Commit f9063bf8 authored by Andrei Paskevich's avatar Andrei Paskevich
treat enums and records in the "alt-ergo-old" non-memoizing printer
parent ac560696
...@@ -270,15 +270,25 @@ let print_decl info fmt d = match d.d_node with ...@@ -270,15 +270,25 @@ let print_decl info fmt d = match d.d_node with
let print_decl info fmt = catch_unsupportedDecl (print_decl info fmt) let print_decl info fmt = catch_unsupportedDecl (print_decl info fmt)
let add_projection (csm,pjs,axs) = function
| [Theory.MAls ls; Theory.MAls cs; Theory.MAint ind; Theory.MApr pr] ->
let csm = try Array.set (Mls.find cs csm) ind ls; csm
with Not_found ->
Mls.add cs (Array.make (List.length cs.ls_args) ls) csm in
csm, Sls.add ls pjs, Spr.add pr axs
| _ -> assert false
let print_task_old pr thpr fmt task = let print_task_old pr thpr fmt task =
print_prelude fmt pr; print_prelude fmt pr;
print_th_prelude task fmt thpr; print_th_prelude task fmt thpr;
let csm,pjs,axs = Task.on_meta Eliminate_algebraic.meta_proj
add_projection (Mls.empty,Sls.empty,Spr.empty) task in
let info = { let info = {
info_syn = get_syntax_map task; info_syn = get_syntax_map task;
info_ac = Task.on_tagged_ls meta_ac task; info_ac = Task.on_tagged_ls meta_ac task;
info_csm = Mls.empty; info_csm = Mls.map Array.to_list csm;
info_pjs = Sls.empty; info_pjs = pjs;
info_axs = Spr.empty; info_axs = axs;
} in } in
let decls = Task.task_decls task in let decls = Task.task_decls task in
fprintf fmt "%a@." (print_list nothing (print_decl info)) decls fprintf fmt "%a@." (print_list nothing (print_decl info)) decls
...@@ -293,24 +303,15 @@ let print_decls = ...@@ -293,24 +303,15 @@ let print_decls =
info_syn = sm; info_syn = sm;
info_ac = ac; info_ac = ac;
info_csm = csm; info_csm = Mls.map Array.to_list csm;
info_pjs = pjs; info_pjs = pjs;
info_axs = axs; info_axs = axs;
} in } in
print_decl info fmt d in print_decl info fmt d in
Trans.on_tagged_ls meta_ac (fun ac -> Trans.on_tagged_ls meta_ac (fun ac ->
Trans.on_meta Eliminate_algebraic.meta_proj (fun mal -> Trans.on_meta Eliminate_algebraic.meta_proj (fun mal ->
let add (csm,pjs,axs) = function let csm,pjs,axs = List.fold_left
| [Theory.MAls ls; Theory.MAls cs; Theory.MAint ind; Theory.MApr pr] -> add_projection (Mls.empty,Sls.empty,Spr.empty) mal in
with Not_found ->
| _ -> assert false
in
let csm,pjs,axs =
List.fold_left add (Mls.empty,Sls.empty,Spr.empty) mal in
let csm = Mls.map Array.to_list csm in
Printer.sprint_decls (print ac csm pjs axs))) Printer.sprint_decls (print ac csm pjs axs)))
let print_task _env pr thpr ?old:_ fmt task = let print_task _env pr thpr ?old:_ fmt task =
