Commit f964bd96 authored by François Bobot's avatar François Bobot
encoding_arrays : non of the type are removed so we can let them
parent e2410f4b
...@@ -234,9 +234,7 @@ let fold_map task_hd ((env:env),task) = ...@@ -234,9 +234,7 @@ let fold_map task_hd ((env:env),task) =
match task_hd.task_decl.td_node with match task_hd.task_decl.td_node with
| Use _ | Clone _ | Meta _ -> env,add_tdecl task task_hd.task_decl | Use _ | Clone _ | Meta _ -> env,add_tdecl task task_hd.task_decl
| Decl d -> match d.d_node with | Decl d -> match d.d_node with
| Dtype [_,Tabstract] -> (env,task) | Dtype [_,Tabstract] -> env,add_tdecl task task_hd.task_decl
(* Nothing here since the type kept are already defined and the other
will be lazily defined *)
| Dtype _ -> Printer.unsupportedDecl | Dtype _ -> Printer.unsupportedDecl
d "encoding_decorate : I can work only on abstract\ d "encoding_decorate : I can work only on abstract\
type which are not in recursive bloc." type which are not in recursive bloc."
