Commit f03a6487 authored by MARCHE Claude's avatar MARCHE Claude
updated ROADMAP
parent a3f04195
...@@ -113,6 +113,13 @@ ...@@ -113,6 +113,13 @@
== TODOs == == TODOs ==
* eliminate_match: (apres la release ?)
** faire un cas particulier pour "bool", le match pouvant se traduire
vers ite qui est supporté par pas mal de prouveurs
** introduire des symboles _match non polymorphes differents pour
chaque instance necessaires. plutot qu'un seul symbole _match
poymorphe.
* extraction vers Caml * extraction vers Caml
** utiliser ZArith ** utiliser ZArith
...@@ -175,10 +182,10 @@ Scheduled for 31 october 2013 ...@@ -175,10 +182,10 @@ Scheduled for 31 october 2013
* why3session * why3session
** --stats: changed (detailler, temps, distinction root et subgoals, CLAUDE) ** --stats: changed (detailler, temps, distinction root et subgoals, CLAUDE)
** --hist: TODO documenter (voir Alain ou Mohamed sur les graphes SMT) ** --hist: TODO documenter (voir Alain ou Mohamed sur les graphes SMT)
* bug fixes: * bug fixes:
** remove extra leading zeros in decimal literals when a prover don't like them ** remove extra leading zeros in decimal literals when a prover don't like them
** PVS output: types are always non-empty ** PVS output: types are always non-empty
** PVS: fixed configuration and installation process ** PVS: fixed configuration and installation process
** improved shape mecanism for session updates (see VSTTE'13 paper). ** improved shape mecanism for session updates (see VSTTE'13 paper).
...@@ -186,9 +193,11 @@ Scheduled for 31 october 2013 ...@@ -186,9 +193,11 @@ Scheduled for 31 october 2013
assured. assured.
** Coq tactic: now loads dynamic plug-ins ** Coq tactic: now loads dynamic plug-ins
** Coq output: fixed printing of polymorphic recursive datatypes ** Coq output: fixed printing of polymorphic recursive datatypes
** bug #15493: ? ** bug #15493: correct Coq output for polymorphic algebraic data types
** bug #15053: ? ** wish #15053: Remove proof time from "Goals proved by only one prover" section of why3session info --stats
** bug #13736: ? ** bug #13736: why3ml was slow when there are many inclusions
** bug #16488: decimals in TPTP syntax
** bug #16454: do not send arithmetic triggers anymore to alt-Ergo
** syntax highlighting bugs: should be fixed by removing the old language ** syntax highlighting bugs: should be fixed by removing the old language
file alt-ergo.lang from alt-ergo distribution file alt-ergo.lang from alt-ergo distribution
...@@ -267,19 +276,11 @@ Scheduled for 31 october 2013 ...@@ -267,19 +276,11 @@ Scheduled for 31 october 2013
* Patch de johannes pour les noms de fichier pour Isabelle TODO * DONE Patch de johannes pour les noms de fichier pour Isabelle
* discriminate, mettre les bons arguments par defaut (ANDREI) * DONE discriminate, mettre les bons arguments par defaut (ANDREI)
DONE ?
poymorphe.
* efficiency issues * DONE efficiency issues
** understand problems when large number of goals (cf D Mentré examples) ** understand problems when large number of goals (cf D Mentré examples)
** prouveur de Martin ** prouveur de Martin
** tester avant la release sur ** tester avant la release sur
...@@ -311,18 +312,18 @@ Scheduled for 31 october 2013 ...@@ -311,18 +312,18 @@ Scheduled for 31 october 2013
transformations, write new functions on terms transformations, write new functions on terms
- LEON: add a section "further reading" - LEON: add a section "further reading"
* bug fix: 16454 (ne pas envoyer des triggers arithmetiques) (GUILLAUME) * DONE bug fix: 16454 (ne pas envoyer des triggers arithmetiques) (GUILLAUME)
* bug fix: 15652 (ghost code detection) * DONE ? bug fix: 15652 (ghost code detection)
* support for new provers * support for new provers
** Alt-Ergo 0.95.2 DONE ** Alt-Ergo 0.95.2 DONE
** CVC4 1.2 TODO: pb avec les booleens ** CVC4 1.2 DONE: pb avec les booleens
** DONE Coq 8.4pl2: probleme tactique Why3 ** DONE Coq 8.4pl2: probleme tactique Why3
** DONE ? Metitarski: improve it (CLAUDE, GUILLAUME) ** DONE Metitarski: improve it (CLAUDE, GUILLAUME)
* DONE? simplification de (a && false) ne devrait pas etre false * DONE simplification de (a && false) ne devrait pas etre false
