Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit f5154112 authored by Andrei Paskevich's avatar Andrei Paskevich
map.MapPermut, array.ArrayPermut: incorporate new lemmas
Comment out the lemmas about symmetry of permutation:
they perturb our provers and are of little interest in
the case of successive array permutations.
parent 51d3dc3c
...@@ -153,9 +153,8 @@ module ArrayPermut ...@@ -153,9 +153,8 @@ module ArrayPermut
use import ArrayEq use import ArrayEq
predicate exchange (a1 a2: array 'a) (i j: int) = predicate exchange (a1 a2: array 'a) (i j: int) =
a1.length = a2.length /\ 0 <= i < a1.length /\ 0 <= j < a1.length /\ a1.length = a2.length /\
a1[i] = a2[j] /\ a1[j] = a2[i] /\ M.exchange a1.elts a2.elts 0 a1.length i j
(forall k:int. 0 <= k < a1.length -> k <> i -> k <> j -> a1[k] = a2[k])
(** [exchange a1 a2 i j] means that arrays [a1] and [a2] only differ (** [exchange a1 a2 i j] means that arrays [a1] and [a2] only differ
by the swapping of elements at indices [i] and [j] *) by the swapping of elements at indices [i] and [j] *)
...@@ -179,29 +178,77 @@ module ArrayPermut ...@@ -179,29 +178,77 @@ module ArrayPermut
(** [permut_all a1 a2 l u] is true when array [a1] is a permutation (** [permut_all a1 a2 l u] is true when array [a1] is a permutation
of array [a2]. *) of array [a2]. *)
(** {3 lemmas about [permut_sub]} *)
(** permut_sub is reflexive, symmetric, transitive and contains
transpositions *)
lemma permut_sub_refl:
forall a: array 'a, l u: int.
0 <= l <= u <= length a -> permut_sub a a l u
lemma permut_sub_sym:
forall a1 a2: array 'a, l u: int.
permut_sub a1 a2 l u -> permut_sub a2 a1 l u
lemma permut_sub_trans:
forall a1 a2 a3: array 'a, l u: int.
permut_sub a1 a2 l u -> permut_sub a2 a3 l u -> permut_sub a1 a3 l u
lemma exchange_permut_sub:
forall a1 a2: array 'a, i j l u: int.
exchange a1 a2 i j -> l <= i < u -> l <= j < u ->
0 <= l -> u <= length a1 -> permut_sub a1 a2 l u
lemma permut_sub_unmodified:
forall i: int. (0 <= i < l \/ u <= i < length a1) -> a2[i] = a1[i]
(** we can always enlarge the interval *)
lemma permut_sub_weakening:
forall a1 a2: array 'a, l1 u1 l2 u2: int.
permut_sub a1 a2 l1 u1 -> 0 <= l2 <= l1 -> u1 <= u2 <= length a1 ->
permut_sub a1 a2 l2 u2
lemma permut_sub_compose:
forall a1 a2 a3: array 'a, l1 u1 l2 u2: int. u1 <= l2 ->
permut_sub a2 a3 l2 u2 ->
permut_sub a1 a3 l1 u2
(** {3 lemmas about [permut_all]} *)
(** permut_all is reflexive, symmetric, transitive and contains
transpositions *)
lemma permut_all_refl: lemma permut_all_refl:
forall a: array 'a. permut_all a a forall a: array 'a. permut_all a a
lemma exchange_permut_all: (*
forall a1 a2: array 'a, i j: int [exchange a1 a2 i j].
exchange a1 a2 i j -> permut_all a1 a2
lemma permut_all_sym: lemma permut_all_sym:
forall a1 a2: array 'a. forall a1 a2: array 'a.
permut_all a1 a2 -> permut_all a2 a1 permut_all a1 a2 -> permut_all a2 a1
lemma permut_all_trans: lemma permut_all_trans:
forall a1 a2 a3: array 'a. forall a1 a2 a3: array 'a.
permut_all a1 a2 -> permut_all a2 a3 -> permut_all a1 a3 permut_all a1 a2 -> permut_all a2 a3 -> permut_all a1 a3
forall a1 a2: array 'a, i j: int.
(** identical arrays *)
lemma array_eq_permut_all: lemma array_eq_permut_all:
array_eq a1 a2 -> permut_all a1 a2 array_eq a1 a2 -> permut_all a1 a2
lemma permut_sub_weakening: (** permutation on a sub-interval *)
lemma permut_sub_permut_all: lemma permut_sub_permut_all:
forall a1 a2: array 'a, l u: int. forall a1 a2: array 'a, l u: int.
...@@ -219,8 +266,7 @@ module ArraySwap ...@@ -219,8 +266,7 @@ module ArraySwap
requires { 0 <= i < length a /\ 0 <= j < length a } requires { 0 <= i < length a /\ 0 <= j < length a }
writes { a } writes { a }
ensures { exchange (old a) a i j } ensures { exchange (old a) a i j }
= = let v = a[i] in
let v = a[i] in
a[i] <- a[j]; a[i] <- a[j];
a[j] <- v a[j] <- v
...@@ -91,7 +91,6 @@ theory MapInjection ...@@ -91,7 +91,6 @@ theory MapInjection
end end
(** {2 Map Permutation (indexed by integers)} *) (** {2 Map Permutation (indexed by integers)} *)
theory MapPermut theory MapPermut
...@@ -99,6 +98,11 @@ theory MapPermut ...@@ -99,6 +98,11 @@ theory MapPermut
use import Map use import Map
use import MapEq use import MapEq
predicate exchange (a1 a2: map int 'a) (l u i j: int) =
l <= i < u /\ l <= j < u /\
(forall k:int. l <= k < u -> k <> i -> k <> j -> a1[k] = a2[k])
inductive permut (map int 'a) (map int 'a) int int = inductive permut (map int 'a) (map int 'a) int int =
| permut_refl : (* a1[l..u[ and a2[l..u[ are identical *) | permut_refl : (* a1[l..u[ and a2[l..u[ are identical *)
forall a1 a2 : map int 'a. forall l u : int. forall a1 a2 : map int 'a. forall l u : int.
...@@ -108,10 +112,7 @@ theory MapPermut ...@@ -108,10 +112,7 @@ theory MapPermut
permut a1 a2 l u -> permut a2 a3 l u -> permut a1 a3 l u permut a1 a2 l u -> permut a2 a3 l u -> permut a1 a3 l u
| permut_exchange : (* elements at indices i and j have been swapped *) | permut_exchange : (* elements at indices i and j have been swapped *)
forall a1 a2 : map int 'a. forall l u i j : int. forall a1 a2 : map int 'a. forall l u i j : int.
l <= i < u -> l <= j < u -> i <> j -> exchange a1 a2 l u i j -> permut a1 a2 l u
a1[i] = a2[j] -> a1[j] = a2[i] ->
(forall k:int. l <= k < u -> k <> i -> k <> j -> a1[k] = a2[k]) ->
permut a1 a2 l u
(** [permut m1 m2 l u] is true when the segment (** [permut m1 m2 l u] is true when the segment
[m1(l..u-1)] is a permutation of the segment [m2(l..u-1)]. [m1(l..u-1)] is a permutation of the segment [m2(l..u-1)].
Values outside of the interval (l..u-1) are ignored. Values outside of the interval (l..u-1) are ignored.
...@@ -119,27 +120,28 @@ theory MapPermut ...@@ -119,27 +120,28 @@ theory MapPermut
It is defined inductively as the smallest equivalence relation It is defined inductively as the smallest equivalence relation
that contains the exchanges *) that contains the exchanges *)
(* symmetry can be proved *) (* symmetry can be proved *)
lemma permut_sym: lemma permut_sym:
permut a1 a2 l u -> permut a2 a1 l u permut a1 a2 l u -> permut a2 a1 l u
lemma permut_exchange_set : lemma exchange_set :
forall a: map int 'a. forall l u i j: int. forall a: map int 'a, l u i j: int.
l <= i < u -> l <= j < u -> permut a a[i <- a[j]][j <- a[i]] l u l <= i < u -> l <= j < u ->
exchange a a[i <- a[j]][j <- a[i]] l u i j
lemma permut_exists : lemma permut_exists :
forall a1 a2: map int 'a. forall l u: int. forall a1 a2: map int 'a, l u i: int.
permut a1 a2 l u -> permut a1 a2 l u -> l <= i < u ->
forall i: int. l <= i < u -> exists j: int. l <= j < u /\ a1[j] = a2[i]
exists j: int. l <= j < u /\ a2[i] = a1[j]
(* (* THIS IS FALSE WHEN m < l < u
lemma permut_concat: lemma permut_concat:
forall a1 a2: map int 'a, l m u: int. forall a1 a2: map int 'a, l m u: int.
permut a1 a2 l m -> permut a1 a2 m u -> permut a1 a2 l u permut a1 a2 l m -> permut a1 a2 m u -> permut a1 a2 l u
end end
(** {2 Sum of elements of a map (indexed by integers)} *) (** {2 Sum of elements of a map (indexed by integers)} *)
