
type 'a list
logic nil : 'a list
(* logic nil : 'a list *)
logic cons : 'a, 'a list -> 'a list
(* logic cons : 'a, 'a list -> 'a list *)
src/typing.ml
f9f70e9f
open
Util
open
Format
open
Term
open
Term
(** errors *)
type
error
ClashType
of
string
BadTypeArity
of
string
exception
Error
of
error
let
error
loc
e
match
loc
None
raise
Error
e
Some
loc
raise
Loc
Located
loc
Error
e
let
report
fmt
function
ClashType
s
fprintf
fmt
"clash with previous type %s"
s
BadTypeArity
s
fprintf
fmt
"duplicate type parameter %s"
s
module
Map
Make
String
module
Map
Make
String
type
env
type
env
@@ -19,3 +39,34 @@ let empty = {
vars
empty
vars
empty
let
find_tysymbol
s
env
find
s
env
tysymbols
let
find_fsymbol
s
env
find
s
env
fsymbols
let
find_psymbol
s
env
find
s
env
psymbols
let
find_tyvar
s
env
find
s
env
tyvars
let
find_var
s
env
find
s
env
vars
(** typing *)
let
term
env
t
assert
false
(*TODO*)
(** building environments *)
open
Ptree
let
add_type
loc
ext
sl
s
env
if
mem
s
env
tysymbols
then
error
loc
ClashType
s
let
add_ty_var
env
x
if
mem
x
env
tyvars
then
error
loc
BadTypeArity
x
let
v
Name
from_string
x
in
env
tyvars
add
x
v
env
tyvars
v
in
let
_
vl
map_fold_left
add_ty_var
env
sl
in
let
ty
Ty
create_tysymbol
Name
from_string
s
vl
None
in
env
tysymbols
add
s
ty
env
tysymbols
let
add
env
function
TypeDecl
loc
ext
sl
s
add_type
loc
ext
sl
s
env
_
assert
false
(*TODO*)
src/typing.mli
f9f70e9f
@@ -7,3 +7,24 @@ type env
val
empty
env
val
empty
env
val
find_tysymbol
string
env
tysymbol
val
find_fsymbol
string
env
fsymbol
val
find_psymbol
string
env
psymbol
val
find_tyvar
string
env
vsymbol
val
find_var
string
env
vsymbol
(** typing *)
val
term
env
Ptree
lexpr
term
val
add
env
Ptree
logic_decl
env
(** error reporting *)
type
error
exception
Error
of
error
val
report
Format
formatter
error
unit
