Commit ee1c1d38 authored by MARCHE Claude's avatar MARCHE Claude
reimporting data
parent 07311f86
...@@ -82,7 +82,7 @@ end ...@@ -82,7 +82,7 @@ end
theory int.EuclideanDivision theory int.EuclideanDivision
prelude "Require Zdiv." prelude "Require Import Zdiv."
syntax logic div "(Zdiv %1 %2)" syntax logic div "(Zdiv %1 %2)"
syntax logic mod "(Zmod %1 %2)" syntax logic mod "(Zmod %1 %2)"
...@@ -91,7 +91,7 @@ end ...@@ -91,7 +91,7 @@ end
theory int.ComputerDivision theory int.ComputerDivision
prelude "Require ZOdiv." prelude "Require Import ZOdiv."
syntax logic div "(ZOdiv %1 %2)" syntax logic div "(ZOdiv %1 %2)"
syntax logic mod "(ZOmod %1 %2)" syntax logic mod "(ZOmod %1 %2)"
...@@ -27,7 +27,7 @@ let alt_ergo = ...@@ -27,7 +27,7 @@ let alt_ergo =
Util.Mstr.find "alt-ergo" provers Util.Mstr.find "alt-ergo" provers
with Not_found -> with Not_found ->
eprintf "Prover alt-ergo not installed or not configured@."; eprintf "Prover alt-ergo not installed or not configured@.";
failwith "Cannot continue without alt-ergo installed" exit 0
let alt_ergo_driver = Driver.load_driver env alt_ergo.Whyconf.driver let alt_ergo_driver = Driver.load_driver env alt_ergo.Whyconf.driver
...@@ -57,10 +57,10 @@ val read_channel : ?format:string -> read_channel ...@@ -57,10 +57,10 @@ val read_channel : ?format:string -> read_channel
the format is chosen according to [f]'s extension. the format is chosen according to [f]'s extension.
Beware that nothing ensures that [c] corresponds to the contents of [f] Beware that nothing ensures that [c] corresponds to the contents of [f]
@raise [NoFormat] if [format] is not given and [f] has no extension @raise NoFormat if [format] is not given and [f] has no extension
@raise [UnknownExtension s] if the extension [s] is not known in @raise UnknownExtension [s] if the extension [s] is not known in
any registered parser any registered parser
@raise [UnknownFormat f] if the [format] is not registered @raise UnknownFormat [f] if the [format] is not registered
val read_file : ?format:string -> env -> string -> theory Mnm.t val read_file : ?format:string -> env -> string -> theory Mnm.t
...@@ -116,12 +116,12 @@ let bind db sql l = ...@@ -116,12 +116,12 @@ let bind db sql l =
1 l 1 l
in stmt in stmt
let stmt_column_INT stmt i msg = let stmt_column_INT stmt i msg =
match Sqlite3.column stmt i with match Sqlite3.column stmt i with
| Sqlite3.Data.INT i -> i | Sqlite3.Data.INT i -> i
| _ -> failwith msg | _ -> failwith msg
let stmt_column_FLOAT stmt i msg = let stmt_column_FLOAT stmt i msg =
| Sqlite3.Data.FLOAT i -> i | Sqlite3.Data.FLOAT i -> i
...@@ -246,14 +246,12 @@ let subgoals t = t.subgoals ...@@ -246,14 +246,12 @@ let subgoals t = t.subgoals
type theory = int64 type theory = int64
let theory_name _ = assert false
let goals _ = assert false let goals _ = assert false
let verified _ = assert false let verified _ = assert false
type file = int64 type file = int64
let file_name _ = assert false let file_name _ = assert false
let theories _ = assert false
...@@ -721,9 +719,17 @@ module Goal = struct ...@@ -721,9 +719,17 @@ module Goal = struct
let sql = let sql =
"CREATE TABLE IF NOT EXISTS goals \ "CREATE TABLE IF NOT EXISTS goals \
(goal_id INTEGER PRIMARY KEY AUTOINCREMENT, \ (goal_id INTEGER PRIMARY KEY AUTOINCREMENT, \
goal_theory INTEGER,
goal_name TEXT, task_checksum TEXT, proved INTEGER);" goal_name TEXT, task_checksum TEXT, proved INTEGER);"
in in
db_must_ok db (fun () -> Sqlite3.exec db.raw_db sql); db_must_ok db (fun () -> Sqlite3.exec db.raw_db sql);
let sql =
"CREATE UNIQUE INDEX IF NOT EXISTS goal_theory_idx \
ON goals (goal_theory)"
in
let sql = "create table if not exists map_external_proofs_goal_external_proof (goal_id integer, external_proof_id integer, primary key(goal_id, external_proof_id));" in let sql = "create table if not exists map_external_proofs_goal_external_proof (goal_id integer, external_proof_id integer, primary key(goal_id, external_proof_id));" in
db_must_ok db (fun () -> Sqlite3.exec db.db sql); db_must_ok db (fun () -> Sqlite3.exec db.db sql);
...@@ -749,13 +755,14 @@ module Goal = struct ...@@ -749,13 +755,14 @@ module Goal = struct
db_must_ok db (fun () -> Sqlite3.exec db.raw_db sql) db_must_ok db (fun () -> Sqlite3.exec db.raw_db sql)
let add db (_th:theory) (name : string) (sum:string) = let add db (th:theory) (name : string) (sum:string) =
transaction db transaction db
(fun () -> (fun () ->
let sql = let sql =
"INSERT INTO goals VALUES(NULL,?,?,0)" "INSERT INTO goals VALUES(NULL,?,?,?,0)"
in in
let stmt = bind db sql [ let stmt = bind db sql [
Sqlite3.Data.INT th;
Sqlite3.Data.TEXT name; Sqlite3.Data.TEXT name;
Sqlite3.Data.TEXT sum; Sqlite3.Data.TEXT sum;
...@@ -1021,21 +1028,54 @@ end ...@@ -1021,21 +1028,54 @@ end
module Theory = struct module Theory = struct
let init db = let init db =
let sql = "CREATE TABLE IF NOT EXISTS theories (theory_name TEXT, theory_file INTEGER);" in let sql =
"CREATE TABLE IF NOT EXISTS theories \
(theory_id INTEGER PRIMARY KEY AUTOINCREMENT,\
theory_file INTEGER, theory_name TEXT);" in
let name db th =
let sql="SELECT theory_name FROM theories \
WHERE theories.theory_id=?"
in
let stmt = bind db sql [Sqlite3.Data.INT th] in
let of_stmt stmt =
(stmt_column_string stmt 0 "Theory.name")
in
match step_fold db stmt of_stmt with
| [] -> raise Not_found
| [x] -> x
| _ -> assert false
let of_file db f =
let sql="SELECT theory_id FROM theories \
WHERE theories.theory_file=?"
in
let stmt = bind db sql [Sqlite3.Data.INT f] in
let of_stmt stmt =
(stmt_column_INT stmt 0 "Theory.of_file")
in
let add db file name = let add db file name =
let sql = "INSERT INTO theories VALUES(?,?)" in let sql = "INSERT INTO theories VALUES(NULL,?,?)" in
let stmt = bind db sql [ Sqlite3.Data.TEXT name ; let stmt = bind db sql
Sqlite3.Data.INT file ] in [ Sqlite3.Data.INT file;
in
db_must_done db (fun () -> Sqlite3.step stmt); db_must_done db (fun () -> Sqlite3.step stmt);
let new_id = Sqlite3.last_insert_rowid db.raw_db in let new_id = Sqlite3.last_insert_rowid db.raw_db in
new_id) new_id)
end end
let theory_name th = Theory.name (current()) th
let theories f = Theory.of_file (current()) f
module Main = struct module Main = struct
...@@ -1043,17 +1083,22 @@ module Main = struct ...@@ -1043,17 +1083,22 @@ module Main = struct
(file_id INTEGER PRIMARY KEY AUTOINCREMENT,file_name TEXT);" (file_id INTEGER PRIMARY KEY AUTOINCREMENT,file_name TEXT);"
in in
let sql = let sql =
"CREATE UNIQUE INDEX IF NOT EXISTS file_idx \ "CREATE UNIQUE INDEX IF NOT EXISTS file_idx \
ON files (file_id)" ON files (file_id)"
in in
let all_files db = let all_files db =
let sql="SELECT file_name FROM files" in let sql="SELECT file_id,file_name FROM files" in
let stmt = Sqlite3.prepare db.raw_db sql in let stmt = Sqlite3.prepare db.raw_db sql in
let of_stmt stmt = stmt_column_string stmt 0 "Db.all_files" in let of_stmt stmt =
(stmt_column_INT stmt 0 "Db.all_files",
stmt_column_string stmt 1 "Db.all_files")
in
step_fold db stmt of_stmt step_fold db stmt of_stmt
let add db name = let add db name =
...@@ -1103,7 +1148,8 @@ let root_goals () = ...@@ -1103,7 +1148,8 @@ let root_goals () =
let files _ = assert false let files () =
Main.all_files (current())
let prover_from_name n = let prover_from_name n =
...@@ -112,8 +112,8 @@ val theories : file -> theory list ...@@ -112,8 +112,8 @@ val theories : file -> theory list
val init_base : string -> unit val init_base : string -> unit
(** opens or creates the current database, from given file name *) (** opens or creates the current database, from given file name *)
val files : unit -> file list val files : unit -> (file * string) list
(** returns the current set of files *) (** returns the current set of files, with their filenames *)
(** {2 Updates} *) (** {2 Updates} *)
...@@ -308,6 +308,21 @@ let task_checksum t = ...@@ -308,6 +308,21 @@ let task_checksum t =
fprintf str_formatter "%a@." Pretty.print_task t; fprintf str_formatter "%a@." Pretty.print_task t;
Digest.to_hex (Digest.string (flush_str_formatter ())) Digest.to_hex (Digest.string (flush_str_formatter ()))
let info_window mt s =
let d = GWindow.message_dialog
~message:s
~message_type:mt
~buttons:GWindow.Buttons.close
~title:"Why3 info or error"
~show:true ()
in
let (_ : GtkSignal.id) =
d#connect#response
~callback:(function `CLOSE | `DELETE_EVENT -> d#destroy ())
in
module Helpers = struct module Helpers = struct
let image_of_result = function let image_of_result = function
...@@ -363,9 +378,8 @@ module Helpers = struct ...@@ -363,9 +378,8 @@ module Helpers = struct
(image_of_result s); (image_of_result s);
if s = Scheduler.Success then set_proved a.proof_goal if s = Scheduler.Success then set_proved a.proof_goal
let add_theory mfile th = let add_theory_row mfile th db_theory =
let tname = th.Theory.th_name.Ident.id_string in let tname = th.Theory.th_name.Ident.id_string in
let db_theory = Db.add_theory mfile.file_db tname in
let parent = mfile.file_row in let parent = mfile.file_row in
let row = goals_model#append ~parent () in let row = goals_model#append ~parent () in
let mth = { theory = th; let mth = { theory = th;
...@@ -379,7 +393,14 @@ module Helpers = struct ...@@ -379,7 +393,14 @@ module Helpers = struct
goals_model#set ~row ~column:icon_column !image_directory; goals_model#set ~row ~column:icon_column !image_directory;
goals_model#set ~row ~column:index_column (Row_theory mth); goals_model#set ~row ~column:index_column (Row_theory mth);
goals_model#set ~row ~column:visible_column true; goals_model#set ~row ~column:visible_column true;
mth
let tasks = Task.split_theory th None None in let tasks = Task.split_theory th None None in
let mth = add_theory_row mfile th db_theory in
let row = mth.theory_row in
let goals = let goals =
List.fold_left List.fold_left
(fun acc t -> (fun acc t ->
...@@ -410,11 +431,7 @@ module Helpers = struct ...@@ -410,11 +431,7 @@ module Helpers = struct
if goals = [] then set_theory_proved mth; if goals = [] then set_theory_proved mth;
mth mth
let add_file_row f dbfile =
let add_file f =
try
let theories = Env.read_file gconfig.env f in
let dbfile = Db.add_file f in
let parent = goals_model#append () in let parent = goals_model#append () in
let mfile = { file_name = f; let mfile = { file_name = f;
file_row = parent; file_row = parent;
...@@ -428,6 +445,13 @@ module Helpers = struct ...@@ -428,6 +445,13 @@ module Helpers = struct
goals_model#set ~row:parent ~column:icon_column !image_directory; goals_model#set ~row:parent ~column:icon_column !image_directory;
goals_model#set ~row:parent ~column:index_column (Row_file mfile); goals_model#set ~row:parent ~column:index_column (Row_file mfile);
goals_model#set ~row:parent ~column:visible_column true; goals_model#set ~row:parent ~column:visible_column true;
mfile
let add_file f =
try
let mfile = add_file_row f dbfile in
let theories = let theories =
Theory.Mnm.fold Theory.Mnm.fold
(fun thname t acc -> (fun thname t acc ->
...@@ -441,27 +465,46 @@ module Helpers = struct ...@@ -441,27 +465,46 @@ module Helpers = struct
mfile.theories <- List.rev theories; mfile.theories <- List.rev theories;
if theories = [] then set_file_verified mfile if theories = [] then set_file_verified mfile
with e -> with e ->
eprintf "Error while reading file '%s': %a@." f fprintf str_formatter
Exn_printer.exn_printer e "@[Error while reading file@ '%s':@ %a@]" f
Exn_printer.exn_printer e;
let msg = flush_str_formatter () in
info_window `ERROR msg
end end
(* read previous data from db *)
TODO: read files from db let () =
let files = Db.files () in
List.iter
(fun (f,fn) ->
eprintf "Reimporting file '%s'@." fn;
let theories = Env.read_file gconfig.env fn in
let mfile = Helpers.add_file_row fn f in
let ths = Db.theories f in
List.iter
(fun db_th ->
let tname = Db.theory_name db_th in
eprintf "Reimporting theory '%s'@."tname;
let th = Theory.Mnm.find tname theories in
let (_mth : Model.theory) = Helpers.add_theory_row mfile th db_th in
( (* TODO *) )
ths
files
(* set up scheduler *)
let () = let () =
begin begin
Scheduler.async := GtkThread.async; Scheduler.async := GtkThread.async;
match config.running_provers_max with
| None -> ()
| Some n ->
if n >= 1 then Scheduler.maximum_running_proofs := n
Scheduler.maximum_running_proofs := gconfig.max_running_processes Scheduler.maximum_running_proofs := gconfig.max_running_processes
end end
...@@ -870,21 +913,6 @@ let () = ...@@ -870,21 +913,6 @@ let () =
(* Help menu *) (* Help menu *)
let info_window t s () =
~message:s
~message_type:`INFO
~title:t
~show:true ()
in
d#connect#response
in
let help_menu = factory#add_submenu "_Help" let help_menu = factory#add_submenu "_Help"
let help_factory = new GMenu.factory help_menu ~accel_group let help_factory = new GMenu.factory help_menu ~accel_group
