GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
f31fb71f
f31fb71f
Asma Tafat-Bouzid
vacid binary heap
cad2523b
11
Expand all
11 changed files
2796 additions
486 deletions
+2796
-486
examples/programs/vacid_0_binary_heaps/elements.why
+12
-12
examples/programs/vacid_0_binary_heaps/heap.why
+12
-12
examples/programs/vacid_0_binary_heaps/heap_implem.mlw
+5
-5
examples/programs/vacid_0_binary_heaps/heap_model.why
+5
-6
examples/programs/vacid_0_binary_heaps/heapsort.mlw
+1
-1
examples/programs/vacid_0_binary_heaps/proofs/elements_Elements_Elements_set_inside_1.v
...ry_heaps/proofs/elements_Elements_Elements_set_inside_1.v
+1
-3
examples/programs/vacid_0_binary_heaps/proofs/elements_Elements_Elements_set_outside_1.v
...y_heaps/proofs/elements_Elements_Elements_set_outside_1.v
+1
-3
examples/programs/vacid_0_binary_heaps/proofs/elements_Elements_Occ_elements_1.v
..._0_binary_heaps/proofs/elements_Elements_Occ_elements_1.v
+1
-3
examples/programs/vacid_0_binary_heaps/proofs/heap_model_Model_Model_set_1.v
...acid_0_binary_heaps/proofs/heap_model_Model_Model_set_1.v
+20
-21
examples/programs/vacid_0_binary_heaps/proofs/why3session.xml
...ples/programs/vacid_0_binary_heaps/proofs/why3session.xml
+2737
-420
examples/programs/vacid_0_binary_heaps/test_harness.mlw
+1
f31fb71f
@@ -2,9 +2,9 @@ theory Elements
use import int.Int
use import int.Int
use import bag.Bag
use import bag.Bag
use
import map.Map as A
use
export map.Map
type array 'a =
A.
map int 'a
type array 'a = map int 'a
(* [elements a i j] is the bag of elements in a[i..j[ *)
function elements (a:array 'a) (i j:int) : bag 'a
@@ -14,11 +14,11 @@ axiom Elements_empty : forall a:array 'a, i j:int.
axiom Elements_add : forall a:array 'a, i j :int.
i < j ->
i < j ->
(elements a i j) = (add
(A.get a (j-1))
(elements a i (j-1)))
a[j-1]
lemma Elements_singleton : forall a:array 'a, i j:int.
j = i + 1 ->
j = i + 1 ->
(elements a i j) = (singleton
(A.get a i)
a[i]
lemma Elements_union : forall a:array 'a, i j k:int.
i <= j <= k ->
i <= j <= k ->
@@ -26,11 +26,11 @@ lemma Elements_union : forall a:array 'a, i j k:int.
lemma Elements_add1 : forall a:array 'a, i j :int.
i < j ->
i < j ->
(A.get a i)
(elements a (i+1) j))
a[i]
lemma Elements_remove_last: forall a:array 'a, i j :int.
i < j-1 ->
i < j-1 ->
(elements a i (j-1)) = diff (elements a i j) (singleton
(A.get a (j-1))
a[j-1]
lemma Occ_elements: forall a:array 'a, i j n:int.
i <= j < n ->
i <= j < n ->
@@ -38,22 +38,22 @@ lemma Occ_elements: forall a:array 'a, i j n:int.
lemma Elements_set_outside : forall a:array 'a, i j:int.
i <= j -> forall k : int. (k < i || k >= j) ->
forall e:'a. (elements (
A.set a k e
) i j) = (elements a i j)
a[k <- e]
lemma Elements_set_inside : forall a:array 'a, i j n: int, e:'a, b:bag 'a.
i <= j < n ->
i <= j < n ->
(elements a i n) = add
(A.get a j)
b ->
a[j]
b ->
(elements (
A.set a j e
) i n) = add e b
(elements (
a[j <- e]
) i n) = add e b
lemma Elements_set_inside2 : forall a:array 'a, i j n: int, e:'a.
i <= j < n ->
i <= j < n ->
elements
(A.set a j e)
i n =
elements
a[j <- e]
i n =
add e (diff (elements a i n) (singleton (a[j])))
Local Variables:
Local Variables:
compile-command: "why3ide -I .
proof
s"
element
s"
End:
End:
\ No newline at end of file
f31fb71f
@@ -23,7 +23,7 @@ predicate parentChild (i: int) (j: int) =
0 <= i < j -> (j = left i) || (j = right i)
use map.Map as A
use
import
map.Map as A
type map = A.map int int
type logic_heap = (map, int)
@@ -31,7 +31,7 @@ predicate is_heap_array (a: map) (idx: int) (sz: int) =
0 <= idx -> forall i j: int.
idx <= i < j < sz ->
parentChild i j ->
parentChild i j ->
A.get a i <= A.get a j
a[i] <= a[j]
predicate is_heap (h : logic_heap) =
let (a, sz) = h in sz >= 0 /\ is_heap_array a 0 sz
@@ -52,37 +52,37 @@ lemma Is_heap_sub2 :
lemma Is_heap_when_node_modified :
forall a:map, n e idx i:int. 0 <= i < n ->
is_heap_array a idx n ->
(i > 0 ->
A.get a (parent i)
<= e ) ->
(i > 0 ->
a[parent i]
<= e ) ->
(left i < n -> e <=
A.get a (left i)
(left i < n -> e <=
a[left i]
(right i < n -> e <=
A.get a (right i)
a[right i]
is_heap_array (
A.set a i e
) idx n
is_heap_array (
a[i <- e]
) idx n
lemma Is_heap_add_last :
forall a:map, n e:int. n > 0 ->
is_heap_array a 0 n /\ (e >=
A.get a (parent n)
a[parent n]
is_heap_array (
A.set a n e
) 0 (n + 1)
is_heap_array (
a[n <- e]
) 0 (n + 1)
lemma Parent_inf_el:
forall a: map, n: int.
is_heap_array a 0 n ->
forall j:int. 0 < j < n ->
A.get a (parent j) <= A.get a j
a[parent j] <= a[j]
lemma Left_sup_el:
lemma Left_sup_el:
forall j: int. 0 <= j < n -> left j < n ->
A.get a j <= A.get a (left j)
a[j] <= a[left j]
lemma Right_sup_el:
lemma Right_sup_el:
forall j: int. 0 <= j < n -> right j < n ->
A.get a j <= A.get a (right j)
a[j] <= a[right j]
lemma Is_heap_relation:
forall a:map, n :int. n > 0 ->
forall j: int. 0 <= j -> j < n ->
A.get a 0 <= A.get a j
a[0] <= a[j]
f31fb71f
@@ -3,12 +3,12 @@ module Implementation
use
import
int
Int
use
import
int
Int
use
import
int
ComputerDivision
use
import
int
ComputerDivision
use
import
map
Map
use
import
map
Map
use
import
heap
Heap
use
import
heap_model
Model
use
import
heap_model
Model
use
import
bag_of_integers
Bag_integers
use
import
bag_of_integers
Bag_integers
use
import
elements
Elements
use
import
elements
Elements
use
import
heap
Heap
lemma
Is_heap_min
lemma
Is_heap_min
forall
a
map
n
int
n
forall
a
map
n
int
n
@@ -40,18 +40,18 @@ let insert (this : ref logic_heap) (e : int) : unit =
!i < n ->
!i < n ->
is_heap_array
!arr 0 (n + 1) /\
is_heap_array
!arr 0 (n + 1) /\
!arr[!i] > e /\
!arr[!i] > e /\
model
!arr, n+1) = add
(A.get !arr !i)
(model (a, n)))
model
!arr, n+1) = add
!arr[!i]
(model (a, n)))
variant
!i }
variant
!i }
let
div
!i - 1) 2 in
let
div
!i - 1) 2 in
let
p
A
get
!arr parent in
let
p
A
get
!arr parent in
if
e
p
then
raise
Break
if
e
p
then
raise
Break
arr
A
set
!arr !i p
arr
!arr[!i<-p]
i
i
done
done
Break
Break
arr
A
set
!arr !i e
arr
!arr[!i<-e]
this
!arr, n + 1);
this
!arr, n + 1);
assert
!i < n -> is_heap !this };
assert
assert
!i < n -> model !this = add e (model (a,n)) }
assert
f31fb71f
theory
Model
theory
Model
use
import
int
Int
use
import
int
Int
use
import
map
Map
use
import
bag
Bag
use
import
bag
Bag
use
import
elements
Elements
use
import
elements
Elements
@@ -13,23 +13,22 @@ function model (h:logic_heap): (bag int) =
lemma
Model_empty
lemma
Model_empty
forall
a
array
int
model
a
empty_bag
forall
a
array
int
model
a
empty_bag
lemma
Model_singleton
forall
a
array
int
model
a
singleton
A
get
a
lemma
Model_singleton
forall
a
array
int
model
a
singleton
a
lemma
Model_set
lemma
Model_set
forall
a
a
': array int,v: int, i n : int.
forall
a
a
0 <= i < n ->
0 <= i < n ->
a'
A
set
a
i
v
add (a[i]) (model (a[i <- v],n)) =
add
A
get
a
i
model
a
',n)) =
add v (model (a, n))
lemma Model_add_last:
forall a: array int, n : int. n >= 0 ->
model (a, n+1) = add (
A.get a n
) (model (a, n))
a[n]
) (model (a, n))
Local Variables:
Local Variables:
proofs
heap_model.why
End:
End:
f31fb71f
@@ -53,7 +53,7 @@ end
Local
Variables
Local
Variables
compile
command
"why3ide -I .
proofs
compile
command
"why3ide -I .
heapsort.mlw
End
End
f31fb71f
@@ -231,6 +231,4 @@ rewrite <- Union_assoc.
apply
f_equal
apply
f_equal
apply
Union_comm
apply
Union_comm
Qed
Qed
DO
NOT
EDIT
BELOW
DO
NOT
EDIT
BELOW
f31fb71f
@@ -221,6 +221,4 @@ destruct h.
apply
f_equal2
auto
apply
f_equal2
auto
apply
H_induc
intuition
apply
H_induc
intuition
Qed
Qed
DO
NOT
EDIT
BELOW
DO
NOT
EDIT
BELOW
f31fb71f
@@ -206,6 +206,4 @@ generalize (occ_non_negative X (elements a i j) (get a j)).
generalize
occ_non_negative
X
elements
a
j
n
get
a
j
generalize
occ_non_negative
X
elements
a
j
n
get
a
j
omega
omega
Qed
Qed
DO
NOT
EDIT
BELOW
DO
NOT
EDIT
BELOW
f31fb71f
@@ -209,32 +209,32 @@ Axiom Elements_set_inside2 : forall (a:Type), forall (a1:(map Z a)) (i:Z)
Axiom
Abs_le
forall
x
Z
y
Z
Zabs
x
y
Z
y
Z
x
Z
Axiom
Abs_le
forall
x
Z
y
Z
Zabs
x
y
Z
y
Z
x
Z
x
y
Z
x
y
Z
Definition
left
i
Z
Z
2
Z
i
Z
Z
Z
Definition
left
i
Z
Z
2
Z
i
Z
Z
Z
Definition
right
i
Z
Z
2
Z
i
Z
2
Z
Z
Definition
right
i
Z
Z
2
Z
i
Z
2
Z
Z
Definition
i
Z
Z
ZOdiv
i
Z
Z
2
Z
Definition
i
Z
Z
ZOdiv
i
Z
Z
2
Z
Axiom
Parent_inf
forall
i
Z
Z
i
Z
i
i
Z
Axiom
Parent_inf
forall
i
Z
Z
i
Z
i
i
Z
Axiom
Left_sup
forall
i
Z
Z
i
Z
i
left
i
Z
Axiom
Left_sup
forall
i
Z
Z
i
Z
i
left
i
Z
Axiom
Right_sup
forall
i
Z
Z
i
Z
i
right
i
Z
Axiom
Right_sup
forall
i
Z
Z
i
Z
i
right
i
Z
Axiom
Parent_right
forall
i
Z
Z
i
Z
right
i
i
Axiom
Parent_right
forall
i
Z
Z
i
Z
right
i
i
Axiom
Parent_left
forall
i
Z
Z
i
Z
left
i
i
Axiom
Parent_left
forall
i
Z
Z
i
Z
left
i
i
Axiom
Inf_parent
forall
i
Z
j
Z
Z
j
Z
Axiom
Inf_parent
forall
i
Z
j
Z
Z
j
Z
j
right
i
Z
j
i
Z
j
right
i
Z
j
i
Z
Axiom
Child_parent
forall
i
Z
Z
i
Z
Axiom
Child_parent
forall
i
Z
Z
i
Z
i
left
i
i
right
i
i
left
i
i
right1
i
Axiom
Parent_pos
forall
j
Z
Z
j
Z
Z
j
Z
Axiom
Parent_pos
forall
j
Z
Z
j
Z
Z
j
Z
Definition
parentChild
i
Z
j
Z
Prop
Z
i
Z
i
j
Z
Definition
parentChild
i
Z
j
Z
Prop
Z
i
Z
i
j
Z
j
left
i
j
right
i
j
left
i
j
right1
i
Definition
map1
map
Z
Z
Definition
map1
map
Z
Z
@@ -260,9 +260,9 @@ Axiom Is_heap_sub2 : forall (a:(map Z Z)) (n:Z), (is_heap_array a 0%Z n) ->
Axiom
forall
a
map
Z
Z
n
Z
e
Z
idx
Z
Axiom
forall
a
map
Z
Z
n
Z
e
Z
idx
Z
i
Z
Z
i
Z
i
n
Z
is_heap_array
a
idx
n
i
Z
Z
i
Z
i
n
Z
is_heap_array
a
idx
n
Z
i
Z
get
a
i
e
Z
left
i
n
Z
Z
i
Z
get
a
i
e
Z
left
i
n
Z
e
get
a
left
i
Z
right
i
n
Z
e
get
a
e
get
a
left
i
Z
right1
i
n
Z
e
get
a
right
i
Z
is_heap_array
set
a
i
e
idx
n
right
i
Z
is_heap_array
set
a
i
e
idx
n
Axiom
Is_heap_add_last
forall
a
map
Z
Z
n
Z
e
Z
Z
n
Z
Axiom
Is_heap_add_last
forall
a
map
Z
Z
n
Z
e
Z
Z
n
Z
is_heap_array
a
Z
n
get
a
n
e
Z
is_heap_array
a
Z
n
get
a
n
e
Z
@@ -273,12 +273,12 @@ Axiom Parent_inf_el : forall (a:(map Z Z)) (n:Z), (is_heap_array a 0%Z n) ->
j
Z
j
Z
Axiom
Left_sup_el
forall
a
map
Z
Z
n
Z
is_heap_array
a
Z
n
Axiom
Left_sup_el
forall
a
map
Z
Z
n
Z
is_heap_array
a
Z
n
forall
j
Z
Z
j
Z
j
n
Z
left
j
n
Z
get
a
forall
j
Z
Z
j
Z
j
n
Z
left
j
n
Z
j
get
a
left
j
Z
get
a
j
get
a
left1
j
Z
Axiom
Right_sup_el
forall
a
map
Z
Z
n
Z
is_heap_array
a
Z
n
Axiom
Right_sup_el
forall
a
map
Z
Z
n
Z
is_heap_array
a
Z
n
forall
j
Z
Z
j
Z
j
n
Z
right
j
n
Z
forall
j
Z
Z
j
Z
j
n
Z
right
j
n
Z
get
a
j
get
a
right
j
Z
get
a
j
get
a
right
j
Z
Axiom
Is_heap_relation
forall
a
map
Z
Z
n
Z
Z
n
Z
Axiom
Is_heap_relation
forall
a
map
Z
Z
n
Z
Z
n
Z
is_heap_array
a
Z
n
forall
j
Z
Z
j
Z
j
n
Z
is_heap_array
a
Z
n
forall
j
Z
Z
j
Z
j
n
Z
@@ -299,13 +299,12 @@ Axiom Model_singleton : forall (a:(map Z Z)), ((model (a,
DO
NOT
EDIT
BELOW
DO
NOT
EDIT
BELOW
Theorem
Model_set
forall
a
map
Z
Z
aqt
map
Z
Z
v
Z
i
Z
n
Z
Theorem
Model_set
forall
a
map
Z
Z
v
Z
i
Z
n
Z
Z
i
Z
Z
i
Z
i
n
Z
aqt
set
a
i
v
add
get
a
i
i
n
Z
add
get
a
i
model
set
a
i
v
n
add
v
model
model
aqt
n
add
v
model
a
n
a
n
YOU
MAY
EDIT
THE
PROOF
BELOW
YOU
MAY
EDIT
THE
PROOF
BELOW
intros
a
a0
v
i
n
H_i
H_a0
intros
a
v
i
n
H_is
unfold
model
in
unfold
model
in
subst
a0
rewrite
Elements_union
i
j
i
k
n
auto
rewrite
Elements_union
i
j
i
k
n
auto
pattern
elements
set
a
i
v
i
rewrite
auto
pattern
elements
set
a
i
v
i
rewrite
auto
rewrite
Elements_add1
i
i
j
n
auto
rewrite
Elements_add1
i
i
j
n
auto
f31fb71f
This diff is collapsed.
f31fb71f
module TestHarness
module TestHarness
(**** logic declarations *****)
