GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
e9a6fd45
e9a6fd45
Andrei Paskevich
remove debug output in eliminate_definition
10b5e6c6
src/transform/eliminate_definition.ml
e9a6fd45
@@ -31,11 +31,7 @@ let add_t_ax task nm ls hd e =
let
vl
Svs
elements
t_freevars
Svs
empty
hd
in
let
vl
Svs
elements
t_freevars
Svs
empty
hd
in
let
ax
f_forall
vl
Term
hd
f_equ
hd
e
in
let
ax
f_forall
vl
Term
hd
f_equ
hd
e
in
let
id
id_derive
nm
"_def"
ls
ls_name
in
let
id
id_derive
nm
"_def"
ls
ls_name
in
try
add_decl
task
create_prop_decl
Paxiom
create_prsymbol
id
ax
add_decl
task
create_prop_decl
Paxiom
create_prsymbol
id
ax
UnboundVars
vs
Format
printf
"@[%a@
\n
Pretty
print_fmla
ax
assert
false
let
add_f_ax
task
nm
ls
hd
e
let
add_f_ax
task
nm
ls
hd
e
let
vl
Svs
elements
f_freevars
Svs
empty
hd
in
let
vl
Svs
elements
f_freevars
Svs
empty
hd
in
