Commit f665916d authored by Sylvain Dailler's avatar Sylvain Dailler
Using driver from the controller for interactive provers.
parent eb43812d
...@@ -585,14 +585,8 @@ let schedule_proof_attempt ?proof_script c id pr ~counterexmp ~limit ~callback ~ ...@@ -585,14 +585,8 @@ let schedule_proof_attempt ?proof_script c id pr ~counterexmp ~limit ~callback ~
(* TODO to be simplified *) (* TODO to be simplified *)
(* create the path to a file for saving the external proof script *) (* create the path to a file for saving the external proof script *)
let create_file_rel_path c pr pn = let create_file_rel_path c pr pn =
let config = c.controller_config in
let c_env = c.controller_env in
let session = c.controller_session in let session = c.controller_session in
let prover_conf = Whyconf.get_prover_config config pr in let driver = snd (Hprover.find c.controller_provers pr) in
let driver = prover_conf.Whyconf.driver in
let driver = Whyconf.load_driver
(Whyconf.get_main config)
c_env driver prover_conf.Whyconf.extra_drivers in
let task = Session_itp.get_task session pn in let task = Session_itp.get_task session pn in
let session_dir = Session_itp.get_dir session in let session_dir = Session_itp.get_dir session in
let th = get_encapsulating_theory session (APn pn) in let th = get_encapsulating_theory session (APn pn) in
...@@ -606,14 +600,8 @@ let create_file_rel_path c pr pn = ...@@ -606,14 +600,8 @@ let create_file_rel_path c pr pn =
file file
let update_edit_external_proof c pn ?panid pr = let update_edit_external_proof c pn ?panid pr =
let file = let file =
