Commit eff3027f authored by Sylvain Dailler's avatar Sylvain Dailler
Adding copy/paste.
Also copy as detached goal.
parent 0c757798
...@@ -428,7 +428,6 @@ let reload_menu_item : GMenu.menu_item = ...@@ -428,7 +428,6 @@ let reload_menu_item : GMenu.menu_item =
create_root (); create_root ();
send_request Reload_req) send_request Reload_req)
(* vpan222 contains: (* vpan222 contains:
2.2.2.1 a view of the current task 2.2.2.1 a view of the current task
2.2.2.2 a vertiacal pan which contains 2.2.2.2 a vertiacal pan which contains
...@@ -811,6 +810,53 @@ let remove_item: GMenu.menu_item = ...@@ -811,6 +810,53 @@ let remove_item: GMenu.menu_item =
| [r] -> let id = get_node_id r#iter in send_request (Remove_subtree id) | [r] -> let id = get_node_id r#iter in send_request (Remove_subtree id)
| _ -> print_message "Select only one node to perform this action") | _ -> print_message "Select only one node to perform this action")
(* Commands of the Experimental menu *)
let exp_menu = factory#add_submenu "_Experimental"
let exp_factory = new GMenu.factory exp_menu ~accel_group
(* Current copied node *)
let saved_copy = ref None
let copy () =
match get_selected_row_references () with
| [r] -> let n = get_node_id r#iter in
saved_copy := Some n
| _ -> ()
let paste () =
| [r] ->
let m = get_node_id r#iter in
(match !saved_copy with
| Some n -> send_request (Copy_paste (n, m))
| None -> ())
| _ -> ()
let detached_copy () =
send_request (Copy_detached n)
| _ -> ()
let (_ : GMenu.menu_item) =
exp_factory#add_item ~key:GdkKeysyms._C
~callback:copy "Copy"
exp_factory#add_item ~key:GdkKeysyms._V
~callback:paste "Paste"
exp_factory#add_item ~key:GdkKeysyms._D
~callback:detached_copy "Detached copy"
(* add a new file in the project *) (* add a new file in the project *)
...@@ -567,6 +567,65 @@ let run_strategy_on_goal c id strat ~callback_pa ~callback_tr ~callback ~notific ...@@ -567,6 +567,65 @@ let run_strategy_on_goal c id strat ~callback_pa ~callback_tr ~callback ~notific
in in
exec_strategy 0 strat id exec_strategy 0 strat id
let schedule_pa_with_same_arguments c (pa: proof_attempt_node) (pn: proofNodeID) ~callback ~notification =
let prover = pa.prover in
let limit = pa.limit in
schedule_proof_attempt c pn prover ~limit ~callback ~notification
let schedule_tr_with_same_arguments c (tr: transID) (pn: proofNodeID) ~callback ~notification =
let s = c.controller_session in
let args = get_transf_args s tr in
let name = get_transf_name s tr in
schedule_transformation c pn name args ~callback ~notification
exception BadCopyPaste
(* Reproduce the transformation made on node on an other one *)
let rec copy_paste ~notification ~callback_pa ~callback_tr c from_any to_any =
if (not (is_below s from_any to_any) &&
not (is_below s to_any from_any)) then
match from_any, to_any with
| AFile _, AFile _ ->
raise BadCopyPaste
| ATh _from_th, ATh _to_th ->
raise BadCopyPaste
| APn from_pn, APn to_pn ->
let from_pa_list = get_proof_attempts s from_pn in
List.iter (fun x -> schedule_pa_with_same_arguments c x to_pn
~callback:callback_pa ~notification) from_pa_list;
let from_tr_list = get_transformations s from_pn in
let callback x st = callback_tr st;
match st with
| TSdone tid -> copy_paste c (ATn x) (ATn tid) ~notification ~callback_pa ~callback_tr
| _ -> ()
in
List.iter (fun x -> schedule_tr_with_same_arguments c x to_pn
~callback:(callback x) ~notification) from_tr_list
| ATn from_tn, ATn to_tn ->
let from_tn_list = get_sub_tasks s from_tn in
let to_tn_list = get_sub_tasks s to_tn in
if (List.length from_tn_list = List.length to_tn_list) then
List.iter2 (fun x y -> copy_paste c (APn x) (APn y)
~notification ~callback_pa ~callback_tr) from_tn_list to_tn_list
| _ -> raise BadCopyPaste
let copy_detached ~copy c from_any =
match from_any with
| APn from_pn ->
begin
let pn_id = copy_proof_node_as_detached c.controller_session from_pn in
let parent = get_any_parent c.controller_session from_any in
match parent with
| None -> raise BadCopyDetached
| Some parent ->
copy ~parent (APn pn_id);
copy_structure ~notification:copy c.controller_session (APn from_pn) (APn pn_id)
| _ -> raise BadCopyDetached (* Only goal can be detached *)
let replay_proof_attempt c pr limit (id: proofNodeID) ~callback = let replay_proof_attempt c pr limit (id: proofNodeID) ~callback =
(* The replay can be done on a different machine so we need (* The replay can be done on a different machine so we need
...@@ -206,6 +206,16 @@ type report = ...@@ -206,6 +206,16 @@ type report =
| No_former_result of Call_provers.prover_result | No_former_result of Call_provers.prover_result
(** Type for the reporting of a replayed call *) (** Type for the reporting of a replayed call *)
(* [copy_paste c a b] try to copy subtree originating at node a to node b *)
val copy_paste:
notification:(any -> bool -> unit) ->
callback_pa:(proofAttemptID -> proof_attempt_status -> unit) ->
callback_tr:(transformation_status -> unit) ->
controller -> any -> any -> unit
val copy_detached:
copy:(parent:any -> any -> unit) ->
controller -> any -> unit
(* Callback for the report printing of replay (* Callback for the report printing of replay
TODO to be removed when we have a better way to print the result of replay *) TODO to be removed when we have a better way to print the result of replay *)
...@@ -372,6 +372,8 @@ type ide_request = ...@@ -372,6 +372,8 @@ type ide_request =
| Set_max_tasks_req of int | Set_max_tasks_req of int
| Get_task of node_ID | Get_task of node_ID
| Remove_subtree of node_ID | Remove_subtree of node_ID
| Copy_paste of node_ID * node_ID
| Copy_detached of node_ID
| Get_Session_Tree_req | Get_Session_Tree_req
| Save_req | Save_req
| Reload_req | Reload_req
...@@ -390,6 +392,8 @@ let print_request fmt r = ...@@ -390,6 +392,8 @@ let print_request fmt r =
| Set_max_tasks_req i -> fprintf fmt "set max tasks %i" i | Set_max_tasks_req i -> fprintf fmt "set max tasks %i" i
| Get_task _nid -> fprintf fmt "get task" | Get_task _nid -> fprintf fmt "get task"
| Remove_subtree _nid -> fprintf fmt "remove subtree" | Remove_subtree _nid -> fprintf fmt "remove subtree"
| Copy_paste _ -> fprintf fmt "copy paste"
| Copy_detached _ -> fprintf fmt "copy detached"
| Get_Session_Tree_req -> fprintf fmt "get session tree" | Get_Session_Tree_req -> fprintf fmt "get session tree"
| Save_req -> fprintf fmt "save" | Save_req -> fprintf fmt "save"
| Reload_req -> fprintf fmt "reload" | Reload_req -> fprintf fmt "reload"
...@@ -465,7 +469,6 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -465,7 +469,6 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
let get_prover_list (config: Whyconf.config) = let get_prover_list (config: Whyconf.config) =
Mstr.fold (fun x _ acc -> x :: acc) (Whyconf.get_prover_shortcuts config) [] Mstr.fold (fun x _ acc -> x :: acc) (Whyconf.get_prover_shortcuts config) []
let init_server config env = let init_server config env =
let provers = Whyconf.get_provers config in let provers = Whyconf.get_provers config in
let c = create_controller env in let c = create_controller env in
...@@ -944,7 +947,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -944,7 +947,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
| Transform_req (nid, t, args) -> apply_transform nid t args | Transform_req (nid, t, args) -> apply_transform nid t args
| Strategy_req (nid, st) -> run_strategy_on_task nid st | Strategy_req (nid, st) -> run_strategy_on_task nid st
| Save_req -> save_session () | Save_req -> save_session ()
| Reload_req -> reload_session (); | Reload_req -> reload_session ()
| Get_Session_Tree_req -> resend_the_tree () | Get_Session_Tree_req -> resend_the_tree ()
| Remove_subtree nid -> | Remove_subtree nid ->
let n = any_from_node_ID nid in let n = any_from_node_ID nid in
...@@ -956,6 +959,21 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -956,6 +959,21 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
with RemoveError -> (* TODO send an error instead of information *) with RemoveError -> (* TODO send an error instead of information *)
P.notify (Message (Information "Cannot remove a proof node or theory")) P.notify (Message (Information "Cannot remove a proof node or theory"))
end end
| Copy_paste (from_id, to_id) ->
let from_any = any_from_node_ID from_id in
let to_any = any_from_node_ID to_id in
C.copy_paste ~notification:notify_change_proved
~callback_pa:(callback_update_tree_proof d.cont)
~callback_tr:(callback_update_tree_transform)
d.cont from_any to_any
| Copy_detached from_id ->
let copy ~parent p =
let parent = node_ID_from_any parent in
ignore (new_node ~parent p)
in
C.copy_detached ~copy d.cont from_any
| Get_task nid -> send_task nid | Get_task nid -> send_task nid
| Replay_req -> replay_session (); resend_the_tree () | Replay_req -> replay_session (); resend_the_tree ()
| Command_req (nid, cmd) -> | Command_req (nid, cmd) ->
...@@ -969,7 +987,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -969,7 +987,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
| Help_message s -> P.notify (Message (Help s)) | Help_message s -> P.notify (Message (Help s))
| QError s -> P.notify (Message (Query_Error (nid, s))) | QError s -> P.notify (Message (Query_Error (nid, s)))
| Other (s, _args) -> | Other (s, _args) ->
P.notify (Message (Information ("Unknown command"^s))) P.notify (Message (Information ("Unknown command: "^s)))
end end
| Add_file_req f -> | Add_file_req f ->
add_file_to_session d.cont f add_file_to_session d.cont f
...@@ -86,6 +86,8 @@ type ide_request = ...@@ -86,6 +86,8 @@ type ide_request =
| Save_req | Save_req
...@@ -123,6 +123,8 @@ let convert_request_constructor (r: ide_request) = ...@@ -123,6 +123,8 @@ let convert_request_constructor (r: ide_request) =
| Set_max_tasks_req _ -> String "Set_max_tasks_req" | Set_max_tasks_req _ -> String "Set_max_tasks_req"
| Get_task _ -> String "Get_task" | Get_task _ -> String "Get_task"
| Remove_subtree _ -> String "Remove_subtree" | Remove_subtree _ -> String "Remove_subtree"
| Copy_paste _ -> String "Copy_paste"
| Copy_detached _ -> String "Copy_detached"
| Get_Session_Tree_req -> String "Get_Session_Tree_req" | Get_Session_Tree_req -> String "Get_Session_Tree_req"
| Save_req -> String "Save_req" | Save_req -> String "Save_req"
| Reload_req -> String "Reload_req" | Reload_req -> String "Reload_req"
...@@ -165,6 +167,13 @@ let print_request_to_json (r: ide_request): json_object = ...@@ -165,6 +167,13 @@ let print_request_to_json (r: ide_request): json_object =
| Remove_subtree n -> | Remove_subtree n ->
Assoc ["ide_request", cc r; Assoc ["ide_request", cc r;
"node_ID", Int n] "node_ID", Int n]
"node_ID", Int from_id;
"node_ID", Int to_id]
"node_ID", Int from_id]
| Get_Session_Tree_req -> | Get_Session_Tree_req ->
Assoc ["ide_request", cc r] Assoc ["ide_request", cc r]
| Save_req -> | Save_req ->
...@@ -341,6 +350,10 @@ let parse_request (constr: string) l = ...@@ -341,6 +350,10 @@ let parse_request (constr: string) l =
Get_task n Get_task n
| "Remove_subtree", ["node_ID", Int n] -> | "Remove_subtree", ["node_ID", Int n] ->
Remove_subtree n Remove_subtree n
| "Copy_paste", ["node_ID", Int from_id; "node_ID", Int to_id] ->
| "Copy_detached", ["node_ID", Int n] ->
Copy_detached n
| "Get_Session_Tree_req", [] -> | "Get_Session_Tree_req", [] ->
Get_Session_Tree_req Get_Session_Tree_req
| "Save_req", [] -> | "Save_req", [] ->
...@@ -368,6 +368,29 @@ let theory_iter_proof_attempt s f th = ...@@ -368,6 +368,29 @@ let theory_iter_proof_attempt s f th =
f pan) f pan)
pn.proofn_attempts) th pn.proofn_attempts) th
(* Copy/Paste *)
let get_any_parent s a =
match a with
| AFile _f -> None
| ATh th -> Some (AFile (theory_parent s th))
| ATn tr -> Some (APn (get_trans_parent s tr))
| APn pn ->
(match (get_proofNode s pn).proofn_parent with
| Theory th -> Some (ATh th)
| Trans tr -> Some (ATn tr))
| APa pa ->
Some (APn (get_proof_attempt_node s pa).parent)
(* True if bid is an ancestor of aid, false if not *)
let rec is_below s (aid: any) (bid: any) =
aid = bid ||
match (get_any_parent s aid) with
| None -> false
| Some pid -> is_below s pid bid
open Format open Format
open Ident open Ident
...@@ -495,6 +518,25 @@ let mk_proof_node_no_task (s : session) (n : Ident.ident) ...@@ -495,6 +518,25 @@ let mk_proof_node_no_task (s : session) (n : Ident.ident)
proofn_transformations = [] } in proofn_transformations = [] } in
Hint.add s.proofNode_table node_id pn Hint.add s.proofNode_table node_id pn
(* Detach a new proof to a proof_parent *)
let graft_detached_proof_on_parent s (pn: proofNodeID) (parent: proof_parent) =
match parent with
| Theory th ->
th.theory_detached_goals <- th.theory_detached_goals @ [pn]
| Trans tr_id ->
let tr = get_transfNode s tr_id in
tr.transf_detached_subtasks <- tr.transf_detached_subtasks @ [pn]
(* Intended as a feature to save a proof (also for testing detached stuff) *)
let copy_proof_node_as_detached (s: session) (pn_id: proofNodeID) =
let pn = get_proofNode s pn_id in
let new_pn_id = gen_proofNodeID s in
let parent = pn.proofn_parent in
let new_goal_name = Ident.id_register (Ident.id_clone pn.proofn_name) in
let _new_pn = mk_proof_node_no_task s new_goal_name parent new_pn_id pn.proofn_checksum pn.proofn_shape in
graft_detached_proof_on_parent s new_pn_id parent;
new_pn_id
let _mk_proof_node_task (s : session) (t : Task.task) let _mk_proof_node_task (s : session) (t : Task.task)
(parent : proof_parent) (node_id : proofNodeID) = (parent : proof_parent) (node_id : proofNodeID) =
let name,_,_ = Termcode.goal_expl_task ~root:false t in let name,_,_ = Termcode.goal_expl_task ~root:false t in
...@@ -524,6 +566,41 @@ let mk_transf_node (s : session) (id : proofNodeID) (node_id : transID) ...@@ -524,6 +566,41 @@ let mk_transf_node (s : session) (id : proofNodeID) (node_id : transID)
Hint.add s.trans_table node_id tn; Hint.add s.trans_table node_id tn;
pn.proofn_transformations <- node_id::pn.proofn_transformations pn.proofn_transformations <- node_id::pn.proofn_transformations
exception BadCopyDetached
let rec copy_structure ~notification s from_any to_any : unit =
| APn from_id, APn to_id ->
let transformations = get_transformations s from_id in
let new_transformations =
List.map (fun x ->
let tr_id = gen_transID s in
let old_tr = get_transfNode s x in
mk_transf_node s to_id tr_id old_tr.transf_name old_tr.transf_args [];
notification ~parent:to_any (ATn tr_id);
copy_structure ~notification s (ATn x) (ATn tr_id);
tr_id) transformations in
(get_proofNode s to_id).proofn_transformations <- new_transformations;
Hprover.iter (fun _k old_pa ->
let old_pa = get_proof_attempt_node s old_pa in
let pa_id = add_proof_attempt s old_pa.prover old_pa.limit None true None to_id in
notification ~parent:to_any (APa pa_id)) (get_proofNode s from_id).proofn_attempts
let sub_tasks = get_sub_tasks s from_tn in
let new_sub_tasks =
List.map (fun old_pn_id ->
let old_pn = get_proofNode s old_pn_id in
let pn_id = gen_proofNodeID s in
let new_id = Ident.id_register (Ident.id_clone old_pn.proofn_name) in
mk_proof_node_no_task s new_id (Trans to_tn)
pn_id old_pn.proofn_checksum old_pn.proofn_shape;
notification ~parent:to_any (APn pn_id);
copy_structure ~notification s (APn old_pn_id) (APn pn_id);
pn_id) sub_tasks in
let tr = get_transfNode s to_tn in
tr.transf_detached_subtasks <- new_sub_tasks
let graft_transf (s : session) (id : proofNodeID) (name : string) let graft_transf (s : session) (id : proofNodeID) (name : string)
(args : string list) (tl : Task.task list) = (args : string list) (tl : Task.task list) =
let tid = gen_transID s in let tid = gen_transID s in
...@@ -67,6 +67,9 @@ type proof_attempt_node = { ...@@ -67,6 +67,9 @@ type proof_attempt_node = {
val session_iter_proof_attempt: (proofNodeID -> proof_attempt_node -> unit) -> session -> unit val session_iter_proof_attempt: (proofNodeID -> proof_attempt_node -> unit) -> session -> unit
(* [is_below s a b] true if a is below b in the session tree *)
val is_below: session -> any -> any -> bool
type proof_parent = Trans of transID | Theory of theory type proof_parent = Trans of transID | Theory of theory
val get_task : session -> proofNodeID -> Task.task val get_task : session -> proofNodeID -> Task.task
...@@ -89,6 +92,14 @@ val get_proof_name : session -> proofNodeID -> Ident.ident ...@@ -89,6 +92,14 @@ val get_proof_name : session -> proofNodeID -> Ident.ident
val get_proof_parent : session -> proofNodeID -> proof_parent val get_proof_parent : session -> proofNodeID -> proof_parent
val get_trans_parent : session -> transID -> proofNodeID val get_trans_parent : session -> transID -> proofNodeID
val get_any_parent: session -> any -> any option
(** [copy s pn] copy pn and add the copy as detached subgoal of its parent *)
val copy_proof_node_as_detached: session -> proofNodeID -> proofNodeID
val copy_structure: notification:(parent:any -> any -> unit) -> session -> any -> any -> unit
val empty_session : ?shape_version:int -> string -> session val empty_session : ?shape_version:int -> string -> session
(** create an empty_session in the directory specified by the (** create an empty_session in the directory specified by the
argument *) argument *)
