Commit eafe468e authored by François Bobot's avatar François Bobot
smoke detector added to the replayer
The smoke detector try to detect when a goal is proved
because the context is self contradicting.
The way it is configured in session is not very pretty.
parent a5b137d2
......@@ -131,7 +131,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula \
encoding_explicit encoding_guard encoding_sort \
encoding_instantiate simplify_array filter_trigger \
introduction abstraction close_epsilon lift_epsilon \
eval_match instantiate_predicate
eval_match instantiate_predicate smoke_detector
LIB_PRINTER = print_number alt_ergo why3printer smtv1 smtv2 \
coq tptp simplify gappa cvc3 yices
......@@ -487,9 +487,12 @@ not and you have to use the IDE to update it.
\begin{itemize}
\item The exit code is 0 if no difference was detected, 1 if there
was. Other exit codes mean some failure in running the replay.
\item option \texttt{-s}: suppresses the output of the final tree view
\item option \texttt{-I \textsl{<path>}}: add \textsl{<path>} to the loadpath
\item option \texttt{-force}: force writing a new session file even if some proofs did not replay correctly.
\item option \texttt{-s}: suppresses the output of the final tree view.
\item option \texttt{-I \textsl{<path>}}: add \textsl{<path>} to the loadpath.
\item option \texttt{-smoke-detector \{none|top|deep\}} try to detect
if the context is self-contradicting.
\item option \texttt{-latex \textsl{<dir>}}: produce a summary of
the replay under the form of a tabular environment in LaTeX, one
tabular for each theory, one per file, in directory \texttt{\textsl{<dir>}}.
......@@ -499,6 +502,46 @@ not and you have to use the IDE to update it.
% the replay in HTML syntax.
\end{itemize}
\paragraph{Smoke Detector}
The smoke detector try to detect if the context is self-contradicting
and, thus, that anything can be proved in this context. The smoke
detector can't be run on outdated session and doesn't modify the session.
It has three possible configurations :
\begin{itemize}
\item \texttt{none} : don't run the smoke detector
\item \texttt{top} : The negation of each proved goals
tries to be proved with the same timeout and the same prover which
prove the goal.
\begin{verbatim}
Goal G : forall x:int. q x -> (p1 x \/ p2 x)
\end{verbatim}
becomes
\begin{verbatim}
Goal G : ~ (forall x:int. q x -> (p1 x \/ p2 x))
\end{verbatim}
\item \texttt{deep} : The same technique as \texttt{top} but the
negation is pushed under the universal quantification (without
changing them) and under the implication. The previous example becomes
\begin{verbatim}
Goal G : forall x:int. q x /\ ~ (p1 x \/ p2 x)
\end{verbatim}
\end{itemize}
The name of the goals which triggered the smoke detector are printed :
\begin{verbatim}
goal 'G', prover 'Alt-Ergo 0.93.1': Smoke detected!!!
\end{verbatim}
Moreover \texttt{Smoke detected} (exit code 1) is printed at the end if the smoke
detector has been trigged, or \texttt{No smoke detected} (exit code 0)
otherwise.
\paragraph{Customizing LaTeX output}
The generated LaTeX files contain some macros that must be defined
......@@ -29,6 +29,13 @@ let opt_latex = ref ""
let opt_latex2 = ref ""
let opt_html = ref ""
let opt_force = ref false
let opt_smoke = ref Session.SD_None
let set_opt_smoke = function
| "none" -> opt_smoke := Session.SD_None
| "top" -> opt_smoke := Session.SD_Top
| "deep" -> opt_smoke := Session.SD_Deep
| _ -> assert false
let spec = Arg.align [
("-I",
......@@ -37,6 +44,9 @@ let spec = Arg.align [
("-force",
Arg.Set opt_force,
" enforce saving of session even if replay failed") ;
("-smoke-detector",
Arg.Symbol (["none";"top";"deep"],set_opt_smoke),
" try to detect if the context is self-contradicting") ;
("-s",
Arg.Clear opt_stats,
" do not print statistics") ;
......@@ -75,6 +85,12 @@ let () =
exit 0
let () =
if !opt_smoke <> Session.SD_None && !opt_force then begin
Format.printf "You can't force when detecting smoke@.";
exit 1
let fname = match !file with
| None ->
Arg.usage spec usage_str;
......@@ -524,8 +540,13 @@ let print_report (g,p,r) =
printf " goal '%s', prover '%s': " g p;
match r with
| M.Wrong_result(new_res,old_res) ->
printf "%a instead of %a@."
print_result new_res print_result old_res
begin match !opt_smoke with
| Session.SD_None ->
| _ ->
printf "Smoke detected!!!@."
| M.No_former_result ->
printf "no former result available@."
| M.CallFailed msg ->
......@@ -533,22 +554,7 @@ let print_report (g,p,r) =
| M.Prover_not_installed ->
printf "not installed@."
let () =
try
eprintf "Opening session...@?";
let found_obs =
M.open_session ~allow_obsolete:true
~env ~config ~init ~notify project_dir
in
if found_obs then
eprintf "[Warning] session is obsolete@.";
M.maximum_running_proofs :=
Whyconf.running_provers_max (Whyconf.get_main config);
eprintf " done@.";
if !opt_latex <> "" then print_latex_statistics 1 !opt_latex
else
if !opt_latex2 <> "" then print_latex_statistics 2 !opt_latex2
else
let add_to_check_no_smoke found_obs =
let callback report =
eprintf "@.";
let files,n,m =
......@@ -584,9 +590,56 @@ session NOT updated)@." n m
eprintf "Replay failed.@.";
exit 1
in
M.check_all ~callback;
try main_loop ()
with Exit -> eprintf "main replayer exited unexpectedly@."
let add_to_check_smoke () =
eprintf "@.";
match report with
eprintf "No smoke detected.@.";
exit 0
| _ ->
List.iter print_report report;
eprintf "Smoke detected.@.";
exit 1
in
let add_to_check found_obs =
| Session.SD_None -> add_to_check_no_smoke found_obs;
| _ -> assert (not found_obs); add_to_check_smoke ()
let () =
try
let found_obs =
in
if found_obs then begin
if !opt_smoke <> Session.SD_None then begin
eprintf
"[Error] I can't run the smoke detector if the session is obsolete";
exit 1
end;
end;
M.smoke_detector := !opt_smoke;
eprintf " done@.";
else
else
begin
add_to_check found_obs;
try main_loop ()
| M.OutdatedSession ->
eprintf "The session database '%s' is outdated, cannot replay@."
......@@ -104,6 +104,11 @@ type proof_attempt_status =
| InternalFailure of exn (** external proof aborted by internal error *)
| Unedited (** interactive prover yet no proof script *)
type smoke_detector =
| SD_None (** no smoke detector *)
| SD_Top (** smoke_detector *)
| SD_Deep (** smoke_detector_deep *)
(* main functor *)
......@@ -225,6 +230,8 @@ let transformations g = g.transformations
let external_proofs g = g.external_proofs
let goal_expanded g = g.goal_expanded
let smoke_detector = ref SD_None
let get_task g =
match g.task with
| None ->
......@@ -1733,7 +1740,8 @@ let same_result r1 r2 =
| Call_provers.Failure _, Call_provers.Failure _-> true
| _ -> false
let check_external_proof g a =
(** When no smoke *)
let check_external_proof_not_smoked g a =
(* check that the state is not Scheduled or Running *)
if running a then ()
else
......@@ -1781,6 +1789,62 @@ let check_external_proof g a =
(get_task g)
(** When some smoke method is used *)
let check_external_proof_smoked g a =
match a.proof_state with
| Done ({Call_provers.pr_answer = Call_provers.Valid } as old_res)
when not (running a)->
begin
incr proofs_to_do;
match a.prover with
| Undetected_prover s ->
push_report g s Prover_not_installed;
incr proofs_done;
set_proof_state ~obsolete:false a Undone
| Detected_prover p ->
let p_name = p.prover_name ^ " " ^ p.prover_version in
let callback result =
match result with
| Scheduled | Running | Interrupted -> ()
| Undone | Unedited -> assert false
| InternalFailure msg ->
push_report g p_name (CallFailed msg);
incr proofs_done;
set_proof_state ~obsolete:false a result
| Done new_res ->
begin
match new_res.Call_provers.pr_answer with
| Call_provers.Valid ->
push_report g p_name (Wrong_result(new_res,old_res))
| _ -> ()
end;
incr proofs_done;
in
let old = if a.edited_as = "" then None else
begin
let f = Filename.concat !project_dir a.edited_as in
(Some (open_in f))
in
let task = match !smoke_detector with
| SD_None -> assert false
| SD_Top -> Trans.apply Smoke_detector.top (get_task g)
| SD_Deep -> Trans.apply Smoke_detector.deep (get_task g) in
schedule_proof_attempt
~debug:false ~timelimit:a.timelimit ~memlimit:0
?old ~command:p.command ~driver:p.driver
~callback
task
| _ -> ()
| SD_None -> check_external_proof_not_smoked g a
| _ -> check_external_proof_smoked g a
let rec check_goal_and_children g =
Hashtbl.iter (fun _ a -> check_external_proof g a) g.external_proofs;
Hashtbl.iter
......@@ -64,6 +64,14 @@ type proof_attempt_status = private
(** {2 Smoke detector} *)
| SD_None (** No smoke detector *)
| SD_Top (** Negation added at the top of the goals *)
| SD_Deep
(** Negation added under implication and universal quantification *)
(** {2 Observers signature} *)
module type OBSERVER = sig
......@@ -304,6 +312,9 @@ module Make(O: OBSERVER) : sig
(** [clean a] removes failed attempts below [a] where
there at least one successful attempt or transformation *)
val smoke_detector : smoke_detector ref
(** Define if the smoke detector is used *)
(* Copyright (C) 2010-2011 *)
(* François Bobot *)
(* Jean-Christophe Filliâtre *)
(* Claude Marché *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
(* Smoke detector try to find if the axiomatisation is self-contradicting.
The second smoke detector add the negation under the implication and
universal quantification (replace implication by conjunction).
open Ident
open Term
open Decl
open Task
let create app =
Trans.goal (fun pr t -> [create_prop_decl Pgoal pr (app t)])
let top = create t_not
let rec neg f = match f.t_node with
| Tbinop (Timplies,f1,f2) -> t_and f1 (neg f2)
| Tquant (Tforall,fq) ->
let vsl,_trl,f = t_open_quant fq in
t_forall_close vsl _trl (neg f)
| Tlet (t,fb) ->
let vs,f = t_open_bound fb in
t_let_close vs t (neg f)
| _ -> t_not f
let deep = create neg
let () = List.iter (fun (name,trans) -> Trans.register_transform name trans)
["smoke_detector_top",top;
"smoke_detector_deep",deep]
Local Variables:
compile-command: "unset LANG; make -C ../.. byte"
End:
(* Claude Marché *)
val top : Task.task Trans.trans
val deep : Task.task Trans.trans
