GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
f173d328
f173d328
Andrei Paskevich
add version-printing option + set VERSION to 0.63
212c6d7e
6
6 changed files
57 additions
9 deletions
+57
-9
Version
Version
+1
-1
src/bench/whybench.ml
+13
-2
src/config/whyconfig.ml
+13
-2
src/ide/gconfig.ml
src/ide/gconfig.ml
+1
-1
src/ide/gmain.ml
src/ide/gmain.ml
+17
-1
src/main.ml
src/main.ml
+12
-2
Version
f173d328
# Why version
# Why version
VERSION=0.
10
VERSION=0.
63
f173d328
@@ -33,6 +33,9 @@ let usage_msg = sprintf
[-P <prover> ]..."
[-P <prover> ]..."
Filename
basename
Sys
argv
Filename
basename
Sys
argv
let
version_msg
sprintf
"Why3 bench tool, version %s (build date: %s)"
Config
version
Config
builddate
let
opt_queue
Queue
create
let
opt_queue
Queue
create
let
opt_input
ref
None
let
opt_input
ref
None
@@ -109,6 +112,7 @@ let opt_list_metas = ref false
let
opt_list_flags
ref
false
let
opt_list_flags
ref
false
let
opt_debug_all
ref
false
let
opt_debug_all
ref
false
let
opt_version
ref
false
let
opt_quiet
ref
false
let
opt_quiet
ref
false
@@ -183,7 +187,10 @@ let option_list = Arg.align [
" Set all debug flags (except parse_only and type_only)"
"--debug"
Arg
String
add_opt_debug
"--debug"
Arg
String
add_opt_debug
"<flag> Set a debug flag"
"--quiet"
Arg
Set
opt_quiet
" Print only what asked"
"--quiet"
Arg
Set
opt_quiet
"--version"
Arg
Set
opt_version
" Print version information"
let
tools
ref
let
tools
ref
@@ -215,6 +222,10 @@ let () =
(** listings*)
(** listings*)
let
opt_list
ref
false
in
let
opt_list
ref
false
in
if
opt_version
then
begin
opt_list
true
printf
"%s@."
version_msg
if
opt_list_transforms
then
begin
if
opt_list_transforms
then
begin
opt_list
true
opt_list
true
printf
"@[<hov 2>Known non-splitting transformations:@
\n
%a@]@
\n
printf
\n
%a@]@
\n
@@ -222,7 +233,7 @@ let () =
sort
String
compare
Trans
list_transforms
sort
String
compare
Trans
list_transforms
printf
"@[<hov 2>Known splitting transformations:@
\n
%a@]@
\n
printf
\n
%a@]@
\n
Pp
print_list
Pp
newline
Pp
string
Pp
print_list
Pp
newline
Pp
string
sort
String
compare
Trans
list_transforms_l
sort
String
compare
Trans
list_transforms_l
if
opt_list_printers
then
begin
if
opt_list_printers
then
begin
opt_list
true
opt_list
true
f173d328
@@ -27,11 +27,16 @@ let usage_msg =
$WHY3LIB and $WHYDATA are used only when a configuration file is created"
Filename
basename
Sys
argv
Filename
basename
Sys
argv
let
version_msg
sprintf
"Why3 configuration utility, version %s (build date: %s)"
Config
version
Config
builddate
(* let libdir = ref None *)
(* let datadir = ref None *)
let
conf_file
ref
None
let
conf_file
ref
None
let
autoprovers
ref
false
let
autoprovers
ref
false
let
autoplugins
ref
false
let
autoplugins
ref
false
let
opt_version
ref
false
let
save
ref
true
let
save
ref
true
@@ -54,9 +59,11 @@ let option_list = Arg.align [
"--autodetect-plugins"
Arg
Set
autoplugins
Arg
Set
autoplugins
" autodetect the plugins in the default library directories"
"--install-plugin"
Arg
String
add_plugin
"--install-plugin"
Arg
String
add_plugin
"install a plugin to the actual libdir"
"--dont-save"
Arg
Clear
save
"--dont-save"
Arg
Clear
save
"dont modify the config file"
" dont modify the config file"
"--version"
Arg
Set
opt_version
" print version information"
let
anon_file
_
Arg
usage
option_list
usage_msg
exit
let
anon_file
_
Arg
usage
option_list
usage_msg
exit
@@ -94,6 +101,10 @@ let plugins_auto_detection config =
let
let
Arg
parse
option_list
anon_file
usage_msg
Arg
parse
option_list
anon_file
usage_msg
if
opt_version
then
begin
printf
"%s@."
version_msg
exit
let
config
let
config
try
read_config
conf_file
try
read_config
conf_file
Not_found
Not_found
src/ide/gconfig.ml
f173d328
@@ -299,7 +299,7 @@ let show_about_window () =
"Andrei Paskevich"
"Andrei Paskevich"
copyright
"Copyright 2010 Univ Paris-Sud, CNRS, INRIA"
copyright
license
"G
nu
Lesser General Public License"
license
"G
NU
website
"https://gforge.inria.fr/projects/why3"
website
website_label
"Project web site"
website_label
"Project web site"
version
Config
version
version
Config
version
src/ide/gmain.ml
f173d328
@@ -92,6 +92,7 @@ open Gconfig
let
includes
ref
let
includes
ref
let
file
ref
None
let
file
ref
None
let
opt_version
ref
false
let
spec
Arg
align
let
spec
Arg
align
"-I"
"-I"
@@ -102,9 +103,18 @@ let spec = Arg.align [
Arg.String (fun s -> input_files := s :: !input_files),
"<f> add file f to the project (ignored if it is already there)") ;
"-v"
Arg
Set
opt_version
let
usage_str
"whydb [options] [<file.why>|<project directory>]"
let
version_msg
sprintf
"Why3 IDE, version %s (build date: %s)"
Config
version
Config
builddate
let
usage_str
sprintf
"Usage: %s [options] [<file.why>|<project directory>]"
Filename
basename
Sys
argv
let
set_file
f
match
file
let
set_file
f
match
file
Some
_
Some
_
raise
Arg
Bad
"only one parameter"
raise
Arg
Bad
@@ -113,6 +123,12 @@ let set_file f = match !file with
let
Arg
parse
spec
set_file
usage_str
let
Arg
parse
spec
set_file
usage_str
let
if
opt_version
then
begin
printf
"%s@."
version_msg
exit
let
fname
match
file
let
fname
match
file
None
None
Arg
usage
spec
usage_str
Arg
usage
spec
usage_str
src/main.ml
f173d328
@@ -30,6 +30,9 @@ let usage_msg = sprintf
"Usage: %s [options] [[file|-] [-T <theory> [-G <goal>]...]...]..."
Filename
basename
Sys
argv
Filename
basename
Sys
argv
let
version_msg
sprintf
"Why3 platform, version %s (build date: %s)"
Config
version
Config
builddate
let
opt_queue
Queue
create
let
opt_queue
Queue
create
let
opt_input
ref
None
let
opt_input
ref
None
@@ -109,6 +112,7 @@ let opt_list_flags = ref false
let
opt_parse_only
ref
false
let
opt_parse_only
ref
false
let
opt_type_only
ref
false
let
opt_type_only
ref
false
let
opt_debug_all
ref
false
let
opt_debug_all
ref
false
let
opt_version
ref
false
let
option_list
Arg
align
let
option_list
Arg
align
Arg
Unit
fun
add_opt_file
Arg
Unit
fun
add_opt_file
@@ -186,7 +190,9 @@ let option_list = Arg.align [
"--debug-all"
Arg
Set
opt_debug_all
"--debug-all"
Arg
Set
opt_debug_all
"--debug"
Arg
String
add_opt_debug
"--debug"
Arg
String
add_opt_debug
"--version"
Arg
Set
opt_version
let
let
try
try
@@ -218,6 +224,10 @@ let () =
(** listings*)
(** listings*)
let
opt_list
ref
false
in
let
opt_list
ref
false
in
if
opt_version
then
begin
opt_list
true
printf
"%s@."
version_msg
if
opt_list_transforms
then
begin
if
opt_list_transforms
then
begin
opt_list
true
opt_list
true
printf
\n
%a@]@
\n
printf
\n
%a@]@
\n
@@ -225,7 +235,7 @@ let () =
sort
String
compare
Trans
list_transforms
sort
String
compare
Trans
list_transforms
printf
\n
%a@]@
\n
printf
\n
%a@]@
\n
Pp
print_list
Pp
newline
Pp
string
Pp
print_list
Pp
newline
Pp
string
sort
String
compare
Trans
list_transforms_l
sort
String
compare
Trans
list_transforms_l
if
opt_list_printers
then
begin
if
opt_list_printers
then
begin
opt_list
true
opt_list
true
