typing of formulas
parent 65f60f57
...@@ -323,11 +323,11 @@ lexpr: ...@@ -323,11 +323,11 @@ lexpr:
{ infix_pp $1 PPmod $3 } { infix_pp $1 PPmod $3 }
| MINUS lexpr %prec uminus | MINUS lexpr %prec uminus
{ prefix_pp PPneg $2 } { prefix_pp PPneg $2 }
/*** | ident
| qualid_ident
{ mk_pp (PPvar $1) } { mk_pp (PPvar $1) }
| qualid_ident LEFTPAR list1_lexpr_sep_comma RIGHTPAR | ident LEFTPAR list1_lexpr_sep_comma RIGHTPAR
{ mk_pp (PPapp ($1, $3)) } { mk_pp (PPapp ($1, $3)) }
| qualid_ident LEFTSQ lexpr RIGHTSQ | qualid_ident LEFTSQ lexpr RIGHTSQ
{ mk_pp (PPapp (Ident.access, [mk_pp_i 1 (PPvar $1); $3])) } { mk_pp (PPapp (Ident.access, [mk_pp_i 1 (PPvar $1); $3])) }
...@@ -187,6 +187,7 @@ val f_and : fmla -> fmla -> fmla ...@@ -187,6 +187,7 @@ val f_and : fmla -> fmla -> fmla
val f_or : fmla -> fmla -> fmla val f_or : fmla -> fmla -> fmla
val f_implies : fmla -> fmla -> fmla val f_implies : fmla -> fmla -> fmla
val f_iff : fmla -> fmla -> fmla val f_iff : fmla -> fmla -> fmla
val f_binary : binop -> fmla -> fmla -> fmla
val f_not : fmla -> fmla val f_not : fmla -> fmla
val f_true : fmla val f_true : fmla
val f_false : fmla val f_false : fmla
...@@ -13,5 +13,14 @@ logic length : 'a list -> int ...@@ -13,5 +13,14 @@ logic length : 'a list -> int
logic is_nil : 'a list -> prop logic is_nil : 'a list -> prop
axiom a : forall x:'a list. if true then not false else false
...@@ -27,6 +27,8 @@ type error = ...@@ -27,6 +27,8 @@ type error =
| UnboundType of string | UnboundType of string
| TypeArity of string * int * int | TypeArity of string * int * int
| Clash of string | Clash of string
| PredicateExpected
| TermExpected
exception Error of error exception Error of error
...@@ -46,6 +48,12 @@ let report fmt = function ...@@ -46,6 +48,12 @@ let report fmt = function
fprintf fmt "but is applied to %d argument(s)@]" n fprintf fmt "but is applied to %d argument(s)@]" n
| Clash id -> | Clash id ->
fprintf fmt "Clash with previous constant %s" id fprintf fmt "Clash with previous constant %s" id
| PredicateExpected ->
fprintf fmt "syntax error: predicate expected"
| TermExpected ->
fprintf fmt "syntax error: term expected"
(** typing environments *)
module M = Map.Make(String) module M = Map.Make(String)
...@@ -75,105 +83,172 @@ let add_tyvar x v env = { env with tyvars = M.add x v env.tyvars} ...@@ -75,105 +83,172 @@ let add_tyvar x v env = { env with tyvars = M.add x v env.tyvars}
let add_tysymbol x ty env = { env with tysymbols = M.add x ty env.tysymbols } let add_tysymbol x ty env = { env with tysymbols = M.add x ty env.tysymbols }
(** typing using destructive type variables *) (** typing using destructive type variables
module D = struct
(* types with destructive type variables *)
type ty =
| Tyvar of type_var
| Tyapp of tysymbol * ty list
and type_var = {
tag : int;
user : bool;
tvsymbol : tvsymbol;
mutable type_val : ty option;
let create_type_var =
let t = ref 0 in
fun ~user x ->
incr t;
{ tag = !t; user = user; tvsymbol = Name.from_string x; type_val = None }
let rec occurs v = function
| Tyvar { type_val = Some t } -> occurs v t
| Tyvar { tag = t; type_val = None } -> v.tag = t
| Tyapp (_, l) -> List.exists (occurs v) l
(* destructive type unification *)
let rec unify t1 t2 = match t1, t2 with
| Tyvar { type_val = Some t1 }, _ ->
unify t1 t2
| _, Tyvar { type_val = Some t2 } ->
unify t1 t2
| Tyvar v1, Tyvar v2 when v1.tag = v2.tag ->
true
(* instantiable variables *)
| Tyvar ({user=false} as v), t
| t, Tyvar ({user=false} as v) ->
not (occurs v t) && (v.type_val <- Some t; true)
(* recursive types *)
| Tyapp (s1, l1), Tyapp (s2, l2) ->
s1 == s2 && List.length l1 = List.length l2 &&
List.for_all2 unify l1 l2
| Tyapp _, _ | _, Tyapp _ ->
false
(* other cases *)
| Tyvar {user=true; tag=t1}, Tyvar {user=true; tag=t2} ->
t1 = t2
(* env + destructive type variables environment *)
type denv = {
env : env;
dvars : (string, type_var) Hashtbl.t;
let create env = { env = env; dvars = Hashtbl.create 17 }
let find_type_var x env =
try
Hashtbl.find env.dvars x
with Not_found ->
let v = create_type_var ~user:true x in
Hashtbl.add env.dvars x v;
v
(* parsed types -> intermediate types *)
let rec dty env = function
| PPTvarid (x, _) ->
Tyvar (find_type_var x env)
| PPTexternal (p, id, loc) ->
if not (M.mem id env.env.tysymbols) then error ~loc (UnboundType id);
let s = M.find id env.env.tysymbols in
let np = List.length p in
let a = List.length s.Ty.ts_args in
if np <> a then error ~loc (TypeArity (id, a, np));
Tyapp (s, List.map (dty env) p)
(* intermediate types -> types *)
let rec ty env = function
ty env t
| Tyvar { tvsymbol = tv } ->
Ty.ty_var tv
| Tyapp (s, tl) ->
Ty.ty_app s (List.map (ty env) tl)
end parsed trees intermediate trees typed trees
(Ptree) (D below) (Term)
ppure_type ---dty---> dty ---ty---> ty
lexpr --dterm--> dterm --term--> term
lexpr --dfmla--> dfmla --fmla--> fmla
(** typing *) *)
(** types with destructive type variables *)
type dty =
| Tyvar of type_var
| Tyapp of tysymbol * dty list
and type_var = {
tag : int;
user : bool;
mutable type_val : dty option;
let term env t = match t.pp_desc with let create_type_var =
let t = ref 0 in
fun ~user x ->
incr t;
unify t1 t2
unify t1 t2
true
false
(* other cases *)
t1 = t2
(** environment + destructive type variables environment *)
type denv = {
env : env;
let create_denv env = { env = env; dvars = Hashtbl.create 17 }
try
with Not_found ->
v
(** typing types *)
| PPTvarid (x, _) ->
ty env t
Ty.ty_var tv
| Tyapp (s, tl) ->
(** typing terms and formulas *)
type dterm = { dt_node : dterm_node; dt_ty : dty }
and dterm_node =
| Tbvar of int
| Tvar of vsymbol
| Tapp of fsymbol * dterm list
| Tlet of dterm * string * dterm
(* | Tcase of dterm * tbranch list *)
| Teps of string * dfmla
and dfmla =
| Fapp of psymbol * dterm list
| Fquant of quant * string * dfmla
| Fbinop of binop * dfmla * dfmla
| Fnot of dfmla
| Ftrue
| Ffalse
| Fif of dfmla * dfmla * dfmla
(* | Flet of dterm * string * dfmla *)
(* | Fcase of dterm * (pattern * dfmla) list *)
let binop = function
| PPand -> Fand
| PPor -> For
| PPimplies -> Fimplies
| PPiff -> Fiff
| _ -> assert false
let rec dterm env t = match t.pp_desc with
| _ -> | _ ->
assert false (*TODO*) assert false (*TODO*)
and dfmla env e = match e.pp_desc with
| PPtrue ->
Ftrue
| PPfalse ->
Ffalse
| PPprefix (PPnot, a) ->
Fnot (dfmla env a)
| PPinfix (a, (PPand | PPor | PPimplies | PPiff as op), b) ->
Fbinop (binop op, dfmla env a, dfmla env b)
| PPinfix _ ->
error ~loc:e.pp_loc PredicateExpected
| PPif (a, b, c) ->
Fif (dfmla env a, dfmla env b, dfmla env c)
| PPforall (id, pt, _, a) -> (* TODO: triggers *)
| _ ->
let fmla env f = let rec term env t =
and fmla env = function
| Ftrue ->
f_true
| Ffalse ->
f_false
| Fnot f ->
f_not (fmla env f)
| Fbinop (op, f1, f2) ->
f_binary op (fmla env f1) (fmla env f2)
| Fif (f1, f2, f3) ->
f_if (fmla env f1) (fmla env f2) (fmla env f3)
| _ ->
(** building environments *) (** building environments *)
open Ptree open Ptree
...@@ -191,20 +266,34 @@ let add_type loc ext sl s env = ...@@ -191,20 +266,34 @@ let add_type loc ext sl s env =
let add_function loc pl t env id = let add_function loc pl t env id =
if M.mem id env.fsymbols then error ~loc (Clash id); if M.mem id env.fsymbols then error ~loc (Clash id);
let denv = D.create env in let denv = create_denv env in
let pl = List.map (D.dty denv) pl and t = D.dty denv t in let pl = List.map (dty denv) pl and t = dty denv t in
let pl = List.map (D.ty denv) pl and t = D.ty denv t in let pl = List.map (ty denv) pl and t = ty denv t in
let s = create_fsymbol (Name.from_string id) (pl, t) false in let s = create_fsymbol (Name.from_string id) (pl, t) false in
{ env with fsymbols = M.add id s env.fsymbols } { env with fsymbols = M.add id s env.fsymbols }
let add_predicate loc pl env id = let add_predicate loc pl env id =
if M.mem id env.psymbols then error ~loc (Clash id); if M.mem id env.psymbols then error ~loc (Clash id);
let pl = List.map (D.dty denv) pl in let pl = List.map (dty denv) pl in
let pl = List.map (D.ty denv) pl in let pl = List.map (ty denv) pl in
let s = create_psymbol (Name.from_string id) pl in let s = create_psymbol (Name.from_string id) pl in
{ env with psymbols = M.add id s env.psymbols } { env with psymbols = M.add id s env.psymbols }
let fmla env f =
let f = dfmla denv f in
fmla denv f
let term env t =
let t = dterm denv t in
term denv t
let axiom loc s f env =
ignore (fmla env f);
env
let add env = function let add env = function
| TypeDecl (loc, ext, sl, s) -> | TypeDecl (loc, ext, sl, s) ->
add_type loc ext sl s env add_type loc ext sl s env
...@@ -212,5 +301,7 @@ let add env = function ...@@ -212,5 +301,7 @@ let add env = function
List.fold_left (add_predicate loc pl) env ids List.fold_left (add_predicate loc pl) env ids
| Logic (loc, ext, ids, PFunction (pl, t)) -> | Logic (loc, ext, ids, PFunction (pl, t)) ->
List.fold_left (add_function loc pl t) env ids List.fold_left (add_function loc pl t) env ids
| Axiom (loc, s, f) ->
axiom loc s f env
| _ -> | _ ->
