Commit f33f9458 authored by Asma Tafat's avatar Asma Tafat
blocking semantic
parent fd62c038
...@@ -364,21 +364,21 @@ lemma eval_msubst: ...@@ -364,21 +364,21 @@ lemma eval_msubst:
(* (eval_fmla sigma pi (subst f x v) <-> *) (* (eval_fmla sigma pi (subst f x v) <-> *)
(* eval_fmla sigma (Cons(x, (get_stack v pi)) pi) f) *) (* eval_fmla sigma (Cons(x, (get_stack v pi)) pi) f) *)
lemma eval_same_var_term: (* lemma eval_same_var_term: *)
forall t:term, sigma:env, pi:stack, id:ident, v1 v2:value. (* forall t:term, sigma:env, pi:stack, id:ident, v1 v2:value. *)
eval_term sigma (Cons (id,v1) (Cons (id,v2) pi)) t = (* eval_term sigma (Cons (id,v1) (Cons (id,v2) pi)) t = *)
eval_term sigma (Cons (id,v1) pi) t (* eval_term sigma (Cons (id,v1) pi) t *)
lemma eval_same_var: (* lemma eval_same_var: *)
forall f:fmla, sigma:env, pi:stack, id:ident, v1 v2:value. (* forall f:fmla, sigma:env, pi:stack, id:ident, v1 v2:value. *)
eval_fmla sigma (Cons (id,v1) (Cons (id,v2) pi)) f <-> (* eval_fmla sigma (Cons (id,v1) (Cons (id,v2) pi)) f <-> *)
eval_fmla sigma (Cons (id,v1) pi) f (* eval_fmla sigma (Cons (id,v1) pi) f *)
lemma eval_swap_term_any: lemma eval_swap_term_any:
forall t:term, sigma:env, pi l:stack, id1 id2:ident, v1 v2:value. forall t:term, sigma:env, pi l:stack, id1 id2:ident, v1 v2:value.
id1 <> id2 -> id1 <> id2 ->
(eval_term sigma (l++(Cons (id1,v1) (Cons (id2,v2) pi))) t = (eval_term sigma (l++(Cons (id1,v1) (Cons (id2,v2) pi))) t =
eval_term sigma (l++(Cons (id2,v2) (Cons (id1,v1) pi))) t) eval_term sigma (l++(Cons (id2,v2) (Cons (id1,v1) pi))) t)
(* lemma eval_swap_term: *) (* lemma eval_swap_term: *)
(* forall t:term, sigma:env, pi:stack, id1 id2:ident, v1 v2:value. *) (* forall t:term, sigma:env, pi:stack, id1 id2:ident, v1 v2:value. *)
...@@ -554,48 +554,24 @@ ...@@ -554,48 +554,24 @@
loclnum="345" loccnumb="6" loccnume="17" loclnum="345" loccnumb="6" loccnume="17"
sum="7dfb30d5fc12e926546e3331a65bfbc3" sum="7dfb30d5fc12e926546e3331a65bfbc3"
proved="false" proved="false"
expanded="false" expanded="true"
shape="ainfix =asubstV0V1V2V0Iafresh_in_fmlaV1V0F"> shape="ainfix =asubstV0V1V2V0Iafresh_in_fmlaV1V0F">
<proof
prover="5"
timelimit="3"
memlimit="1000"
obsolete="true"
archived="false">
<result status="timeout" time="3.09"/>
</proof>
<proof
prover="11"
timelimit="3"
memlimit="1000"
obsolete="true"
archived="false">
<result status="timeout" time="3.04"/>
</proof>
<proof
prover="2"
timelimit="3"
memlimit="1000"
obsolete="true"
archived="false">
<result status="unknown" time="0.04"/>
</proof>
<transf <transf
name="induction_ty_lex" name="induction_ty_lex"
expanded="false"> expanded="true">
<goal <goal
name="subst_fresh.1" name="subst_fresh.1"
locfile="blocking_semantics3/../blocking_semantics3.mlw" locfile="blocking_semantics3/../blocking_semantics3.mlw"
sum="2c18da601668a340cffc5052da630109" sum="2c18da601668a340cffc5052da630109"
shape="CV0aFtermVainfix =asubstV0V2V3V0Iafresh_in_fmlaV2V0FaFandVVainfix =asubstV0V6V7V0Iafresh_in_fmlaV6V0FIainfix =asubstV4V8V9V4Iafresh_in_fmlaV8V4FIainfix =asubstV5V10V11V5Iafresh_in_fmlaV10V5FaFnotVainfix =asubstV0V13V14V0Iafresh_in_fmlaV13V0FIainfix =asubstV12V15V16V12Iafresh_in_fmlaV15V12FaFimpliesVVainfix =asubstV0V19V20V0Iafresh_in_fmlaV19V0FIainfix =asubstV17V21V22V17Iafresh_in_fmlaV21V17FIainfix =asubstV18V23V24V18Iafresh_in_fmlaV23V18FaFletVVVainfix =asubstV0V28V29V0Iafresh_in_fmlaV28V0FIainfix =asubstV27V30V31V27Iafresh_in_fmlaV30V27FaFforallVVVainfix =asubstV0V35V36V0Iafresh_in_fmlaV35V0FIainfix =asubstV34V37V38V34Iafresh_in_fmlaV37V34FF"> shape="CV0aFtermVainfix =asubstV0V2V3V0Iafresh_in_fmlaV2V0FaFandVVainfix =asubstV0V6V7V0Iafresh_in_fmlaV6V0FIainfix =asubstV4V8V9V4Iafresh_in_fmlaV8V4FIainfix =asubstV5V10V11V5Iafresh_in_fmlaV10V5FaFnotVainfix =asubstV0V13V14V0Iafresh_in_fmlaV13V0FIainfix =asubstV12V15V16V12Iafresh_in_fmlaV15V12FaFimpliesVVainfix =asubstV0V19V20V0Iafresh_in_fmlaV19V0FIainfix =asubstV17V21V22V17Iafresh_in_fmlaV21V17FIainfix =asubstV18V23V24V18Iafresh_in_fmlaV23V18FaFletVVVainfix =asubstV0V28V29V0Iafresh_in_fmlaV28V0FIainfix =asubstV27V30V31V27Iafresh_in_fmlaV30V27FaFforallVVVainfix =asubstV0V35V36V0Iafresh_in_fmlaV35V0FIainfix =asubstV34V37V38V34Iafresh_in_fmlaV37V34FF">
<transf <transf
name="split_goal_wp" name="split_goal_wp"
<goal <goal
name="subst_fresh.1.1" name="subst_fresh.1.1"
...@@ -967,7 +943,7 @@ ...@@ -967,7 +943,7 @@
sum="7e164013dd963bf07230044a34334bae" sum="7e164013dd963bf07230044a34334bae"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVainfix =asubstV0V10V11V0Iafresh_in_fmlaV10V0FIainfix =asubstV9V12V13V9Iafresh_in_fmlaV12V9FaFforallVVVtF"> shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVainfix =asubstV0V10V11V0Iafresh_in_fmlaV10V0FIainfix =asubstV9V12V13V9Iafresh_in_fmlaV12V9FaFforallVVVtF">
<proof <proof
prover="7" prover="7"
...@@ -989,9 +965,9 @@ ...@@ -989,9 +965,9 @@
prover="3" prover="3"
timelimit="5" timelimit="5"
memlimit="1000" memlimit="1000"
obsolete="true" obsolete="false"
archived="false"> archived="false">
<result status="timeout" time="5.03"/> <result status="timeout" time="5.09"/>
</proof> </proof>
<proof <proof
prover="1" prover="1"
...@@ -999,7 +975,7 @@ ...@@ -999,7 +975,7 @@
obsolete="false" obsolete="false"
<result status="unknown" time="2.02"/> <result status="unknown" time="1.90"/>
</proof> </proof>
<proof <proof
prover="5" prover="5"
...@@ -1033,6 +1009,14 @@ ...@@ -1033,6 +1009,14 @@
<result status="timeout" time="5.04"/> <result status="timeout" time="5.04"/>
</proof> </proof>
<proof
prover="9"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="timeout" time="5.35"/>
</proof>
<proof <proof
prover="4" prover="4"
...@@ -1375,285 +1359,11 @@ ...@@ -1375,285 +1359,11 @@
</goal> </goal>
</transf> </transf>
</goal> </goal>
<goal
name="eval_same_var_term"
loclnum="367" loccnumb="6" loccnume="24"
sum="32c8bd07dbed0a0b0883828f1348d637"
proved="false"
expanded="false"
shape="ainfix =aeval_termV1aConsaTuple2V3V4aConsaTuple2V3V5V2V0aeval_termV1aConsaTuple2V3V4V2V0F">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
</proof>
</goal>
<goal
name="eval_same_var"
loclnum="372" loccnumb="6" loccnume="19"
sum="2636459a59608d4aa803be88d4b94832"
proved="false"
expanded="false"
shape="aeval_fmlaV1aConsaTuple2V3V4V2V0qaeval_fmlaV1aConsaTuple2V3V4aConsaTuple2V3V5V2V0F">
<transf
proved="false"
expanded="false">
<goal
name="eval_same_var.1"
sum="2f8079d985b78666812ba633af745de5"
proved="false"
expanded="false"
shape="CV0aFtermVaeval_fmlaV2aConsaTuple2V4V5V3V0qaeval_fmlaV2aConsaTuple2V4V5aConsaTuple2V4V6V3V0FaFandVVaeval_fmlaV9aConsaTuple2V11V12V10V0qaeval_fmlaV9aConsaTuple2V11V12aConsaTuple2V11V13V10V0FIaeval_fmlaV14aConsaTuple2V16V17V15V7qaeval_fmlaV14aConsaTuple2V16V17aConsaTuple2V16V18V15V7FIaeval_fmlaV19aConsaTuple2V21V22V20V8qaeval_fmlaV19aConsaTuple2V21V22aConsaTuple2V21V23V20V8FaFnotVaeval_fmlaV25aConsaTuple2V27V28V26V0qaeval_fmlaV25aConsaTuple2V27V28aConsaTuple2V27V29V26V0FIaeval_fmlaV30aConsaTuple2V32V33V31V24qaeval_fmlaV30aConsaTuple2V32V33aConsaTuple2V32V34V31V24FaFimpliesVVaeval_fmlaV37aConsaTuple2V39V40V38V0qaeval_fmlaV37aConsaTuple2V39V40aConsaTuple2V39V41V38V0FIaeval_fmlaV42aConsaTuple2V44V45V43V35qaeval_fmlaV42aConsaTuple2V44V45aConsaTuple2V44V46V43V35FIaeval_fmlaV47aConsaTuple2V49V50V48V36qaeval_fmlaV47aConsaTuple2V49V50aConsaTuple2V49V51V48V36FaFletVVVaeval_fmlaV55aConsaTuple2V57V58V56V0qaeval_fmlaV55aConsaTuple2V57V58aConsaTuple2V57V59V56V0FIaeval_fmlaV60aConsaTuple2V62V63V61V54qaeval_fmlaV60aConsaTuple2V62V63aConsaTuple2V62V64V61V54FaFforallVVVaeval_fmlaV68aConsaTuple2V70V71V69V0qaeval_fmlaV68aConsaTuple2V70V71aConsaTuple2V70V72V69V0FIaeval_fmlaV73aConsaTuple2V75V76V74V67qaeval_fmlaV73aConsaTuple2V75V76aConsaTuple2V75V77V74V67FF">
<transf
proved="false"
expanded="false">
<goal
name="eval_same_var.1.1"
sum="16826d46ad0bd3a1523c1f080568b3e5"
proved="true"
expanded="false"
shape="CV0aFtermVaeval_fmlaV2aConsaTuple2V4V5V3V0Iaeval_fmlaV2aConsaTuple2V4V5aConsaTuple2V4V6V3V0FaFandVVtaFnotVtaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.12"/>
</proof>
</goal>
<goal
name="eval_same_var.1.2"
sum="ae98f2f5840ea5ecf5b70a6565e2de9a"
proved="true"
expanded="false"
shape="CV0aFtermVaeval_fmlaV2aConsaTuple2V4V5aConsaTuple2V4V6V3V0Iaeval_fmlaV2aConsaTuple2V4V5V3V0FaFandVVtaFnotVtaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.08"/>
</proof>
</goal>
<goal
name="eval_same_var.1.3"
sum="d9055acb8a95e47e2c6ae86069c9220e"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVaeval_fmlaV4aConsaTuple2V6V7V5V0Iaeval_fmlaV4aConsaTuple2V6V7aConsaTuple2V6V8V5V0FIaeval_fmlaV9aConsaTuple2V11V12V10V2qaeval_fmlaV9aConsaTuple2V11V12aConsaTuple2V11V13V10V2FIaeval_fmlaV14aConsaTuple2V16V17V15V3qaeval_fmlaV14aConsaTuple2V16V17aConsaTuple2V16V18V15V3FaFnotVtaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.17"/>
</proof>
</goal>
<goal
name="eval_same_var.1.4"
sum="52ba4810a272e276fca6c584c56e08ae"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVaeval_fmlaV4aConsaTuple2V6V7aConsaTuple2V6V8V5V0Iaeval_fmlaV4aConsaTuple2V6V7V5V0FIaeval_fmlaV9aConsaTuple2V11V12V10V2qaeval_fmlaV9aConsaTuple2V11V12aConsaTuple2V11V13V10V2FIaeval_fmlaV14aConsaTuple2V16V17V15V3qaeval_fmlaV14aConsaTuple2V16V17aConsaTuple2V16V18V15V3FaFnotVtaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.07"/>
</proof>
</goal>
<goal
name="eval_same_var.1.5"
sum="201dd785a1e8991c3a1e7af44f71776f"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVaeval_fmlaV5aConsaTuple2V7V8V6V0Iaeval_fmlaV5aConsaTuple2V7V8aConsaTuple2V7V9V6V0FIaeval_fmlaV10aConsaTuple2V12V13V11V4qaeval_fmlaV10aConsaTuple2V12V13aConsaTuple2V12V14V11V4FaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.10"/>
</proof>
</goal>
<goal
name="eval_same_var.1.6"
sum="adcde3509a88ae30c51737d94246dc55"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVaeval_fmlaV5aConsaTuple2V7V8aConsaTuple2V7V9V6V0Iaeval_fmlaV5aConsaTuple2V7V8V6V0FIaeval_fmlaV10aConsaTuple2V12V13V11V4qaeval_fmlaV10aConsaTuple2V12V13aConsaTuple2V12V14V11V4FaFimpliesVVtaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.06"/>
</proof>
</goal>
<goal
name="eval_same_var.1.7"
sum="f87100e7fde15b2e310450982a660b01"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVaeval_fmlaV7aConsaTuple2V9V10V8V0Iaeval_fmlaV7aConsaTuple2V9V10aConsaTuple2V9V11V8V0FIaeval_fmlaV12aConsaTuple2V14V15V13V5qaeval_fmlaV12aConsaTuple2V14V15aConsaTuple2V14V16V13V5FIaeval_fmlaV17aConsaTuple2V19V20V18V6qaeval_fmlaV17aConsaTuple2V19V20aConsaTuple2V19V21V18V6FaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.13"/>
</proof>
</goal>
<goal
name="eval_same_var.1.8"
sum="9635fde993117c01a8120f9b43b10153"
proved="true"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVaeval_fmlaV7aConsaTuple2V9V10aConsaTuple2V9V11V8V0Iaeval_fmlaV7aConsaTuple2V9V10V8V0FIaeval_fmlaV12aConsaTuple2V14V15V13V5qaeval_fmlaV12aConsaTuple2V14V15aConsaTuple2V14V16V13V5FIaeval_fmlaV17aConsaTuple2V19V20V18V6qaeval_fmlaV17aConsaTuple2V19V20aConsaTuple2V19V21V18V6FaFletVVVtaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="valid" time="0.04"/>
</proof>
</goal>
<goal
name="eval_same_var.1.9"
sum="403c7a09d176df9a8559bc2f33a74fff"
proved="false"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVaeval_fmlaV10aConsaTuple2V12V13V11V0Iaeval_fmlaV10aConsaTuple2V12V13aConsaTuple2V12V14V11V0FIaeval_fmlaV15aConsaTuple2V17V18V16V9qaeval_fmlaV15aConsaTuple2V17V18aConsaTuple2V17V19V16V9FaFforallVVVtF">
<proof
prover="3"
timelimit="5"
memlimit="1000"
obsolete="true"
archived="false">
<result status="timeout" time="5.11"/>
</proof>
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="timeout" time="5.33"/>
</proof>
<proof
prover="6"
timelimit="5"
memlimit="1000"
edited="blocking_semantics3_ImpExpr_eval_same_var_1.v"
obsolete="true"
archived="false"><undone/>
</proof>
<proof
prover="9"
timelimit="5"
memlimit="1000"
obsolete="true"
archived="false">
<result status="timeout" time="5.63"/>
</proof>
</goal>
<goal
name="eval_same_var.1.10"
sum="ed269bbae278f981c914fc243ded50d8"
proved="false"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVaeval_fmlaV10aConsaTuple2V12V13aConsaTuple2V12V14V11V0Iaeval_fmlaV10aConsaTuple2V12V13V11V0FIaeval_fmlaV15aConsaTuple2V17V18V16V9qaeval_fmlaV15aConsaTuple2V17V18aConsaTuple2V17V19V16V9FaFforallVVVtF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
archived="false">
<result status="timeout" time="5.79"/>
</proof>
</goal>
<goal
name="eval_same_var.1.11"
sum="04d9982c92fdbe3d345a1a897575f1b7"
proved="false"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVtaFforallVVVaeval_fmlaV13aConsaTuple2V15V16V14V0Iaeval_fmlaV13aConsaTuple2V15V16aConsaTuple2V15V17V14V0FIaeval_fmlaV18aConsaTuple2V20V21V19V12qaeval_fmlaV18aConsaTuple2V20V21aConsaTuple2V20V22V19V12FF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
</proof>
</goal>
<goal
name="eval_same_var.1.12"
sum="f94141e45d5feee131be5367b38d4a42"
proved="false"
expanded="false"
shape="CV0aFtermVtaFandVVtaFnotVtaFimpliesVVtaFletVVVtaFforallVVVaeval_fmlaV13aConsaTuple2V15V16aConsaTuple2V15V17V14V0Iaeval_fmlaV13aConsaTuple2V15V16V14V0FIaeval_fmlaV18aConsaTuple2V20V21V19V12qaeval_fmlaV18aConsaTuple2V20V21aConsaTuple2V20V22V19V12FF">
<proof
prover="1"
timelimit="5"
memlimit="1000"
obsolete="false"
</proof>
</goal>
</transf>
</goal>
</transf>
</goal>
<goal <goal
name="eval_swap_term_any" name="eval_swap_term_any"
loclnum="377" loccnumb="6" loccnume="24" loclnum="377" loccnumb="6" loccnume="24"
sum="98b7cc455641859baeea006e4e2f2cc5" sum="54818880aac7f32588cbefb9cdfbfe86"
proved="true" proved="true"
expanded="false" expanded="false"
shape="ainfix =aeval_termV1ainfix ++V3aConsaTuple2V4V6aConsaTuple2V5V7V2V0aeval_termV1ainfix ++V3aConsaTuple2V5V7aConsaTuple2V4V6V2V0Iainfix =V4V5NF"> shape="ainfix =aeval_termV1ainfix ++V3aConsaTuple2V4V6aConsaTuple2V5V7V2V0aeval_termV1ainfix ++V3aConsaTuple2V5V7aConsaTuple2V4V6V2V0Iainfix =V4V5NF">
...@@ -1665,7 +1375,7 @@ ...@@ -1665,7 +1375,7 @@
name="eval_swap_term_any.1" name="eval_swap_term_any.1"
sum="91155d486ada149445b186c005e71afe" sum="57a1c9123f46e9f1b1f6419da51c48f2"
shape="CV0aTvalueVainfix =aeval_termV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0aeval_termV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0Iainfix =V5V6NFaTvarVainfix =aeval_termV10ainfix ++V12aConsaTuple2V13V15aConsaTuple2V14V16V11V0aeval_termV10ainfix ++V12aConsaTuple2V14V16aConsaTuple2V13V15V11V0Iainfix =V13V14NFaTderefVainfix =aeval_termV18ainfix ++V20aConsaTuple2V21V23aConsaTuple2V22V24V19V0aeval_termV18ainfix ++V20aConsaTuple2V22V24aConsaTuple2V21V23V19V0Iainfix =V21V22NFaTbinVVVainfix =aeval_termV28ainfix ++V30aConsaTuple2V31V33aConsaTuple2V32V34V29V0aeval_termV28ainfix ++V30aConsaTuple2V32V34aConsaTuple2V31V33V29V0Iainfix =V31V32NFIainfix =aeval_termV35ainfix ++V37aConsaTuple2V38V40aConsaTuple2V39V41V36V25aeval_termV35ainfix ++V37aConsaTuple2V39V41aConsaTuple2V38V40V36V25Iainfix =V38V39NFIainfix =aeval_termV42ainfix ++V44aConsaTuple2V45V47aConsaTuple2V46V48V43V27aeval_termV42ainfix ++V44aConsaTuple2V46V48aConsaTuple2V45V47V43V27Iainfix =V45V46NFF"> shape="CV0aTvalueVainfix =aeval_termV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0aeval_termV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0Iainfix =V5V6NFaTvarVainfix =aeval_termV10ainfix ++V12aConsaTuple2V13V15aConsaTuple2V14V16V11V0aeval_termV10ainfix ++V12aConsaTuple2V14V16aConsaTuple2V13V15V11V0Iainfix =V13V14NFaTderefVainfix =aeval_termV18ainfix ++V20aConsaTuple2V21V23aConsaTuple2V22V24V19V0aeval_termV18ainfix ++V20aConsaTuple2V22V24aConsaTuple2V21V23V19V0Iainfix =V21V22NFaTbinVVVainfix =aeval_termV28ainfix ++V30aConsaTuple2V31V33aConsaTuple2V32V34V29V0aeval_termV28ainfix ++V30aConsaTuple2V32V34aConsaTuple2V31V33V29V0Iainfix =V31V32NFIainfix =aeval_termV35ainfix ++V37aConsaTuple2V38V40aConsaTuple2V39V41V36V25aeval_termV35ainfix ++V37aConsaTuple2V39V41aConsaTuple2V38V40V36V25Iainfix =V38V39NFIainfix =aeval_termV42ainfix ++V44aConsaTuple2V45V47aConsaTuple2V46V48V43V27aeval_termV42ainfix ++V44aConsaTuple2V46V48aConsaTuple2V45V47V43V27Iainfix =V45V46NFF">
...@@ -1677,7 +1387,7 @@ ...@@ -1677,7 +1387,7 @@
name="eval_swap_term_any.1.1" name="eval_swap_term_any.1.1"
sum="4a3c0cb704c2ae3614f4ecca2a3b1127" sum="09dbc6e434eca065af15ca6a7c484db1"
shape="CV0aTvalueVainfix =aeval_termV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0aeval_termV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0Iainfix =V5V6NFaTvarVtaTderefVtaTbinVVVtF"> shape="CV0aTvalueVainfix =aeval_termV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0aeval_termV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0Iainfix =V5V6NFaTvarVtaTderefVtaTbinVVVtF">
...@@ -1687,14 +1397,14 @@ ...@@ -1687,14 +1397,14 @@
<result status="valid" time="0.05"/> <result status="valid" time="0.04"/>
</proof> </proof>
</goal> </goal>
<goal <goal
name="eval_swap_term_any.1.2" name="eval_swap_term_any.1.2"
sum="c0619e8e247f63f7f525422f4f7e4e81" sum="9608abe3fe7b0ed5e7585e2e00dc2bfc"
shape="CV0aTvalueVtaTvarVainfix =aeval_termV3ainfix ++V5aConsaTuple2V6V8aConsaTuple2V7V9V4V0aeval_termV3ainfix ++V5aConsaTuple2V7V9aConsaTuple2V6V8V4V0Iainfix =V6V7NFaTderefVtaTbinVVVtF"> shape="CV0aTvalueVtaTvarVainfix =aeval_termV3ainfix ++V5aConsaTuple2V6V8aConsaTuple2V7V9V4V0aeval_termV3ainfix ++V5aConsaTuple2V7V9aConsaTuple2V6V8V4V0Iainfix =V6V7NFaTderefVtaTbinVVVtF">
...@@ -1702,7 +1412,7 @@ ...@@ -1702,7 +1412,7 @@
obsolete="false" obsolete="true"
<result status="timeout" time="5.11"/> <result status="timeout" time="5.11"/>
</proof> </proof>
...@@ -1713,14 +1423,14 @@ ...@@ -1713,14 +1423,14 @@
edited="blocking_semantics3_ImpExpr_eval_swap_term_any_1.v" edited="blocking_semantics3_ImpExpr_eval_swap_term_any_1.v"
<result status="valid" time="1.13"/> <result status="valid" time="1.24"/>
</proof> </proof>
</goal> </goal>
<goal <goal
name="eval_swap_term_any.1.3" name="eval_swap_term_any.1.3"
sum="2ae7dc10a1c5658a8ed05a2799eab331" sum="fbc223200fc60b754e4e92145ccd2cfc"
shape="CV0aTvalueVtaTvarVtaTderefVainfix =aeval_termV4ainfix ++V6aConsaTuple2V7V9aConsaTuple2V8V10V5V0aeval_termV4ainfix ++V6aConsaTuple2V8V10aConsaTuple2V7V9V5V0Iainfix =V7V8NFaTbinVVVtF"> shape="CV0aTvalueVtaTvarVtaTderefVainfix =aeval_termV4ainfix ++V6aConsaTuple2V7V9aConsaTuple2V8V10V5V0aeval_termV4ainfix ++V6aConsaTuple2V8V10aConsaTuple2V7V9V5V0Iainfix =V7V8NFaTbinVVVtF">
...@@ -1730,14 +1440,14 @@ ...@@ -1730,14 +1440,14 @@
<result status="valid" time="0.06"/> <result status="valid" time="0.04"/>
</proof> </proof>
</goal> </goal>
<goal <goal
name="eval_swap_term_any.1.4" name="eval_swap_term_any.1.4"
sum="b6128255650d4997d08a61a42bc8c431" sum="84706d4c6573dd8855651e530064af14"
shape="CV0aTvalueVtaTvarVtaTderefVtaTbinVVVainfix =aeval_termV7ainfix ++V9aConsaTuple2V10V12aConsaTuple2V11V13V8V0aeval_termV7ainfix ++V9aConsaTuple2V11V13aConsaTuple2V10V12V8V0Iainfix =V10V11NFIainfix =aeval_termV14ainfix ++V16aConsaTuple2V17V19aConsaTuple2V18V20V15V4aeval_termV14ainfix ++V16aConsaTuple2V18V20aConsaTuple2V17V19V15V4Iainfix =V17V18NFIainfix =aeval_termV21ainfix ++V23aConsaTuple2V24V26aConsaTuple2V25V27V22V6aeval_termV21ainfix ++V23aConsaTuple2V25V27aConsaTuple2V24V26V22V6Iainfix =V24V25NFF"> shape="CV0aTvalueVtaTvarVtaTderefVtaTbinVVVainfix =aeval_termV7ainfix ++V9aConsaTuple2V10V12aConsaTuple2V11V13V8V0aeval_termV7ainfix ++V9aConsaTuple2V11V13aConsaTuple2V10V12V8V0Iainfix =V10V11NFIainfix =aeval_termV14ainfix ++V16aConsaTuple2V17V19aConsaTuple2V18V20V15V4aeval_termV14ainfix ++V16aConsaTuple2V18V20aConsaTuple2V17V19V15V4Iainfix =V17V18NFIainfix =aeval_termV21ainfix ++V23aConsaTuple2V24V26aConsaTuple2V25V27V22V6aeval_termV21ainfix ++V23aConsaTuple2V25V27aConsaTuple2V24V26V22V6Iainfix =V24V25NFF">
...@@ -1747,7 +1457,7 @@ ...@@ -1747,7 +1457,7 @@
<result status="valid" time="0.11"/> <result status="valid" time="0.12"/>
</proof> </proof>
</goal> </goal>
</transf> </transf>
...@@ -1758,7 +1468,7 @@ ...@@ -1758,7 +1468,7 @@
name="eval_swap_any" name="eval_swap_any"
loclnum="389" loccnumb="6" loccnume="19" loclnum="389" loccnumb="6" loccnume="19"
sum="c4528c005aa2d20827ea3f86fec5da22" sum="9d7e5bdcd13996d937030209540cdc5d"
shape="aeval_fmlaV1ainfix ++V3aConsaTuple2V5V7aConsaTuple2V4V6V2V0qaeval_fmlaV1ainfix ++V3aConsaTuple2V4V6aConsaTuple2V5V7V2V0Iainfix =V4V5NF"> shape="aeval_fmlaV1ainfix ++V3aConsaTuple2V5V7aConsaTuple2V4V6V2V0qaeval_fmlaV1ainfix ++V3aConsaTuple2V4V6aConsaTuple2V5V7V2V0Iainfix =V4V5NF">
...@@ -1770,7 +1480,7 @@ ...@@ -1770,7 +1480,7 @@
name="eval_swap_any.1" name="eval_swap_any.1"
sum="af1ed20311dad84d43e51d3c3230d425" sum="0862f390158c0d4eae980f4f915febe7"
shape="CV0aFtermVaeval_fmlaV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0qaeval_fmlaV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0Iainfix =V5V6NFaFandVVaeval_fmlaV11ainfix ++V13aConsaTuple2V15V17aConsaTuple2V14V16V12V0qaeval_fmlaV11ainfix ++V13aConsaTuple2V14V16aConsaTuple2V15V17V12V0Iainfix =V14V15NFIaeval_fmlaV18ainfix ++V20aConsaTuple2V22V24aConsaTuple2V21V23V19V9qaeval_fmlaV18ainfix ++V20aConsaTuple2V21V23aConsaTuple2V22V24V19V9Iainfix =V21V22NFIaeval_fmlaV25ainfix ++V27aConsaTuple2V29V31aConsaTuple2V28V30V26V10qaeval_fmlaV25ainfix ++V27aConsaTuple2V28V30aConsaTuple2V29V31V26V10Iainfix =V28V29NFaFnotVaeval_fmlaV33ainfix ++V35aConsaTuple2V37V39aConsaTuple2V36V38V34V0qaeval_fmlaV33ainfix ++V35aConsaTuple2V36V38aConsaTuple2V37V39V34V0Iainfix =V36V37NFIaeval_fmlaV40ainfix ++V42aConsaTuple2V44V46aConsaTuple2V43V45V41V32qaeval_fmlaV40ainfix ++V42aConsaTuple2V43V45aConsaTuple2V44V46V41V32Iainfix =V43V44NFaFimpliesVVaeval_fmlaV49ainfix ++V51aConsaTuple2V53V55aConsaTuple2V52V54V50V0qaeval_fmlaV49ainfix ++V51aConsaTuple2V52V54aConsaTuple2V53V55V50V0Iainfix =V52V53NFIaeval_fmlaV56ainfix ++V58aConsaTuple2V60V62aConsaTuple2V59V61V57V47qaeval_fmlaV56ainfix ++V58aConsaTuple2V59V61aConsaTuple2V60V62V57V47Iainfix =V59V60NFIaeval_fmlaV63ainfix ++V65aConsaTuple2V67V69aConsaTuple2V66V68V64V48qaeval_fmlaV63ainfix ++V65aConsaTuple2V66V68aConsaTuple2V67V69V64V48Iainfix =V66V67NFaFletVVVaeval_fmlaV73ainfix ++V75aConsaTuple2V77V79aConsaTuple2V76V78V74V0qaeval_fmlaV73ainfix ++V75aConsaTuple2V76V78aConsaTuple2V77V79V74V0Iainfix =V76V77NFIaeval_fmlaV80ainfix ++V82aConsaTuple2V84V86aConsaTuple2V83V85V81V72qaeval_fmlaV80ainfix ++V82aConsaTuple2V83V85aConsaTuple2V84V86V81V72Iainfix =V83V84NFaFforallVVVaeval_fmlaV90ainfix ++V92aConsaTuple2V94V96aConsaTuple2V93V95V91V0qaeval_fmlaV90ainfix ++V92aConsaTuple2V93V95aConsaTuple2V94V96V91V0Iainfix =V93V94NFIaeval_fmlaV97ainfix ++V99aConsaTuple2V101V103aConsaTuple2V100V102V98V89qaeval_fmlaV97ainfix ++V99aConsaTuple2V100V102aConsaTuple2V101V103V98V89Iainfix =V100V101NFF"> shape="CV0aFtermVaeval_fmlaV2ainfix ++V4aConsaTuple2V6V8aConsaTuple2V5V7V3V0qaeval_fmlaV2ainfix ++V4aConsaTuple2V5V7aConsaTuple2V6V8V3V0Iainfix =V5V6NFaFandVVaeval_fmlaV11ainfix ++V13aConsaTuple2V15V17aConsaTuple2V14V16V12V0qaeval_fmlaV11ainfix ++V13aConsaTuple2V14V16aConsaTuple2V15V17V12V0Iainfix =V14V15NFIaeval_fmlaV18ainfix ++V20aConsaTuple2V22V24aConsaTuple2V21V23V19V9qaeval_fmlaV18ainfix ++V20aConsaTuple2V21V23aConsaTuple2V22V24V19V9Iainfix =V21V22NFIaeval_fmlaV25ainfix ++V27aConsaTuple2V29V31aConsaTuple2V28V30V26V10qaeval_fmlaV25ainfix ++V27aConsaTuple2V28V30aConsaTuple2V29V31V26V10Iainfix =V28V29NFaFnotVaeval_fmlaV33ainfix ++V35aConsaTuple2V37V39aConsaTuple2V36V38V34V0qaeval_fmlaV33ainfix ++V35aConsaTuple2V36V38aConsaTuple2V37V39V34V0Iainfix =V36V37NFIaeval_fmlaV40ainfix ++V42aConsaTuple2V44V46aConsaTuple2V43V45V41V32qaeval_fmlaV40ainfix ++V42aConsaTuple2V43V45aConsaTuple2V44V46V41V32Iainfix =V43V44NFaFimpliesVVaeval_fmlaV49ainfix ++V51aConsaTuple2V53V55aConsaTuple2V52V54V50V0qaeval_fmlaV49ainfix ++V51aConsaTuple2V52V54aConsaTuple2V53V55V50V0Iainfix =V52V53NFIaeval_fmlaV56ainfix ++V58aConsaTuple2V60V62aConsaTuple2V59V61V57V47qaeval_fmlaV56ainfix ++V58aConsaTuple2V59V61aConsaTuple2V60V62V57V47Iainfix =V59V60NFIaeval_fmlaV63ainfix ++V65aConsaTuple2V67V69aConsaTuple2V66V68V64V48qaeval_fmlaV63ainfix ++V65aConsaTuple2V66V68aConsaTuple2V67V69V64V48Iainfix =V66V67NFaFletVVVaeval_fmlaV73ainfix ++V75aConsaTuple2V77V79aConsaTuple2V76V78V74V0qaeval_fmlaV73ainfix ++V75aConsaTuple2V76V78aConsaTuple2V77V79V74V0Iainfix =V76V77NFIaeval_fmlaV80ainfix ++V82aConsaTuple2V84V86aConsaTuple2V83V85V81V72qaeval_fmlaV80ainfix ++V82aConsaTuple2V83V85aConsaTuple2V84V86V81V72Iainfix =V83V84NFaFforallVVVaeval_fmlaV90ainfix ++V92aConsaTuple2V94V96aConsaTuple2V93V95V91V0qaeval_fmlaV90ainfix ++V92aConsaTuple2V93V95aConsaTuple2V94V96V91V0Iainfix =V93V94NFIaeval_fmlaV97ainfix ++V99aConsaTuple2V101V103aConsaTuple2V100V102V98V89qaeval_fmlaV97ainfix ++V99aConsaTuple2V100V102aConsaTuple2V101V103V98V89Iainfix =V100V101NFF">
...@@ -1782,7 +1492,7 @@ ...@@ -1782,7 +1492,7 @@
name="eval_swap_any.1.1" name="eval_swap_any.1.1"
sum="b92f2d08bf398ff42cdfeb90a1ed4beb" sum="fce4c4370d453c95b7fd09e8752e0166"
