Commit eda26846 authored by Martin Clochard's avatar Martin Clochard
Transformation compute: reduce partial function application
parent 5e54ace2
...@@ -568,40 +568,58 @@ and reduce_app engine st ls ~orig ty rem_cont = ...@@ -568,40 +568,58 @@ and reduce_app engine st ls ~orig ty rem_cont =
and reduce_func_app ~orig ty rem_st t1 t2 rem_cont = and reduce_func_app ~orig ty rem_st t1 t2 rem_cont =
try try
Format.eprintf "[compute] found (... @@ ...)@.";
(* attempt to decompile t1 under the form (* attempt to decompile t1 under the form
(epsilon fc. forall x. fc @ x = body) (epsilon fc. forall x. fc @ x = body)
that is equivalent to \x.body *) that is equivalent to \x.body *)
match t1 with match t1 with
| Term { t_node = Teps tb } -> | Term { t_node = Teps tb } ->
Format.eprintf "[compute] found (Teps(fc,...) @@ ...) @.";
let fc,t = Term.t_open_bound tb in let fc,t = Term.t_open_bound tb in
begin match t.t_node with begin match t.t_node with
| Tquant(Tforall,tq) -> | Tquant(Tforall,tq) ->
Format.eprintf "[compute] found (Teps(fc,Tforall ...) @@ ...) @."; let vl,trig,t = t_open_quant tq in
let vl,_,t = t_open_quant tq in
begin begin
match vl with match t.t_node with
| [x] -> | Tapp (ls1,[lhs;body]) when ls_equal ls1 ps_equ ->
Format.eprintf "[compute] found (Teps(fc,Tforall x...) @@ ...) @."; let rvl = List.rev vl in
begin let rec remove_var lhs rvh rvt = match lhs.t_node with
match t.t_node with | Tapp (ls2,[lhs1;{t_node = Tvar v1} as arg])
| Tapp(ls1, when ls_equal ls2 fs_func_app && vs_equal v1 rvh ->
[{t_node = begin
Tapp(ls2, match rvt , lhs1 with
[{t_node = Tvar v1};{t_node = Tvar v2}])}; | rvh::rvt , _ ->
body]) let lhs1 , fc2 = remove_var lhs1 rvh rvt in
when ls_equal ls1 ps_equ && ls_equal ls2 fs_func_app && let lhs2 = t_app ls2 [lhs1;arg] lhs.t_ty in
vs_equal v1 fc && vs_equal v2 x -> t_label_copy lhs lhs2 , fc2
(* GOT IT ! *) | [] , { t_node = Tvar fc1 } when vs_equal fc1 fc ->
Format.eprintf "[compute] found (Teps(fc,Tforall x. fc@@x = body) @@ ...) @."; let fcn = fc.vs_name in
let t2 = term_of_value t2 in let fc2 = Ident.id_derive fcn.Ident.id_string fcn in
{ value_stack = rem_st; let fc2 = create_vsymbol fc2 (t_type lhs) in
cont_stack = t_label_copy lhs (t_var fc2) , fc2
(Keval(body, Mvs.add x t2 Mvs.empty), | _ -> raise Undetermined
t_label_copy orig body) :: rem_cont; end
| _ -> raise Undetermined | _ -> raise Undetermined
in
begin
match rvl with
| rvh :: rvt -> let lhs , fc2 = remove_var lhs rvh rvt in
let (vh,vl) = match vl with
| [] -> assert false
| vh::vl -> (vh,vl)
in
let body = match vl with
| [] -> body
| _ ->
let eq = t_label_copy t (t_app ps_equ [lhs;body] None) in
let tq = t_quant Tforall (t_close_quant vl trig eq) in
t_label_copy t (t_eps_close fc2 tq)
in
cont_stack =
(Keval(body,Mvs.add vh t2 Mvs.empty),
end end
end end
